AceVentura
How To Listen The Atc?
Mon Feb 04, 2002 3:03 am
Can I listen somehow to the ATC - excluding by the Internet??
donder10
RE: How To Listen The Atc?
Mon Feb 04, 2002 3:07 am
Yes you can
AceVentura
Mon Feb 04, 2002 3:13 am
How
flightsimfreak
Mon Feb 04, 2002 3:54 am
Go to radio shack and buy a scanner
LY744
Mon Feb 04, 2002 4:56 am
I don't think they have "Radio Shacks" in Bulgaria, FlightSimFreak.  Big grin
LY744.
NZ767
Mon Feb 04, 2002 7:04 am
Yep,
Get yourself an Air Band scanner.
I used to have a Uniden Bearcat before it got pinched and before that I used to just simply use short wave on a normal radio.
Only trouble with that was that it was unreliable and I could only hear one half of the conversation, ie: ATC and not the pilots reading back.
You also need to know the frequencies of the ATC services that you want to listen to (unless they make scanners now that can seek those out for you-I don't know!).
Also, check whether it not it's legal to listen to them in Bulgaria, it may not be.
Mike (NZWN)  Smile
VirginFlyer
Mon Feb 04, 2002 8:52 am
If you get a scanner, you will need to know frequencies. I use http://worldaerodata.com to find them.
V/F
Having trouble with a malware spam popup advert on A.net mobile site? Share details at viewtopic.php?f=12&t=1363111
"So powerful is the light of unity that it can illuminate the whole earth." - Bahá'u'lláh
ILS
Mon Feb 04, 2002 8:57 am
All aviation frequencies are from 108-roughly 136.75 MHz. Visit http://www.airnav.com for frequencies at your local airport.  Big thumbs up
VirginFlyer
Mon Feb 04, 2002 10:00 am
ILS - as airnav is only for the USA, I doubt it will be of much for someone in Bulgaria...
V/F
Mon Feb 04, 2002 10:19 am
Get yourself an AOR scanner....
They can pick up Military, and since they are not made in the USA, can pick up cell phones.
http://www.aorja.com/
http://www.durhamradio.ca/aor.htm
http://n7olq.home.att.net/Radio/ARscanner.htm
http://www.aorusa.com/
They also pick up military. Aerial refuelings etc... Would suit you well over there where all the action is. I know in that area, the US refuels a lot of aircraft and you can listen in.
