JAT
What Does Air Transat Use To Europe?
Sat Nov 17, 2001 6:20 am
What equipment does Air Transat use to theor flights to Europe, after that whole ETOPS thing. Do they use the A330s and if so are the flights loger, or have they switched to L1011s? Specifically LGW.
Thanks.
Lindy
RE: What Does Air Transat Use To Europe?
Sat Nov 17, 2001 6:23 am
They made few charter flights passed summer YYZ-WAW. Few times they were using A330 and few times L1011s
BWIADCA - Nikon D100
manni
Sat Nov 17, 2001 6:24 am
757s and L1011s to BRU
SUPPORT THE LEBANESE CIVILIANS
gkirk
Sat Nov 17, 2001 6:30 am
They used 757s mostly through NCL, but also the odd L1011 and A330  Smile
quebecair727
Sat Nov 17, 2001 7:40 am
Depends where you are leaving from and were you are going. For instance the flight between Montreal and Toulouse is in 757. YMX-CDG would be A330 and L1011.
Have a nice flight is you are boarding...
gmonney
What About The A310's?
Sat Nov 17, 2001 7:43 am
Do they use the A310's for domestic?
Grant
Drive it like you stole it!
JAT
Sat Nov 17, 2001 7:53 am
I will be leaving on the 20th of December YYZ-LGW. I wonder what aircraft it will be..... I hope it's an L1011, I have never flown on this type and I really want to before they are retired. I don't think I'll every have another chance.....
What do you think? Which will it be?
BA-747
Sat Nov 17, 2001 7:59 am
think they use L1011 B757 and A330's to GLA
AWspicious
Sat Nov 17, 2001 1:18 pm
Probably a 500 which has a longer range than the 150s?
Nevermind political correctness - Envision using your turn signals!
yyz717
Sat Nov 17, 2001 1:31 pm
TS uses their entire fleet for Europe flights. You could be on the A332, A333, A310, 752, L15 or L10. They mix and match alot. LGW could be anything.
After the ETOPS restrictions, they rerouted their remaining A330's to fly more domestic and L-1011's more Europe. But even an ETOPS restricted A330 is more efficient to Europe than an L-1011 flight able to fly more direct. Indeed, the A330's are now back on transatlantic flights.
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
Airbus Lover
Sat Nov 17, 2001 4:55 pm
No they use hot air baloons...j/k
they use A330 series, 757 ,310 and L1011.
RJ100
Sat Nov 17, 2001 7:23 pm
Hello
they use the 757 between Basel and Montreal.
RJ100
none
dreamexpress
Sat Nov 17, 2001 7:30 pm
L1011's, A330's and the odd 757 to LGW.
Sukhoi
Sat Nov 17, 2001 7:55 pm
Yep LGW gets A330 and Tristar both 100's and 500's with the odd 757 and A310 thrown in for good measure, although I havent caught a 757 recently
Paul
JAT
Sat Nov 17, 2001 11:24 pm
Thanks for the info. I hope it's a TriStar.
yyz717
Sun Nov 18, 2001 5:22 am
Well, numerically speaking, it probably will be! The L-1011 is TS's most numerous type!
