2001DC-3
Distance Between Cities
Sat Jan 19, 2002 10:51 am
Looking for a site on the net were I could find distance between cities. If you have knowledge of any please let me know.
thank you
bkkair
RE: Distance Between Cities
Sat Jan 19, 2002 11:05 am
Go to
http://gc.kls2.com
Put in the cities and it will show route and distance
rushed
Sat Jan 19, 2002 11:07 am
If you know the latitude and longititude of your 2 cities you can use this site to get the distance between the two points.. it has a list of 326 cities that it already knows the details for... try it at:
http://www.vsv.slu.se/johnb/java/lat-long.htm
travel blogging enthusiast :)
timz
Sun Jan 20, 2002 7:38 am
Looks like the www.vsv site calculates using a spherical earth, so it can be off by 10-20 miles or so. For lots of purposes that's good enough, but if you want the actual correct distance you can get the airport lat-lons from airnav.com or worldaerodata.com and go to Ed Williams' ever-useful site http://www.best.com/~williams/gccalc.htm to get the distance.
timz
Revised Address
Sun Jan 20, 2002 7:42 am
2001DC-3
RE: Revised Address
Sun Jan 20, 2002 11:14 pm
thank you people.
It was very helpfull.
timz
Fri Jan 25, 2002 9:56 am
Has anyone found a site that gives airport-to-airport distances directly on the GRS80/WGS84 spheroid-- i.e. without having to look up the lat-lons?
http://gc.kls2.com uses the Clarke 1866 spheroid, so its mileages are better than many, but they can still be off by a few miles.
http://www1.drive.net/evird.acgi$pass*42873027!_h-www.landings.com/_landings/pages/search/search_dist_apt.html apparently uses a spherical earth, as do most other sites.
If you find a possible site and want to test it, try HNL-RAR, which should come out 2542.3 nm, and LED-ANC, which should come out 3556.8 nm. Also, the equator to the 45th parallel should be 2691.655 nm, while 45 degrees to the pole is 2708.975.
woodsboy
Fri Jan 25, 2002 10:00 am
http://www.webflyer.com/milemarker/milemarker.htm
I dont think anybody has posted this one yet, but its the one I use all the time. It will alsocalculate frequent flyer milage for the different airlines and membership levels, bonus miles etc.
timz
Fri Jan 25, 2002 10:05 am
Thanks for the suggestion-- I hadn't seen that one. Looks like they use a spherical earth too; they give 2940 miles for HNL-RAR (actual 2925.6 statute miles) and 4080 for ANC-LED (actual 4093.1).
