vfw614
Paris Airport System
Thu Dec 27, 2001 9:57 am
I just had a look at the Paris airport landscape and stumbled over an airport called "Coulommiers-Voisins", approx 40km east of the city centre and close to the A4 motorway. With secondary airports around Paris being quite popular with low-cost carriers, I am wondering why I have never seen this one even only mentioned: Ryanair serves Beauvais from PIK which is some 60km outside Paris and Debonair used to fly from LTN to Pontoise (to the north-west of Paris) which is about the same distance from the city as Coulommiers-Voisins. I remember even a semi-scheduled service from MGL to the general aviation airfield at Toussous-Le-Noble, south of Versailles, a couple of years back. Coulommiers-Voisins has to runways with a length of approx 2.200m and 1.500m, so what is it used for ?
Cleco
RE: Paris Airport System
Thu Dec 27, 2001 1:47 pm
I hope this helps.
http://perso.wanadoo.fr/planeur
Jake
EMBRY-RIDDLE BABY
vfw614
Fri Dec 28, 2001 12:35 am
Thanks Jake,
I have done a bit of searchung and below is what I have found. Looking at the website you mentioned, quite a waste if they really use it as glider airfield as it has been a major military airfield in the past with two long runways. In fact at one point it was considered to become what Orly today is.
from http://www.strandlab.com/cv/
The aerodrome was built in the early 1930s by aviation enthusiasts. As war approached, the french Armée de l'Air took it over and shared it for some time with units of the RAF (Royal Air Force) expeditionary forces in France. After the defeat of the BEF (British Expediitionary Force) and the fall of France, the Luftwaffe moved in and improved the facilities; they operated the airfield until late September 1944. After the German withdrawal, it accommodated squadrons of the U.S. Army Air Force (USAAF) and the RAF, being vacated in late September 1945. The aerodrome then languished while its disposition was discussed, though the Air Ministry (France) planned and started to use it as an alternate for the then-busy Le Bourget airport (at that time, the only airport servicing Paris). During this time, NATO (the North Atlantic Treaty Organization) upgraded the field it to its standards. However, by 1960, A.D.P. (Aéroports de Paris) decided to build Orly airport. The die was cast, and the future of Coulommiers-Voisins was again uncertain. From the past there remains a portion of the East-West runway (1,400 x 20 m) that is still in use. Airliners drone overhead en-route to Roissy-Charles de Gaulle International Airport.
