greenjet
Concorde Load Factors At 70%
Thu Nov 29, 2001 5:32 am
British Airways says that load factors on its BAC-Aerospatiale Concorde services have consistently exceeded 70% since the aircraft returned to regular commercial service earlier this month.
Following restoration of the aircraft’s certificate of airworthiness in September, the carrier restarted transatlantic Concorde services to New York JFK on 7 November and is preparing to recommence supersonic operations to Barbados for the winter.
“Concorde bookings to New York are going extremely well,” says BA CEO Rod Eddington. “Since 7 November, load factors have consistently been in excess of 70%.”
Weekly Barbados flights are scheduled to begin again on 1 December and continue until 13 April.
Source: Air Transport Intelligence news
GDB
RE: Concorde Load Factors At 70%
Thu Nov 29, 2001 11:36 am
I can personally confirm those factors are true, and good news, considering we break even at around 30%
If these figures continue, expect the twice-daily JFK service to be reinstated around next april.
bombayhog
Thu Nov 29, 2001 1:26 pm
BA breaks even with a load factor of 30% on the Concorde?? I had no idea. I'd always heard that the Concorde tended to lose money even with high loads.
/gwl
Thu Nov 29, 2001 6:20 pm
Nope, Bombayhog - Concorde is a major moneyspinner for BA. Over £50 million profit in the last twelve months it operated!
GDB
Thu Nov 29, 2001 9:49 pm
The basic return ticket is now £6800. You do get upgrades and staff discounts, (BA get a 90% discount, others 60-75%).
Looking at lists the other day, you noticed that many familiar names were on board again, I don't mean famous people, though they are too, rather very frequent business users. They said all along they'd be back, the media were rather sceptical, what do they know?
For the return to service, a 60% discounted ticket was available for about a week, at least one Air.Net member is taking advantage of that offer.
Pre the grounding, charters made up 9% of the revenue, but used up a lot of airframe life, so BA were looking to reduce them.
Now the official line is no charters until 2003, and then only a few lucrative ones, (no more 90 minute Mach 2 pleasure flights for £600-£800).
But since Sept. 11th, in the 'cash is king' BA, we've heard marketing are looking again at charters.
When more modified aircraft are available, we'll see what happens. Next are the Saturday LHR-BGI/BGI-LHR flights starting 1st December, some are already fully-booked.
SInGAPORE_AIR
Thu Nov 29, 2001 10:30 pm
So with a 75% load factor, BA makes £20 million annually. Interesting...
David L
RE: GDB
Thu Nov 29, 2001 11:34 pm
Do you know which aircraft is on the JFK run tomorrow (30th)? What about the 12:30 flight from JFK on the 4th December? Just in case I forget to look as I did on my only other Concorde trip.
GDB
RE: GDB
Fri Nov 30, 2001 2:45 am
I'll have the details on which of the three operational aircraft you fly on.
Your previous flight, was it after 01/01/98?
SN-A330
RE: Ceilidh
Fri Nov 30, 2001 6:38 am
Ceildih, 70%, that's even much better than the load factor of your L1011's  Insane  Big thumbs up  Insane  Big thumbs up
I would rather be flying...
SInGAPORE_AIR
Fri Nov 30, 2001 7:09 am
Is 70% good? Do explain someone.
GDB
Singapore_Air
Sat Dec 01, 2001 2:03 am
As stated previously, break even is around 30%
In the last few days, the BA001's have been just over 80%
aamd11
Sun Dec 02, 2001 12:58 am
Concorde is a goldmine for BA and AF. AF aircraft are often chartered and as they only have 5 a/c now they get quite a good usage. BA aircraft are usually concentrated on scheduled services. 70% is fantastic news... concorde accounts for a relatively large percentage of profits at ba. Im interested to see how AF is doing..... they never did seem to have as many concorde flights and pax numbers were a little lower, now they have 1 less a/c how does it affect em?
hkg_clk
Mon Dec 03, 2001 12:03 am
Are BA and AF planning to modify all their aircraft so that they can all fly again? If they are going to do so, any idea when the work will be completed?
See my homepage for a comprehensive guide to spotting and photography at HKG
GDB
Mon Dec 03, 2001 1:20 am
BA are working on the 4th A/C (OAD). Officially no more have yet been programmed, but we've heard the OAC is almost certain to be modded.
The great load factors make it highly likely that OAA will also be modded, perhaps at the same time as OAC.
OAB will be decided later, BA intend to resume 2 JFKs per day from April.
So it's likely that all 7 will eventually be done.
All modded A/C so far have had the spar 72 wing mod done previously, the rest will have to have the work done before the tank mod.
OAA and OAB also require a routine heavy maint. check.
If OAC is started this month, it should be ready by mid april.
A tank mod takes about 90 days.
David L
RE: GDB
Sat Dec 08, 2001 8:32 pm
Sorry I appeared to ignore your reply after I'd asked you a question but everything kind of hit the fan at work after I'd posted that.
My first flight was LHR-JFK, 15th Sep 1999, charter flight BA 9093. If you can supply the registration for that aircraft I'd be very grateful.
In case anyone else is interested, this time my outward flight was on "AE" and the return was on "AF".
GDB
RE: GDB
Sat Dec 08, 2001 8:54 pm
I'll be able to find that out.
Updating my previous posts on here, OAC will start it's mod. in January, although not officially programmed yet, the tank mod. kits for OAA and OAB have been ordered.
GDB
David L
Wed Dec 12, 2001 1:51 am
The BA9093C on 15 sept. 99, was operated by G-BOAA
David L
RE: David L
Wed Dec 12, 2001 3:45 am
Thanks GDB, I can finally get some sleep! So, three flights and no duplicates. I'll need to contact you to synchronise aircraft next time. It'll be a couple of years though - don't leave your job!
