iahcsr
Re: United Fleet Upgrade Status - 2017
Mon Oct 09, 2017 7:45 am
A320s from where sir? And any reg# info? :bouncy:
calpsafltskeds
Mon Oct 09, 2017 2:47 pm
73G:
N15712 is returning back to GUM w/o configuration change after Maint in HOU- was thought it was to become domestic
738:
N76529 entered LCQ 2772/9Oct, slimlines?
N79541 new dlivery, first revenue flight 1827/8Oct EWR-SAN
aircraft has PDE/slimlines/ISP F/E+/space bins/split scimitars
sites.google.com/site/unitedfleetsite/
calpsafltskeds
Mon Oct 09, 2017 7:43 pm
You would think 2 A320s would have registrations reserved. N450UA and N499UA are the obvious numbers. N450UA was a UA s320 years ago, but that unit is now flying for Iran Air
Both numbers are paid, but don't have aircraft attached to the number.
Maybe there will be another series of fleet numbers.
calpsafltskeds
Mon Oct 09, 2017 9:02 pm
744 Retirement:
N119UA fleet exit 2791/9Oct SFO-VCV
9 744s remain - all to exit by Thanksgiving 2017
VC10er
Tue Oct 10, 2017 12:40 am
Not quite on topic right this moment, but has UA spoken about the long term plans for the 757-300s? My friends in SF HATE that aircraft due to it's length and let out a moan every time they get one. They asked me what is going on with them because they know I am an A.nutter and UA FF. But, I think they are going to be around for a while and due for the new domestic First Class seat eventually and Y. But will the 737 MAX 10 take over many of their routes? Thanks!
To Most the Sky is The Limit, For me, the Sky is Home.
ikolkyo
Tue Oct 10, 2017 12:48 am
No one really knows what the MAX 10 is gonna be doing but a betting man would say it would be operating on current -900ER routes and could be used to add capacity on routes with a lot of frequency and just operate around the domestic routes. I also could see the aircraft taking over P.S duties. The 753s will be around for awhile, no retiriement for them anytime soon.
atcsundevil
Tue Oct 10, 2017 12:55 am
They'll be around for a good, long while. They are still fairly young (2001-2005 builds IIRC), so they've got at least another ten years, maybe more. They've got excellent CASM, so that's definitely an appealing factor for the airline.
I think if they receive new seats and a cabin update, they'd be a little less hated. They were slow to get DTV on the half of the fleet that did receive it, then slow to get in seat power (still one more to go), then slow to get WiFi, then slow to get PDE. All of that is a byproduct of the routes they generally ply, which is usually full of Basic Economy fares headed to Disney World. Unfortunately they do take a lifetime to board/deplane. They're best suited for flights to Florida, but UA has put them on a lot of transcons (especially from SFO-EWR) post-merger. With more domestic 772s coming into the mix, I was hoping all of those 753 rotations would switch up to the 772, but I'm not sure that's happened.
Long story short, those things print money on the right routes, so they ain't going anywhere for a long time.
UnitedTristar
Tue Oct 10, 2017 2:35 am
CALTECH wrote:
calpsafltskeds wrote:
STT757 wrote:
Any update on acquiring the A320s?
Scheduled for delivery Oct and Nov '17.....
Where they coming from? Used I’m assuming?
-m
intotheair
Tue Oct 10, 2017 3:16 am
The thing to remember too is that the MAX10 is not significantly bigger than the -900s. At most, the MAX10 will have 12 more seats over the -900s and MAX9. That's still 22 fewer seats than the 753s, assuming the 753s remain in their current configuration and aren't ""densified"" further. I think you're right that the MAX10 will end up on the routes that see the -900s today. 753s will probably continue to be the oddball combination of mid-con low-yield Florida hauler and mid-to-transcon high density routes that aren't p.s.
300 319 320 321 332 333 345 346 717 733 734 735 73G 738 739 744 752 753 762 763 772 CR2 CR7 CR9 Q400 E175 DC10 MD82 MD90
AA AF AS AY AZ B6 BA BR DL F9 FI GA HA KF LH MI QX SK SN SQ UA US VY WN
calpsafltskeds
Tue Oct 10, 2017 3:48 am
I'm sure many won't like this but, the 753 is going to start real soon with slimline seats, which will add 21 seats in Y. Probably see a lav removed and seat pitch go down to 30" in Y and 34" in E+.
They are good aircraft for Hawaiian flights with the low CASM. Also used on hub to hub flights and MCO a lot.
MAX 10 should be a good Hawaiian aircraft as well along with transcon and flying around domestically on heavier demand routes/flights.
VC10er
Tue Oct 10, 2017 9:23 pm
The 753s don’t do ps EWR/SFO do they, really?
Does F have many more domestic F seats than other single aisles?
Gosh I really am not fond of them either but I guess they would be cash generators? What’s it maximum range?
adamblang
Tue Oct 10, 2017 9:41 pm
753s aren't scheduled between EWR and SFO as all EWR-SFO flights have lie-flat up front and no 753s have lie-flat up front.
146 319 320 321 332 333 343 717 734 735 73G 738 739 744 752 753 763 764 772 773 789 AR1 AT4 CNA CR2 CR7 DC9 ER3 ERD ER4 E70 E75 E90
atcsundevil
Tue Oct 10, 2017 9:50 pm
They used to run that route frequently (multiple times daily), but that was before the p.s. switch from JFK to EWR and making all flights between the markets lieflat. I wasn't sure if that had actually occurred yet, but clearly that's the case. These days, the 753s fly mostly to ORD, but I don't think that it operates from SFO nearly as much as it used to.
hkcanadaexpat
Wed Oct 11, 2017 3:06 am
763 (2-class):
N661UA entered SFO 1584/10Oct for maintenance
N671UA exited SFO 212/10Oct for engine pylon inspection
calpsafltskeds
Wed Oct 11, 2017 6:23 am
73G:
N27733 entered IAH 833/9Oct, slimlines?????
738:
N76529 exited LCQ 2777/9Oct w/o slimlines
739:
N38467 sked to exit LCQ 2695/11Oct with slimlines/scimitars
aaflyer222
Wed Oct 11, 2017 3:25 pm
q200 n366ph is at YHZ for exit prep. 14 q200 remain.
74m, 772, 763, 764, 752, 733, 734, 738, 739, a319, a320, a321, s80, m88, m90, e190, e170, e175, e140, e145, cr2, cr7, cr9, dh1, dh3, dh4, at72, s340
klwright69
UA Polaris Tracking Thread
Thu Oct 12, 2017 9:06 am
I am aware of the longstanding UA fleet update thread.
I would like to propose a thread committed to the rollout of United Polaris.
How many aircraft currently have Polaris?
What routes do they fly?
There is a 767-300 with the Polaris configuration. During the last few weeks it has been flown to LHR, TXL, and HAM.
Where is it now?
Today, a 777-300 is on EWR-SJU for a couple days. Why is this?
FoxtrotSierra
Re: UA Polaris Tracking Thread
Thu Oct 12, 2017 9:37 am
What's the current timeframe for 787's?
klwright69
Thu Oct 12, 2017 9:39 am
Also CNN recently featured Richard Quest doing a segment on Polaris. He interviewed Oscar. Apparently, the Polaris lounges are already proving to be too small. They must be made larger, which will further delay the rollout.
https://hub.united.com/united-polaris-c ... 75323.html
http://edition.cnn.com/videos/travel/20 ... aris-a.cnn
atcsundevil
Thu Oct 12, 2017 10:20 am
Where is it now?
The United Fleet Thread these days is almost primarily a discussion on Polaris. Having a separate topic would badly split the discussion. While I would support regular Polaris specific updates, I don't feel that the discussion should take place separately from this thread, when that is the primary discussion of the United Thread.
cosyr
Thu Oct 12, 2017 12:51 pm
Where is it now?
Especially since this thread has been going so long it was previously keeping track of the IPTE and sCO Diamond seat installations. Just like following cars, we seem to have followed an entire generation from design to replacement design.
ordpark
Thu Oct 12, 2017 12:59 pm
Yeah...I'm getting a little tired of reading about seats......I mean, really, it's Chairs in the air!
audidudi
Thu Oct 12, 2017 2:25 pm
Where is it now?
Already started in reply #1375 above! All the aircraft/flights can be tracked on FlightAware and FlightRadar24. Here is the tracking of N644UA:
http://flightaware.com/live/flight/N644UA
iahcsr
Thu Oct 12, 2017 3:17 pm
Where is it now?
664UA has also done a few EWRHNL on occasion and is currently planned for a BCN turn.
77W to SJU is mainly to fly in as many hurricane relief supplies and as many passengers out as possible. Puerto Rico is still very very much a mess from Irma and it will be some time before things are back to anywhere near what could be considered normal.
iahcsr
Thu Oct 12, 2017 3:25 pm
UA has 12 788s and 21 789s in service. The last four 789s will come by Jan’18 7810s will start sometime next year. These will be the first to have the Polaris seats.
AVENSAB727
Thu Oct 12, 2017 3:40 pm
2 of those 4 upcoming 789s will likely fly the new IAH-SYD route launching that same month.
Always look on the bright side of Life!
CriticalPoint
Thu Oct 12, 2017 4:39 pm
The 787-9 used on SYD will rotate through LAX with a IAH-LAX-IAH leg. Those new 787 will not be assigned solely to any base, but yes they will end up doing SYD-IAH at some point in their lives.
boilerla
Thu Oct 12, 2017 5:09 pm
This showed up in the thread about LH buying AirBerlin's assets:
viewtopic.php?f=3&t=1376017&start=50#p19880951
It’s possible LH does not keep the entire fleet. Rumor is that United will very soon announce a transaction for 30-40 used airbus aircraft to enter the fleet.
:stirthepot:
LAXintl
Thu Oct 12, 2017 5:45 pm
737MAX-9 config will be 20/165.
Internal aircraft code 73X which is pretty dumb as X=10 and should have been kept for the MAX-10.
ikolkyo
Thu Oct 12, 2017 5:49 pm
Managed to add another row of Y, Looks like the -10 is gonna need to have the aft wing exit doors activated to seat over 189 passengers.
cosyr
Thu Oct 12, 2017 5:51 pm
:stirthepot:
It's possible that with 30-40 it could make sense, but I don't know why they would want to introduce a new engine type for a subset of one of their smaller fleet types to begin with.
iahcsr
Thu Oct 12, 2017 6:14 pm
:stirthepot:
I dare say UA is quite familiar with the CFM 56 engine, it won’t be a problem I think.
For fleet #s 43xx, 44xx, 45xx, 49xx are all available.
CONTACREW
Thu Oct 12, 2017 6:31 pm
Flight Attendants prepare doors for departure, cross check verify straps standby for all call
audidudi
Thu Oct 12, 2017 6:40 pm
Where is it now?
I assume you meant N644UA, as N664UA doesn't have the Polaris interior yet!
cosyr
Thu Oct 12, 2017 7:20 pm
iahcsr wrote:
:stirthepot:
I understand that maintenance are familiar with the engine, but I doubt there are many shared parts between the 3 series and the 5 series. That is a logistical complication, so UA would have to be getting a really good price to offset the additional complexity.
cosyr
Thu Oct 12, 2017 7:27 pm
CONTACREW wrote:
Seat map for 73X:
https://mobile.twitter.com/BrianSumers/ ... 80/photo/1
According to that photo, I'm only counting 159 Y, although I don't see the point of a different Y+ config compared with the 739.
ikolkyo
Thu Oct 12, 2017 7:33 pm
CONTACREW wrote:
Seat map for 73X:
I also see 159 Y
Coalways
Thu Oct 12, 2017 7:40 pm
I thought the 737 max10 was automatically going to have the aft wing activated as standard no matter who was the operator?
ordbosewr
Thu Oct 12, 2017 7:42 pm
It goes back to the same point that was made in the thread about the changes in the A350 order size. At a fleet size of 40 commonality (if I recall 40 was what kirby said about the A350), with the remainder of the fleet. 40 becomes big enough to justify it's own world. It could also be that they can isolate these to specific hubs to reduce that cost (ie parts/spares/etc).
ikolkyo
Thu Oct 12, 2017 8:11 pm
I could see that happening but if the aircraft is going to be used in a more premium configuration it’s not necessary.
cosyr
Thu Oct 12, 2017 10:05 pm
Except that the A350 will go through a select set of predictable airports worldwide, many flying no more than 2 flights a day. A320's get mixed in through more than 100 destinations across the US, and have far more rotations. 30-40 is a large set of widebodies, but a small set of narrowbodies.
iahcsr
Fri Oct 13, 2017 1:24 am
ikolkyo wrote:
CONTACREW wrote:
Seat map for 73X:
I also see 159 Y
Same, 159.... the 165 would more likely be for the Max10
adamblang
Fri Oct 13, 2017 2:43 am
CONTACREW wrote:
Is this a credible tweet? The style of the image looks different than every other seat map image I've seen come out of United. The style across the desktop website, mobile website, app, GIDS are pretty consistent and this does not match.
calpsafltskeds
Fri Oct 13, 2017 3:08 am
CONTACREW wrote:
Seat map for 73X:
Vs. 739, 12 and 14 DEF are E+ where they are Y on the 117Y 739 version. Everything else looks the same - galleys, lavs. So 6 more E+ seats and 6 fewer Y seats.
Since the 737MAX10 is 66 inches longer than the 737MAX9, you'd expect all of theat would be floor space and allow one row in front and one behind the wing exits will be added. That is unless it goes to 24F or lavs are added, which I highly doubt.
mmahpeel
Fri Oct 13, 2017 2:19 pm
Everything I'm seeing including what has been loaded into the flight attendant manuals is a configuration of 20/159.
mmahpeel
Fri Oct 13, 2017 2:21 pm
adamblang wrote:
The image is legit and from an internal reference you wouldn't have access to unless you were crew for UA.
calpsafltskeds
Mon Oct 16, 2017 2:35 pm
744:
N121UA - Still operating customer flights, flew SFO/LHR/SFO 2 days ago
73G:
N27733 exited IAH 1781/11Oct, no slimlines
738:
N78438 entered RFD 2997/9Oct, probable slimlines
752:
N17128 - SAT as of 14-Sept/2812, probable scimitars at new SAT MRO
N33132 - Entered RFD 2-Oct/2798, scimitars, exited 2812/15Oct
753:
N75851 - SAT as of 10-Oct/2798, possible slimlines
772:
N226UA exited HKG 2782/13Oct
Updated delivery status from Boeing.
789:
N29971 expected delivery date 1 Dec 2017
N24972 expected delivery date 1 Jan 2018
N24973 expected delivery date 1 Feb 2018
N24974 expected delivery date 1 Feb 2018
This will finish off all ordered 787-9s
CR2:
N455AW (2003 build) entered service with Air Wisconsin dba UAX
VC10er
Mon Oct 16, 2017 4:35 pm
Was it really so impossible to get Polaris onto those last 4 787-9's?
atcsundevil
Mon Oct 16, 2017 5:37 pm
From what I understand, those seats have about a two year lead time. Certain things are locked in far in advance, and it probably didn't happen soon enough for these birds. I'm sure UA would love for there to be another way, because I'm sure they don't want to pay for seats that will only be used for a couple of years, but that's the way it goes.
FlyHossD
Mon Oct 16, 2017 6:01 pm
Think about it this way, it will cost UAL more to retrofit the planes with Polaris than to have them delivered with it. So yes, I'd say that it wasn't possible to get Polaris installed before delivery.
