bluewhite
Aircraft Speed
Fri Jan 25, 2002 10:38 pm
A bit technical but am I correct in thinking that the larger aircraft (B747,B777) come in on approach, at a lower speed than, say a B737-200.
I remember a recent trip when the Olympic B732 seemed to be very fast (but smooth) on approach, but something like a B777-300 just "drifts" in for miles and miles.
Can someone confirm this for me as just perception or reality??
BW
LY744
RE: Aircraft Speed
Sat Jan 26, 2002 12:31 am
Isn't it the other way around??? Anyways go to http://www.britishairways.com/flights/factfile/airfleet/airfleet.shtml It's BA's fleet page, click on a/c to see detailed info, including landing speed.
LY744.
seagull
RE: Aircraft Speed
Sat Jan 26, 2002 12:53 am
It's the other way around.
456
RE: Aircraft Speed
Sat Jan 26, 2002 1:23 am
It looks like that a larger aircraft comes in at a lower speed, but that is because it's size is so large.
Compare it with a fast flying fly. It seems it is going really fast, but when you run, or cycle, you will go at a same speed, and it seems not you are going that fast.
apuneger
RE: Aircraft Speed
Sat Jan 26, 2002 2:29 am
A bigger aircraft weights more, hence the higher approach speed.
But it's true, a bigger aircraft appears to fly slower because of its size...
Ivan
Ivan Coninx - Brussels Aviation Photography
bluewhite
RE: Aircraft Speed
Sat Jan 26, 2002 3:55 am
Thanks guys, I forgot that everything's relative (well, at least according to Einstein) and my elementary Physics!
BW
