USAIRDC9
Learning To Fly!
Wed Jan 23, 2002 1:33 am
Hello,
I am starting to take flying lessons on the Cessna
C-150 could someone please give me some information on the airplane such as safety,reliability,controls,ETC?
I will be paying $94.00 for two hours. 1 hour learning and 1 hour flying!!!!!!!!!!!
$50.00 for the Cessna C-150 -1 hour.
$42.00 for the Instructor -2 hours.
$2.00 for the headset -hour.
Those prices sound good dont they?
Where I will be taking it at, The runway is only 35 feet wide and something like 2,275 feet long. There is no ATC. So when I am on solo what would I do if something were to go wrong???!?!?!?!?!?!?!!!!!!!?????????
You can look up the school website at www.longaviation.com Please reply THANKS.........
USAIRDC9
RE: Learning To Fly!
Wed Jan 23, 2002 1:52 am
Just trying to get it back up to the top to get some help and answers!!!!!!!!!!!!!!!!
Kirstey
Wed Jan 23, 2002 2:14 am
www.studentpilot.com
Wed Jan 23, 2002 3:20 am
150's are great planes. I have 100+ hours in ints younger brother the 152. The prices seem reasonable, however I would be surprised if you use 2 hour on ground for 1 hour of flight. Time the time you spend on the ground being taught by your instructor, and make sure they do not rip you off (by charging you more for ground instruction which you do not have). It seems a bit cheap renting out headsets for $2, I would buy one ASAP. The airport sounds fine. You will be familiar with most things that can happen on your solo, and your instructor will more then likely have a transciever so if anything goes wrong he can shout at you. Once you get your license do try to get to busier airports this way you will not feel intermerdiated by bigger busy airports!
Iain
USAIRDC9
Wed Jan 23, 2002 3:36 am
Hey,
Thanks for your help.
The reason why I put 2 hours of instruction is one on the ground and one hour of instruction in the air, sorry that I didnt make that more clear.......
What exactly is a headset for?????????
What other kind of things will I need? Sunglasses? ETC?
He said that we will be flying to an airport with ATC so I can learn how to use it, but he will probably have a radio that I can talk to him on? My biggest fears are death, and getting lost!!!!!!!!!!!!!
USAIRDC9
Wed Jan 23, 2002 3:45 am
Any good C-150 websites?
Wed Jan 23, 2002 4:03 am
I understood what you meant, but many CFI's charge for more ground instruction then they give. Time him and make sure he does not charge you for more then he gave.
You have to go to a towered airport as part of your training, but you can find small towered airports what I suggest is getting very comfortable with them, and go to some of the larger ones. This will make you more confident and a better pilot.
Headset is for 2 reasons decreasing sound, and talking to your instructor/controller/fellow aviators. You will have an intercomm in the aircraft so you can speak to him and ATC at the same time, and so can your instructor.
Yeah I would take sunglasses, that is all I can really think that you will need. You will need more things later on, however your instructor will tell you what you need, as most of them you will have to buy.
Do not worry about getting lost, every pilot has got lost. You will learn what to do if you do get lost, it really is not a big deal!
Iain
USAIRDC9
Wed Jan 23, 2002 4:24 am
Hey,
What is a spin? I am learning about spin recovery...
What others things could go wrong? How many Cessna C-150's are in the USA? I think about 25,000 were made and on the FAA/NTSB websites it says that over 1,475 have had incidents or crashes from 1988 to 2001!!!!!!!!!!!!!!!!
flyf15
Wed Jan 23, 2002 5:23 am
Cessna 150s and 152s are quite safe if maintained well. They're very good training airplanes. The prices seem very reasonable.
Your airport will make you quite a good pilot compared to someone who trains on a 10000x150ft runway. You're only at 565' above the ground, so the length will not be an issue for takeoff or landing. The width will be somewhat of a challenge during crosswind landings early in your training, but you will soon grow used to it.
You don't need to worry about dying at all. Just be confident in yourself, but not overconfident. You might get scared every once in a while, but your CFI will do that so that you learn from your mistakes. He will never let anything get out of control and always predict your mistakes. He is also trained to know very well what you're capable of doing. For your solo flights, he will know what you can/can't do and inform you accordingly.
A spin is when the aircraft stalls and is uncordinated (you'll learn about what that is sooner or later). It then starts to do something that resembles a spiral dive. They can be quite deadly, that is why you are specifically trained on how to avoid them and how to recover from them if one happens.
And yes, you should buy a headset as soon as you economically can. They're something you're always going to use when flying. Get something that is comfortable (that you could wear for at least 3 hours without getting disturbed by it), within your price range, and has quality. I personally have a Dave Clark 13.4...its very comfortable and light, cost around $300 new.
Aside from all this, don't forget to HAVE FUN!!  Big thumbs up
DE727UPS
Wed Jan 23, 2002 5:28 am
I checked out the web site. It's a small school at a small airport...fun place to learn how to fly. The rates are good. You are paying the CFI for an hour of ground time...if this is productive time, I've got no problem with it. If he's in drinking coffee while you pre-flight the aircraft...I'd be questioning it. It all depends on the attitude, motivation, and professionalism of the CFI.
The Cessna 150 is a great airplane. They have a high accident rate because they are used so heavily for training...makes sense.
Hopefully the school has a good mechanic. The problem with only having on Cessna 150 is the downtime if it breaks. You might ask them if they will give you the 172 at the 150 rate if the 150 is down for maintence. If they fix things promptly and get inspections done quickly...this won't be much of a problem.
Don't worry about no tower. I learned at an airport with no tower and was scared to death of them for a long time. You'll get some experience at towers because it's required by the FAR's but you'll still be weak in that area. If you can...listen to some of the tower lingo at some of these on-line ATC sites.
The good news is you'll make up for no tower with your prowess at landing on short, narrow, runways. This will make you a better pilot and is something that the guy learning at a big, towered, airport might be weak at. Just don't be afraid to go around if things don't look good on your landing approaches.
USAIRDC9
Wed Jan 23, 2002 7:36 am
How much different is it in the Cessna C-150 then for example a DC-9?
Is it very bumpy more easily to get or be sick?????????
USAIRDC9
Wed Jan 23, 2002 9:28 am
Hello,
How high do you think that we will be going up on our first few flights?
When I fly solo can I elect which altitude I want to fly at?
I am still a little scared to fly even on large jets due to some earlier incidents that I have had.
I have come to realize that when god wants you, he will take you whether by car wreck,freak accident, or even an airplane crash. I understand that and will not let fear keep me from flying just I would feel more comfortable knowing 100% nothing will happen. I am not scared of death itself, but the impact mine will have on my family with whom I am very close with.
I can accept death, I have had MANY friends and family to die just recently 2 aunts and 1 friend..............
I wish that if I were to die there would be a way to say my last words but seeing as there is no black box on these airplanes I do not believe that I can.
In 2001 there were several fatal aircraft crashes in the Cessna C-150 in the USA. Mostly due to engine failure resulting in spin and one inverted flight.  Sad...................
strickerje
Wed Jan 23, 2002 9:56 am
Congradulations on your decision to begin flight lessons! I currently fly a Cessna 172, which is similar to the 152 but with four seats. The 150 is a bit older, so some of the systems may be different, but overall they should be similar. These single-engine trainers are very safe and reliable. You may think that 1400 crashes in 13 years is a lot, but there are so many of those airplanes flying to make that number actually a very small percentage. As for the price, mine is considerably higher because I fly a 172, but the 152 I used to fly (while they still had it) was priced similarly to your school's 150. I would also recommend that you purchase a headset, because if you wait too long, you will have spent as much on rental as to actually buy one. True, you probably don't have to have a headset as the 150's and 172's have a handheld mic and cabin speaker, but with all the background noise, a headset makes it easier to hear and understand. I would personally recommend the LightSpeed Solo, which is very clear, quiet, and comfortable, and cost me $145 new. Online retailer has good deals if you like shopping online.
Death and getting lost-- well, neither are very likely, but getting lost is really not that big a deal as you will not be very far from the airport and you are generally low enough to be able to recognize some familiar ground objects. Lakes, schools, office buildings, etc will all help you find your way. Now as for death... well, hasn't happened to me yet.  Smile Also remember that your instructor will be with you; you can talk to him through your headset. (Talk without pressing the mic button on the yoke and the instructor can hear you; talk with the mic button held and other aircraft can hear you on the radio.)
The controls of the aircraft consist of a yoke and pedals which your instructor will explain further, but it is controlled the same way all aircraft are controlled. (with a few exceptions, for all of you Airbus freaks who'll try to explain to me what fly by wire is...) The 172 I fly is relatively smooth in flight, and that's in Mississippi where summer weather is often very turbulent. If you get sick easily, I'd recommend you take two Dramimine pills before each flight, especially in warm weather, as that is when motion sickness tends to be worse. This works very well for me.
What else could go wrong-- well, a lot, but the chance that a problem will actually be life-threatening is very slim. Good luck!
-Jeffrey Stricker
serge
Wed Jan 23, 2002 9:58 am
No worries getting lost, I found this cockpit shot on your FBO's website of the C150 you are training in...
:D Big grin Big grin
It looks like its equipped with GPS.
...Serge
serge
Wed Jan 23, 2002 10:01 am
""What kind of plane would I learn to fly in?" Long Aviation conducts private pilot training in the students choice of the Cessna 150 or the Cessna 172. Both are equipped with state-of-the-art satellite navigation systems (color GPS), which are very rare in training aircraft."  Smile/happy/getting dizzy
-from the 'Learning to fly' section on longaviation.com..
...Serge
Av8trxx
Getting Your U.S. PPL
Wed Jan 23, 2002 10:08 am
I also learned to fly in a Cessna 150- N16179. It is very small, and without a lot of Hp but it's fine for training. Once you get your license, then you can get a checkout in a Skyhawk and take a few friends. You will notice the extra performance! I guess it's been too long since I trained, but I couldn't fathom paying $42.00/hr for an instructor! I paid $25-30 tops. Geez, I must be gettin' old. I also have clubs in my area (SAN) that rent C150s for $43/hr, but schools are always $5-10/hr more, so I guess that rate is OK.
If you want to get the most bang for the buck, read all you can before going into your lesson. Do as much bookwork and learning about the airplane, maneuvers, ATC, ect BEFORE you fly. But the MOST important is to fly at least 3 times a week! The less you fly, the more you will pay in the long run as you have to re-learn parts of your previous flights if too much time passes. This just causes you to pay for the same instruction all over again. The avgerage student completes their private training in 70 hours. The min legally required is 40. Most do not finish in a condensed period of time, so they spend many extra hours & dollars re-learning previous tasks.
***JUST THINK: at $92 per hour it will cost you $2,760 MORE to get your license than if you finished in at (or near) 40 hours of training! That money is equal to 65 hours of flying alone in that C150!!! At those rates is will cost $3,680 to get your PPL at 40 hours. At the national avg of 70 hours to get to your checkride, it will cost you $6,440 (without ground instruction).****
Bottom line, if you make it your priority to finish ASAP, you will come away from getting your rating richer and have more money to spend on accumulating time PIC (pilot in command) as a Private instead of paying for a CFI sit sit next to you.
If you don't have the "Gleim Red Covered Book" that everyone uses to study for their PPL written- get one! Highlighting only the right anwsers on the multiple choice questions helps you to do better on the test. (An age old thing most all pilots did in training)
As a student pilot, check out these sites that are "of high relevance to (this) certain discussion" for helpful flight training information and advice:
AirNav.com
Online airport information directory
FlightInfo.com
Awesome & informative pilot website. Lists all rating requirements and curriculum.
Your Pilots License: Getting Started
Flight Training and Pilot career advice
Please send me an E-mail for more on this topic since other helpful links l know of can't be posted as they might be removed for "advertising".
SophieMaltese
Wed Jan 23, 2002 12:47 pm
Those prices do sound pretty good. Where do you live? I pay $95/hr just for the time in the plane (152) with a CFI. However, I've never paid for more than 1/2 hour of ground instruction at a time.
USAIRDC9
Wed Jan 23, 2002 1:18 pm
Hello,
Thanks ya'll have been alot of help! So what exactly is GPS? What will it tell me, ETC? I sooooo did not notice that!!!!!!!!!!! Obviously I am no aviation expert at least on the little planes. I plan on taking a couple of bonines like I have done before........... I would hate to stall the plane I dont see how people crash when they have engine failure cant they just kinda sort of nose dive it to get some lift and set it down in a field instead of spinning? I heard an ATC tape of a guy in a spin quite scary... How high will I be flying about???????????
gocaps16
Wed Jan 23, 2002 1:28 pm
Well, with the GPS and it's moving map, it'll be hard for you to be lost.  Smile You could get lost, but you'll easily manage to find your airport with the GPS and crosschecking your VORs to find your exact position on the sectional. No worries on geting lost. Also, don't be afriad to talk to ATC, they'll help ya.
Kevin/DCA
USAIRDC9
Wed Jan 23, 2002 1:54 pm
Hey,
At what altitude will I be flying at about???????????????
TWAMD-80
Wed Jan 23, 2002 2:11 pm
The C-150 is a good airplane. Right now I am taking flying lessons, but I am training in a C-172. The flight school that I go to has a number of C-150's. Actually I have flown a C-150, and it was a lot of fun. Because the C-150 is much lighter than the C-172, the controls on the 150 are much more sensitive than the controls on the C-172. As far as I know the 150 has a good saftey record.
That sounds like a good price that you are getting. Hey, don't worry about your solo. You will learn what to do if something goes wrong. I was a little nervous on my first solo, but when I got up in the air it was great. Have fun flying!
TWAMD-80
Two A-4's, left ten o'clock level continue left turn!
strickerje
Wed Jan 23, 2002 2:20 pm
Oh, one question I forgot to answer:
As for altitude, that may vary depending on your location. During my local VFR training flights, I stay below 3000 feet, as the area where my flight school operates is under the approach path of a nearby Jackson international airport (JAN). If I stay in the approach path, I stay under 1700 feet MSL (traffic pattern for the airport I use is 1000 feet AGL, or about 1300 feet MSL), since 1700 feet is the start of the JAN's Class D airspace, which requires 2-way radio communication with JAN approach control while in that airspace. If you have a large airport near you, your procedures will be similar, but if not, your altitude will generally be only restricted by weather. (under VFR, 500 feet below a ceiling, which is a broken or overcast cloud layer)
-Jeffrey Stricker
XFSUgimpLB41X
Hey bro... I'm a CFI... Your first lesson will be familiarizing yourself with the airplane and how it feels... Just getting used to it. I have over 150 hours in C150's and they are fun little airplanes to fly. Altitude will be around 2000-3000 feet. When you do your first solo it will only be take-offs and landings around the traffic pattern of which the highest leg is 1000 feet above the ground.
We'll teach you what to do if you get lost.. the biggest trick is always keeping yourself oriented. My favorite remedy for being really lost is called IFR: "I follow roads". Find a road you know and take it back home. For your first 8 or so lessons before you solo youll just be learning the fundamentals of flying the airplane and get the basic ground schooling out of the way. It will be more flying than ground school. Mostly on these lessons I keep my students in the air for about an hour and 10 minutes and total time about an hour and a half for chagring with preflight and pre and post briefing. There will also be a couple dedicated ground school sessions tossed in there. Feel free to email me or holler at me on AOL instant messenger.
As far as dying: these planes just dont fall out of the sky. They take a beating and will treat you nicely if you treat them nicely. Relax and enjoy... it's a blast. Your instructor wont let you get in a situation he/she doesnt feel comfortable in too.
-Denny
Chicks dig winglets.
XFSUgimpLB41X
Wed Jan 23, 2002 2:22 pm
By the way.. that is a very nice Cessna 150 your school has. I'd love to fly that one.  Big grin
USAIRDC9
Wed Jan 23, 2002 2:41 pm
Hi,
Thanks again for all of the nice replies.......
The guy told me that the plane itself is fine but the seats are very worn........ I am a little scared of landing on that little runway and also getting air sickness
I still look forward however to flying!!!!!!!!! When I fly solo can I say for example I was to fly at 700 feet?
Also what kinda of lights are there? How easy is it to see around you in the airplane? Are there windows in the top like slits in the wings? At what angle will I be taking off at about and what will be my steepest?
Any more general information would and will be great.
Thanks alot people!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Wed Jan 23, 2002 4:25 pm
You will have no problem landing on little runways, once you become familar with it, it will be like parking a car in a garage.
You might feel a litle queesy after your first flight, however that is normal and after a couple flights it will go away.
Your instructor and you will decide what altitude you fly at on your solos. The altitude you guys select generally depends on terrain you are flying over. 700 is pretty low I would expect to fly between 2000-4000 feet. You will really not notice the difference when flying from 1000 or 10,000 the houses are just smaller and the mountains are under you instead of infront.
Do not worry about things like lights, your instructor will teach all that stuff to, and it will be far easier to grasp the concept with the hands on appraoch, rather then the internet forum approach.
The vis. in the Cessna's are very good there are slits in the wings in most cessna's however you will not notice or really use them.
The steepest angle you would take off will be like driving up on an on ramp; you will hardly be able to feel it.
Do not worry about dieing in a plane accident. You will soon get used to aircraft and there will be no difference in your mind about getting in your car to go grocery shopping, or in the 150 for a cross country flight.
Iain
USAIRDC9
Thu Jan 24, 2002 12:12 am
 Smile Maybe a bonine or so will cut me out from barfing?
USAIRDC9
Thu Jan 24, 2002 1:54 am
Any more help please????????????
USAIRDC9
Thu Jan 24, 2002 4:00 am
Hey,
Anyway to get a schloarship???????
Thu Jan 24, 2002 5:13 am
I think the parental scholarship is the most common one. However there are some which wil require you to research.
Iain
gocaps16
Thu Jan 24, 2002 6:06 am
Do you have a job and could pay for your flight training? I was lucky enough to have my parents help pay for my training, as in a favor loan.
I'm sure someone might have some informaion on this and if not, I suggest asking your flight instructor or get one if you don't have one.
Kevin/DCA
baec777
Thu Jan 24, 2002 6:31 am
I am also interested. Please show us more details..
5-Ratings Pro Pilot Pkg, AP, PPL, CPL Licenses
baec777
baec777
Thu Jan 24, 2002 6:34 am
baec777
DE727UPS
Thu Jan 24, 2002 8:07 am
Don't worry about stalling and spinning into the ground. You'll learn what to do if the engine quits and how to avoid a stall/spin. The guy on the tape must have screwed up big time or had a structural failure.
You have great visability in a Cessna except in the direction of turn. Maybe this 150 has skylight windows in the ceiling, so you can see towards turns better.
Your 150 has a panel mount GPS. If I were your instructor, I'd make you leave it off most of the time but teach you how to use it, too. I would have you learn how it works on the ground. Trust me...you don't want to be flying around trying to figure out how that thing works. It's important to learn how to use a map and the "old" style VOR's...as well as the new GPS stuff.
Your comments about death are interesting....if you're last words and thoughts are all that important to you...I'd say write a them down and put them somewhere your parents would find them later.
Av8trxx
Stalls: Nothing To Be Afraid Of
Thu Jan 24, 2002 9:28 am
"I would hate to stall the plane I don't see how people crash when they have engine failure can't they just kinda sort of nose dive it to get some lift and set it down in a field instead of spinning?"
As you will soon find out, "stalling" has nothing to do with engine operation (or lack thereof). A "stall" refers to a condition when the flow of air over the wing is disrupted. (In practice, you will do this by intentionally creating en excessive angle of attack). This disruption of the smooth airflow causes the wing to lose part or all of its lifting efficiency. This is when the wing (not the engine) "stalls".
Also, not every stall results in a spin. That is a dramatization. Keep that ball centered and you will do OK! Perhaps you should check out this page where you can read the Pilots Handbook Of Aeronautical Knowledge & the Flight Training Handbook online for free and learn more about stalls and how/why they occur:
http://avstop.com/AC/Index.html
Thu Jan 24, 2002 9:39 am
Written by DE727UPS:
I would personally try your best to show your parents and friends how much you love. Telling your parents you love them and appreciate all they have done for you will mean so much to them.
Iain
USAIRDC9
Thu Jan 24, 2002 11:09 am
Good evening everyone!
Thanks again for the great help!
727-Yeah I was thinking about writing a letter and leaving it somewhere, where it could be easily found at a later date... But right off I could think of anywhere.........
Lain- Well I do not know if you have any siblings but there is a love/hate relationship which some. Yeah sure you say that you hate them when you get mad at them etc but deep down you do care you just wouldnt show it.. I know it my brother is one of my 3 sisters came up to me and was like "I just want you to know how much I love you" I would think either the mob is after them or they are gonna kill themselves.  Smile.... It is just something that doesnt happen here lol. I have some ideas invloving a tape recorder.... (Kinda sounds strange like I expect it to happen)
I know how fast someones life can end. Even though I could more easily die in a car accident its just one of those things it wont happen to me, I'll never die!
Being young like me will make you take risks as I have done in the past.......
YWG
RE: Do It For Free!
Thu Jan 24, 2002 11:14 am
If you live in canada, join the air cadets. They will train you for 7 weeks over the summer for FREE! And, to top it off, they'll pay you $60 a week just to be there! Thats the direction I'm heading Big grin
Contact Winnipeg center now on 134.4, good day.
QFTJT
Thu Jan 24, 2002 11:30 am
Hi Usairdc9,
http://www.cessna150-152.com/
Everything you need to know about the Cessna 150 and 152. The Cessna 150/2 is a great aircraft, which I first soloed in. The same aircraft in the shot below
Click for large version
Photo © Matthew Millsom
Personally, I prefer the Piper Tomahawk as a two seat trainer, despite what Iainhol says. The T-hawk in the shot below, is the one I fly.
And remember, have fun!!!!!
QFTJT
Racers22
Thu Jan 24, 2002 11:40 am
I currently have about 40 hours in a C152 which is very similar to what you will be learning in. In response to your question on the pitch of the plane there is really no exact answer. You will always pitch the plane at the angle which keeps you at Vy or Vx depending on whether there are any obstacles that you need to avoid at the end of the runway. In the 152 that I fly, Vy is 70 knots and Vx is 54 knots. There are many factors that can vary the amount of pitch it can take to achieve Vy or Vx. The first time you solo, it will amaze you how much faster the plane climbs without the instructor in the right seat. The plane will also climb faster in colder air than in warm air. Hope that this helps to answer your question. Any terms that you don't understand will be answered by your instructor when the appropriate time comes. Just remember to have fun!
Thu Jan 24, 2002 1:53 pm
The View from the 150/2 is great. This is the plane you'd want to take some friends sightseeing since the view of the ground is not obscurated.
SophieMaltese
Thu Jan 24, 2002 2:13 pm
This didn't make much difference for me. He told me it wouldn't and it didn't. Could it perhaps be because I live in a more humid climate?
SophieMaltese
Thu Jan 24, 2002 2:17 pm
re: the parental scholarships... I wish I'd decided to learn to fly years ago, maybe I'd have one. Now I have the "I go to work every day" scholarship. It sucks not to be able to fly a lot and it takes longer, but if I waited until I could fly three times a week or more I'd be waiting for a while longer. It may cost more in the long run, but at least I'm flying NOW!!!
strickerje
Thu Jan 24, 2002 2:27 pm
Nice picture Nicolaki, what airport is that?
Very good point about sightseeing, as in a high-wing aircraft, it is easier to see the ground. This also makes VFR navigation easier, IMO, especially if you find yourself often using ground features and landmarks to find your way. Here are a few pictures of my first lesson, btw, which illustrate my point: http://www.strickerje.com/flight.html. Flight training is greatly rewarding, and I'm sure you'll enjoy it once you get over the nervousness of the first few lessons!
-Jeffrey Stricker
Av8trxx
Flight Scholarships
Thu Jan 24, 2002 2:43 pm
Re: Flight Scholarships
Don't expect to find one that pays for your Private. Most want to see commitment, so are only for advanced ratings. There are many out there- if you know where to look, but mostly if you are a female!
Sorry guys, but there are several awards that are just for women only as they are only 6% of this pilot population in the US. So if you are a woman, and are interested in flight training scholarships (i.e. $500, $750, $1,000 awards to assist in getting a rating) send me an E-mail. Usually, the application is based on an essay. I have a list of resources just for female aviators. I personally got $500 for my Commercial, and $2,000 for multi training.
There are very few open to guys. Most are associated with a 4 year university. Most big aviation organizations also give out small awards to help you in getting your ratings. Do a search for "aviation + scholarship" or "flight training scholarship", just like that- enclosed in quotations and see what pops up. This site also has a list: http://www.avscholars.com
QFTJT
Thu Jan 24, 2002 3:09 pm
I got $500 from Qantas for my private pilot licence and I'm still in high school.
QFTJT
USAIRDC9
Fri Jan 25, 2002 1:58 am
QFTJT- How did you get them to give you money?
I talked to John Long the owner of Long Aviation and he said that I could do some odd jobs around there to knock off a few bucks......... I figure if I get a part time time mornings 4 days a week making at least $95.00 a week I will be good. And whenever I have a little bit of extra money from selling something off of Ebay I will take 2 lessons a week instead of 1. I would love to have 4 a week but that is just impossible right now........
I looked over that Cessna website thanks it is great.
and I also looked over Stickerje's it is cool too. Nice pictures that is what I want to do on my flights. I think that I will go and buy a 27 exposure disposable camera every 3-4 weeks and take pictures of each flight t kinda keep a documentary and if I have a good one of the instrument panle I will take it to Kinkos and pay $5.00 to get it blown up 11x17 so I can use it as a sort of study guide..........
QFTJT
Fri Jan 25, 2002 4:51 am
Hi Usairdc9,
My $500 dollars from Qantas was for academic achievements for the year 2000, of Qantas employees, but it sure helps.
It is really important, if you are aiming for the Airlines, to try to work for your flying, if this job is around aircraft, than that's excellent. I work six hours a week getting paid a lousy wage at a supermarket, however I live in a small town in Australia and that is the only job I can get until I finish school this year. I love flying that much that I am prepared to endure that dead-end job until I get my private licence.
I earn only 38AU dollars a week, but I pays for my flying and will get me a airline job in the long run over someone whose parent has paid her/his way. Because my twin brother and I are serious about a flying career my dad bought us a Piper Tomahawk, however we still pay for the instruction and the fuel, which is about $40US per hour
Keep us updated
QFTJT
USAIRDC9
Fri Jan 25, 2002 5:13 am
Hello,
I have 2 motorcycles in NC that I need to sell a 1972 Honda CL 350 and a 1971 Honda CL 350 for $175-$200.00 each which will hopefully get me a big headstart. Once I sell those I will get a job making at least 95 bucks a week which isnt hard to find around my house. I have had 3-4 jobs before but for some reason all of the places being small private restaurants close down  Sad.... My last job which I held for 8 months was at a Carrabbas where my sister was the manager however I quit because it would intefere with my flying and my future career is more important then my little part time job. So I am gonna find one working during the days...... That way I can fly on the weekends and still have afternoons open for friends and girlfriend.........
I would like to have at least $150.00 in my bank account in just in case I need it for flying if I didnt work a week or something like that.........
A friend of my moms husband died in an airplane crash when I was a little baby.
Here is the NTSB report...........
NTSB Identification: ATL88FA066 . The docket is stored on NTSB microfiche number 35452.
Accident occurred Thursday, December 17, 1987 at MONROE, NC
Aircraft:FAIRCHILD M-62A-3, registration: N9132H
Injuries: 2 Fatal.
REPTDLY, THE FLT PURPOSE WAS TO ADMINISTER A BFR TO THE PLT/OWNER OF THE ACFT. THE FIRST TAKEOFF WAS ABORTED. THE ACFT DEPTD AGAIN WITHOUT AN APPARENT PROBLEM. AFTER ABOUT 30 MINUTES, THE APT MGR HEARD AND SAW THE ACFT IN A VERTICAL DESCENT AND ROTATING ABOUT THE LONGITUDINAL AXIS. IT DISAPPEARED BEHIND TREES. THE WRECKAGE WAS FOUND IN A WOODLAND AND THE WRECKAGE SCATTER PATTERN INDICATED AN INFLIGHT BREAK-UP. NO EVIDENCE OF ROT WAS FOUND IN THE PRIMARY WOOD STRUCTURE OF THE AIRCRAFT. IT WAS NOT DETERMINED WHAT MANEUVER PRECEDED THE BREAKUP OR WHICH PILOT WAS OPERATING THE FLIGHT CONTROLS.
The National Transportation Safety Board determines the probable cause(s) of this accident as follows.
DESIGN STRESS LIMITS OF AIRCRAFT..EXCEEDED
Contributing Factors
MANEUVER..ATTEMPTED
DE727UPS
Fri Jan 25, 2002 8:12 am
Dude....I bet your mom is freakin about you taking lessons. I don't know what kind of plane that is in the above report.
