Dardania
Re: Airbus A330neo Production And Delivery Thread
Wed Oct 11, 2017 6:22 am
So what is this paint for - is it a defined pattern that you can photograph air against? Or is the paint more a type of gel that moves with airflow?
StTim
Wed Oct 11, 2017 6:50 am
This - "Or is the paint more a type of gel that moves with airflow?"
WIederling
Wed Oct 11, 2017 7:58 am
VirginFlyer wrote:
Well this puts paid to the comments that come from time to time that the -800 won't be built!
Radio Yerevan:
In principle, yes, but ...
Murphy is an optimist
george77300
Wed Oct 11, 2017 10:40 am
WIederling wrote:
Radio Yerevan:
Well with only 8 orders it seems mad to go ahead. They cancelled he A358 because of low orders too.
A306 A313 A319 A320 A321 A332 A333 A343 A345 A346 A388
B712 B733 B734 B735 B738 B742 B744 B752 B763 B772 B77E B773 B77W
AT75 AT76 C208 P46T SR20 SR22 TBM8
BA EI EK EY FR GT IG JQ KX PG PW QF QR SQ TG TP U2 UA VS WY ZB
parapente
Wed Oct 11, 2017 11:18 am
Well for better or worse it is being built and will be finished soon enough.Yes it can for the basis of a next gen' MRTT and cargo a/c.But perhaps more importantly (for effectively no cost) it gives them a competitive a/c in this space whether it be long thin routes or the 'top end' of MOM.Basically a 788 competitor I suppose.
Without it Boeing have no competition in this space.Although long term both a/c will be made fairly redundant if the 797 ever happens.But would cover the next decade roughly I guess.
WIederling
Wed Oct 11, 2017 12:53 pm
Airbus seems to have decide not to do the A358 though they had an acceptable number of orders for the type.
(guesswork: mostly hold overs from the A350Mk1 which also had an acceptable number of orders back then.)
Then they started moving their customers to other models. Be that 359 or one of A332/3/8/9.
KarelXWB
Wed Oct 11, 2017 1:13 pm
MSN 1795 just completed a RTO.
Polot
Wed Oct 11, 2017 1:32 pm
Airbus was probably doing the math as the specs on the A350 became more concrete as development progressed and realized that that "acceptable" number will likely not grow and instead shrink as airline's start to do their own math once provided with the updated numbers.
KarelXWB
Wed Oct 11, 2017 2:27 pm
KarelXWB
Wed Oct 11, 2017 3:17 pm
KarelXWB
Wed Oct 11, 2017 4:09 pm
Video of the A330neo RTO in action:
https://www.youtube.com/watch?v=a3mdyTPWtyA
WIederling
Wed Oct 11, 2017 4:43 pm
Interesting that they already applied it before First Flight.
i.e. FF will be "right into the middle of programme work".
boefan
Wed Oct 11, 2017 5:09 pm
Does anybody else noticed that TAP Portugal now has 10 A339neo on order instead of 12 in the previous Airbus O&D sheet ?
Anyone care to clarify why those weren't viewed as cancellations ? Maybe they decided to own 2 frames less and lease them perhaps ?
http://www.aircraft.airbus.com/market/o ... eliveries/
KarelXWB
Wed Oct 11, 2017 5:12 pm
TAP arranged a lease deal with lessor ALC.
airzona11
Wed Oct 11, 2017 6:46 pm
A330 is a good looking plane. Those larger engines "shrink" the look in eye. Looking forward to seeing it in airline paint.
Tedd
Wed Oct 11, 2017 10:19 pm
Thanks Karel for the vid. I noted as the engines spooled-up, that the paint or gel applied to the rear of the fuselage, & perhaps up under the wing on the left side was blown down on to the runway
giving the desired result hopefully. I noted also the decent turn of speed too!
Channex757
Wed Oct 11, 2017 10:57 pm
We keep going back here so here's a little bit of the story.
The A330-800 is basically an A330-200 with a few tweaks. It therefore isn't a high-cost addition to the lineup for Airbus.
The A350-800 is a whole different animal. The carbon fibre panels are substantially different to those on the A350-900, and that means lots of extra costs and testing needed. There isn't an existing aircraft to grandfather off either. Spirit make the central roof panel on the A350, and the A358 would have been a long lead item for them as not only the length but also the layup and thickness of the CF was different on the A358. It had different forces acting upon it so needed to change. That's just one section, one part.
This just doesn't apply to the A338 which is an existing, metal bodied aircraft and won't cost Airbus anything like as much to offer.
WIederling
Thu Oct 12, 2017 7:40 am
You think they applied the goo for just the RTO? Thanks, I hadn't made that mind step.
Dardania
Thu Oct 12, 2017 7:49 am
Maybe there is some aerodynamic parameter they wanted to observe at the speed before a RTO?
Tedd
Thu Oct 12, 2017 9:56 am
WIederling wrote:
giving the desired result hopefully. I noted also the decent turn of pespeed too!
I can't be sure it was only applied for the RTO, since they may have been experimenting with the "goo" during engine testing, but there was a lot of the stuff blown down on to the runway which lead me to believe it was at least reapplied for the RTOot.
I do like this plane. I was always a fan of the A330ceo, having flown in it many times. There's been a fair amount of criticism about the path chosen by AB to extend it's life & to give it extra ability to take sales from the B787, but i believe it was the correct course to take, especially since it was a low risk decision. Not every airline needs, wants, or can afford the "best" i.e. B787. In the highly competative airline industry, & not forgetting the depressed WB market at this time, IMHO the Neo could be attractive to many airlines looking for lower initial cost, very decent economics ( to be confirmed after flight testing ) & well proven, reliable airframe. I think the airlines should be extra pleased that AB went ahead with the Neo. Even if most don't choose it, the fact that it's given them a choice is terrific for the industry. I hope AB are rewarded in their investment.
scbriml
Thu Oct 12, 2017 9:57 am
V/F
Some are still in denial. :sarcastic:
Slash787
Fri Oct 13, 2017 11:12 am
Does anyone have the flight deck photos, if anyone has then please post them.
Polot
Fri Oct 13, 2017 11:14 am
I don’t think the A330neo flight deck is any different from the A330ceo flight deck.
NZ321
Fri Oct 13, 2017 1:21 pm
scbriml wrote:
V/F
But hasn't Airbus already announced that they are beginning assembly of the A338? So in that case it will be built. Whether it will sell is another question.
Plane mad!
NZ321
Fri Oct 13, 2017 1:22 pm
Further to the above, I think Airbus talked about fabrication of parts for A338 not assembly yet.
Plane mad!
VirginFlyer
Fri Oct 13, 2017 2:46 pm
NZ321 wrote:
scbriml wrote:
V/F
To answer your question, I'll direct your attention to the two posts I quoted when I said "Well this puts paid to the comments that come from time to time that the -800 won't be built!", on the previous page of this thread:
KarelXWB wrote:
Pre-assembly of the first A330-800 (MSN 1888) is well advanced:
http://www.airbus.com/newsroom/photo-gallery.html
KarelXWB wrote:
A330-800 wings in pre-production:
V/F
It is not for him to pride himself who loveth his own country, but rather for him who loveth the whole world. The earth is but one country, and mankind its citizens. —Bahá'u'lláh
mjoelnir
Fri Oct 13, 2017 2:53 pm
Airbus is talking about starting final assembly of the A330-800 in the end of this year, in about two month.
ap305
Fri Oct 13, 2017 4:18 pm
http://www.reuters.com/article/us-malay ... SKBN1CI1JA
Malaysia Airlines is watching the testing of the Airbus A330neo due to enter service next year as it evaluates an order for around 30 long-haul aircraft, CEO Peter Bellew said on Friday
Racing, competing, is in my blood. It's part of me, it's part of my life; I've been doing it all my life. And it stands up before anything else- Ayrton Senna
TranscendZac
Fri Oct 13, 2017 7:16 pm
I know it’s not shiny and new like the 787s but the A330NEO looks fantastic. I just wonder, as the capability is increased, does it make less and less sense to buy an A330 vs the A350? Or even a 787?
Zac
Slug71
Fri Oct 13, 2017 11:46 pm
Can't speak for the 787 but the A350 will be fine. The A330 is about at it's limit now as far as it's MTOW and what the landing gear can take. The A350 will likely get a couple more at least and is already a fair bit higher.
flee
Sat Oct 14, 2017 2:49 am
Airbus can probably think of incorporating the A340's centre undercarriage if it wants to raise MTOW even more than the proposed 251t. They may also need to raise the Trent 7000's thrust.
As the A350's MTOW is raised in future, it gives room for the A330 to raise its MTOW and still not compete with the A350.
Someone83
Sat Oct 14, 2017 7:50 am
But that would also add weight.....
flee
Sat Oct 14, 2017 7:59 am
That will be a big decision to take as it does change the dynamics of the aircraft and its capabilities. It will also require some more investment from both Airbus and RR. I am not sure if we are at that stage yet. Maybe it is still another 2-4 years before Airbus needs to look into this - assuming that the Neo is still a viable proposition for airlines to buy.
mjoelnir
Sat Oct 14, 2017 11:56 am
I do not think that the landing gear limits the A330 to 242 t. If we compare the A330 main landing gear to the 787-9/10 landing gear, we will find the same size tires, 54x21-R23. Regarding the foot print, the bogie on A330 has a track of 1.397 m and a wheelbase of 1.981 m. The 787-9/10 has 1.52 x 1.51 m, that is rather a smaller footprint. The 787 is able to reach an MTOW of 254 t, so I assume the A330 should also be able to reach 254 t in regards to the MLG.
I assume the A350-900 is about maxed out at 280 t MTOW with its big 4 wheel bogie. Tires are are about the same size, but the footprint is large at 1.735 x 2.04 m.
Even if the MTOW of the A330 will be raised to 251 t, that would not impinge on the A350-900. The A350-900 is simply the next size up, bigger and more capable.
Polot
Sat Oct 14, 2017 12:22 pm
That is assuming the MTOW limitations with regards to the landing gear solely come down to pavement loading.
JeremyB
Sat Oct 14, 2017 5:00 pm
The A330 has the same gear as the A340-200/300 right? (minus the center gear) they should be able to go to 251T, but that is probably the maximum weight the current gear can handle.
SQ22
Sat Oct 14, 2017 5:51 pm
Please stay on topic, feel free to open a new thread on future capabilities and necessary fixes to achieve that.
KarelXWB
Sun Oct 15, 2017 9:33 am
Photo of MSN 1795 during its RTO last week clearly shows the size of the engine and pylon:
fwwtn_5576 by Eurospot 1 Million views in 1 year, Thanks, on Flickr
Tedd
Sun Oct 15, 2017 10:07 am
Nice pic Karel, cheers. You can see the pylon is hanging the Trent 7000 quite high in relation to the wing, probably as
high as I`ve ever seen before. It`s great to see this terrific aircraft given the latest in engine tech for the thrust range, to
give it the best possible chance in the market. Although this plane should fly in the next few days, we`ll have to wait to
hear from B787 ( Trent 1000-TEN ) operators to see if this engine delivers on expected gains promised by RR. This
engine should be imminent in it`s introduction on the Boeing after a fair delay, if indeed it does deliver said gains the
A330 Neo will be the biggest beneficiary.
hotelbravo
Mon Oct 16, 2017 12:22 pm
Yes, it's mounted high for sure but the slats are down making it look like the wing starts lower down. In fact, I think 73M, 77W and 787 engines are all mounted higher with respect to the wing (in clean configuration) than the 330neo.
Tedd
Mon Oct 16, 2017 12:35 pm
Yes, thanks for that, I can see you are correct for sure. My cursory glance missed the slats being down.
It`s a great looking aircraft IMHO, can`t wait to see it in the air.......hopefully this week!
KarelXWB
Tue Oct 17, 2017 1:05 pm
MSN 1795 just completed a high speed RTO.
maortega15
Tue Oct 17, 2017 4:12 pm
Will those engines sound more like the 700 or more like XWB?
Always loved the sound of the 700. Start-up, spool-up even the howl and grind.
Most Trent engines after the A346 don't seem to have that characteristic of the infamous RR "howl" and "grind" anymore.
ikolkyo
Tue Oct 17, 2017 4:17 pm
Should be similar to Trent 1000
Slash787
Tue Oct 17, 2017 4:22 pm
So well 2 days to go
Tedd
Tue Oct 17, 2017 10:38 pm
If you want to hear those Trent 7000 engine now, just go back up this thread to reply #611, Karel posted
a YouTube vid of a recent RTO. They sounded ok to me! ( Haven`t posted here for you as I`d probably need permission ).
WIederling
Tue Oct 17, 2017 10:46 pm
I'd be interesting if the 787 with T1000TEN and chevroned nacelle
and the clean A330 NEO with T7000 in its nacelle show a difference in sound ( and noise levels ).
maortega15
Tue Oct 17, 2017 11:45 pm
Well, you can hear a noticeable grind, but not the howl.
maortega15
Tue Oct 17, 2017 11:47 pm
I'm curious to know how it sounds up close from a passenger perspective. You can still hear a grind, but not a howl when applying thrust.
