ILS
What Happened Here?
Fri Dec 14, 2001 1:38 pm
What happened in this situation?
crank
RE: What Happened Here?
Fri Dec 14, 2001 1:43 pm
I think this QF 744 than overran a runway, I've seen it from a different angle and it was obvious that it had overran the runway, you could clearly see the tire prints in the grass.
CX Flyboy
Fri Dec 14, 2001 1:45 pm
Silly pilots, that's what happened!!
PHLflyer
Fri Dec 14, 2001 1:48 pm
Click for large version
Photo © K W Chui
Photo © K S Down
Check the captions of these photos. I think this will answer your question.
ILS
Fri Dec 14, 2001 1:53 pm
Thanks!  Big thumbs up
Max Q
Fri Dec 14, 2001 1:58 pm
It looks like the Qantas 747-400 that overran the runway in Bangkok.
First officer was flying the aircraft and realized their approach speed was too high and that they would land
too far down the runway.
He made an excellent decision to reject the landing and
started to go-around, adding power and raising the nose
However the Captain decided that a safe landing was indeed feasible and took over.The aircraft did indeed land too far down the runway and they were unable to
stop.
Several factors came into play first of all attempting to land after a go-around has been initiated is risky at best
and against most airlines procedure.
Secondly the Captain was relatively new to the type and attempted a manoeuvre that he MIGHT have got away with on a smaller/lighter aircraft.
An unfortunate way to end a nearly perfect safety record although their were no fatalities or serious injuries
It actually ended up on a golf course.
Not wanting to lose at least their perfect Hull loss record Qantas decided at enormous expense to repair/rebuild the aircraft.
For the sake of a little pride and a total break down in
crew communication an aircraft was almost lost, along
with 400 or so people, they were lucky.
PHLflyer
Fri Dec 14, 2001 1:59 pm
You should like these photos also!
Photo © Dayot Jean-Charles
hkgspotter1
Fri Dec 14, 2001 2:29 pm
STUPID PILOTS more like it.
This is the QF 744 that went cross country in Bangkok !!
VapourTrails
RE: What Happened Here? QF VH-OJH
Fri Dec 14, 2001 7:26 pm
 Embarrassment for QF!! (& Air Canada as well)!!
Photo © Frank Schaefer
VH-OJH repaired and flying again -- read photo comment..
"The best office in the world."
