baec777
Miles Distant Measure
Thu Nov 15, 2001 12:53 am
doesn anyones know where I can find flight measures.
for example:
when u enter DFW-LGW, the map shows a distant line between the 2 airports and how far it is...??
and second is.....
when u enter something like this....
8000nm @ LHR, map shows a line circle....
please help me....
Baec777  Big thumbs up
copter808
RE: Miles Distant Measure
Thu Nov 15, 2001 1:11 am
What you're probably looking at is the "Great Circle" route. Since the earth is not flat, a flat map will not accurately depict the world. The shortest route (across the globe) appears as a curved line when drawn on a flat map. Look at a globe sometime, then measure the distance between 2 points with a string. You'll notice that although the string is a straight line, the lines of latitude are curved. On your flat map, the latitude lines are straight, but the route appears curved. Shortest distance betwreen 2 points is the great circle route.
bombayhog
Thu Nov 15, 2001 1:20 am
baec777
Thu Nov 15, 2001 1:24 am
I found what I been looking for, thanks alot..... Bombayhog ! Big grin
Baec777 Big grin
