VC10er
Re: United Fleet Upgrade Status - 2017
Tue Oct 31, 2017 5:39 pm
atcsundevil wrote:
VC10er wrote:
I know that the 3 Class sUA 767s are going in First for Polaris refits, but then the rest of the 2 Class 767s after...correct?
No. Already converted two class 763s are staying as is. Those cabins are maybe only two or three years old, and at most they'll only be around until the middle of the next decade. When Polaris seats likely cost in the range of $200,000 or more per seat, there's no way to justify that cost.
OMG! I didn’t realize that. So the same goes for the 772?
I’m surprised only because I’m not sure those 2 class 767s seats will last...they already show signs of wear and tear!
To Most the Sky is The Limit, For me, the Sky is Home.
adamblang
Tue Oct 31, 2017 5:40 pm
No.
adamblang wrote:
United's Polaris site has been updated with a few not-too-notable developments:
There's a progress tracker that says 14 763s will get refit (so only the current 3-cabin 763s) and 55 772s will get refit (so all sUA and sCO 777-200ERs): http://view.ceros.com/united/polaris-tr ... ktop-4/p/3
763s are to be completed by the end of 2018; 772s will start being refit in "early 2018" with no published end date.
146 319 320 321 332 333 343 717 734 735 73G 738 739 744 752 753 763 764 772 773 789 AR1 AT4 CNA CR2 CR7 DC9 ER3 ERD ER4 E70 E75 E90
VC10er
Tue Oct 31, 2017 5:49 pm
Thanks for that link! Was I the only one who was under the impression that one day ALL 767s would have new Polaris seats (just the 14 3 Class ones first)?
adamblang
Tue Oct 31, 2017 6:58 pm
I was under the same impression. Was a little surprised the current two-cabin aircraft will solider on.
iahcsr
Wed Nov 01, 2017 1:43 am
Of course if Boeing does in fact build new 767s for UA, those 2 class aircraft will most likely be the first to go. : :crossfingers: :crossfingers: :crossfingers:
..but as luck would have it, 14 of the current 2 class birds are the youngest of the bunch being ‘98-‘01 builds and most of the others that will have Polaris ‘91-‘93 :banghead:
Schweigend
Wed Nov 01, 2017 5:51 am
No need to beat your head against a wall!
To me, it also has appeared odd how the oldest ones will get Polaris, while the youngest (seemingly) won't.
If indeed UA does pick up new 767-322ERs from Boeing, those later-built '98-'01 models will easily find homes with various cargo carriers. The older Polaris-converted frames will fly on with United until their final end.
atcsundevil
Wed Nov 01, 2017 9:48 am
Originally the plan was to retire all 763s. Then the plan changed to give the newest 14 life extensions, but the oldest 14 would be retired. About a year after the original 14 were completed (and around the time Polaris became public knowledge), the decision was made to give the older 14 a life extension as well.
The newest build 763s were modded long before Polaris was even known. Unless they were going to be kept for at least another decade (which I doubt, they may start to go at the next heavy check), the cost to upgrade the entire aircraft to match the older 14 being modded now would be pretty prohibitive. Trust me, I wish they would, but even I can't rationalize the cost. It would be throwing millions — potentially even tens of millions — out of the window. That doesn't make sense when these aircraft could very well be reassigned to run p.s. routes or something in a few short years. The cabins are still brand new, they just have an outdated seat. They can't send an aircraft back in for mod if it's unlikely to have even paid off the cost of the last one.
SFOtoORD
Wed Nov 01, 2017 1:21 pm
Any chance that if UA orders new 763s that theyd move the Polaris seats from the oldest 763s to the new ones and then retire the old planes? Are the seats that portable?
calpsafltskeds
Wed Nov 01, 2017 1:23 pm
I surely hope tHe millions to retrofit the 763s includes major rework of labs, coach seats and other infrastructure that equals $200k per Polaris seat. It appears to me that very minor changes to E+ seating pitch would allow Polaris seats ito be installed on the current 2 class units - no Y seat changes, no lav changes, just replace BF seats with Polaris. There would probably be an STC, but $200k per seat is hopefully based on a total retrofit, not just Polaris seats.
So, I believe it would be realistic to swap polaris seats into newer 763 aircraft if and when the older units are sold.
It may make sense to use current 2 class units for ps, hub to hub and Hawaii service if new 763s are purchased. 14 older units with Polaris could be used on LHR service, maybe locking all 14 on LHR service and have spare units in EWR, ORD and LHR to keep the operation running on time.
sites.google.com/site/unitedfleetsite/
VC10er
Wed Nov 01, 2017 1:30 pm
What about new Polaris full mods on the 764s? United doesn’t call them out on their “progress” subsite
atcsundevil
Wed Nov 01, 2017 2:13 pm
They could if they wanted, but it would be a long way off if that were to happen. It would probably be at least a couple weeks worth of mods, especially if walls or lavs need to be moved around. By that point, their strategy with those aircraft may be quite different. Like I mentioned, they could end up running p.s. routes or otherwise operating domestically using the older seats. Fact is, there's nothing wrong with those seats for the stage lengths they're running. They typically operate 6-8 hour routes max. The sCO seat design is certainly adequate, and the seats themselves are only a couple of years old.
If those newer build 763s are going to stick around long term, then they should certainly receive Polaris. However, I would argue that the rest of the longhaul fleet takes priority. The 764s have the same sCO seats, but they're roughly 3-4 years older and will need replacement sooner. The three class 772s need replacement for obvious reasons (even though it'll be sad to see F go), and the two class birds have sCO seats going on a decade old. The 788s/789s have virtually brand new seats, but considering the length of the routes they operate, they need the best product available. Once that's done, if all current 763s are still in service and the newer deliveries will be kept for a while, then I could see replacement being justified.
KVH68
Wed Nov 01, 2017 2:19 pm
I heard from an internal source that United is looking to acquire some used 767-300.
adamblang
Wed Nov 01, 2017 4:34 pm
The three-cabin-to-Polaris 763 mods include new bins in Y, new seats in Y (same seat as existing two-cabin 763s, with signature "leather"), new on-demand IFE (is it like exiting the two-cabin 763s or the 787s? I don't know), new lavs, and I believe new bulkheads:
https://thepointsguy.com/2017/09/united ... ofit-tour/
calpsafltskeds
Thu Nov 02, 2017 12:08 am
73G:
N13716 entered MIA 2697/1Nov for slimlines/new F seats
738:
N76522 entered LCQ 2698/1Nov for slimlines
N76529 entered LCQ 2776/11Oct for slimlines (may have posted this a while ago)
752:
N12116 exited MIA 2809/31Oct with scimitars
763:
N653UA sked to exit SFO 2794/1Nov
N655UA sked to exit SFO 2798/2Nov
772:
N218UA slipped into XMN 2783/19Sep, exited 2775/2Nov
VC10er
Thu Nov 02, 2017 6:02 am
What’s happening to the refits on the existing 737 fleet: mostly the new F seat? I’ve done roughly 10 legs over the past 3 months on UA 737s, they were all 800s & 900s, Y seemed to have gotten the new leather slimlines, but F were all the old uncomfortable seats. When are they going to ramp up F hard product on the 737s?
UAinAUS
Thu Nov 02, 2017 8:36 am
Sadly only the 737-700s are being refurbished with the new F seat. Next fleet after that is the 757-300s. There’s actually been radio-silence on the 738s and 739s. I hoping for a full fleet upgrade but it’s been eerily quiet.
horsepowerchef
Thu Nov 02, 2017 9:44 am
Cmac787 wrote:
767-400 a/c 3052 was damaged at IAD on Thursday. Will be out of service for at least 14 days. Bad enough that they are flying in people from Boeing to look at it.
Ive searched, what happened to this aircraft?
SFOtoORD
Thu Nov 02, 2017 1:16 pm
Have any of the 753s started yet? Will they replace the economy cabin too?
audidudi
Thu Nov 02, 2017 4:26 pm
There's nothing listed on avherald.com, but I'm not sure what their criteria is for reporting incidents to/with aircraft.
redrooster3
Thu Nov 02, 2017 6:25 pm
Beltloader came into contact with the fuselage, huge scratch below the bulkhead compartment
Marry one of us, and you'll fly for free!
Cmac787
Thu Nov 02, 2017 9:33 pm
Significant damage on the underbelly by a beltloader
hkcanadaexpat
Fri Nov 03, 2017 3:39 am
763 (2-class):
N664UA entered MIA 2699/2Nov
KVH68
Fri Nov 03, 2017 11:46 am
747-400
N118UA
SFO-HNL, 10/7, Flight# 0747, 11:00-14:45
HNL-SFO, 10/8, Flight# 2796, 08:00-14:55
fun2fly
Fri Nov 03, 2017 12:27 pm
KVH68 wrote:
747-400
N118UA
That's going to be one hell of a ride! I'm really impressed with UA's efforts on the 747 retirement.
calpsafltskeds
Fri Nov 03, 2017 2:00 pm
One of the farewell videos show that COs first 747 was before UAs and flew ORD-LAX-HNL
I think UA should have flown that route a day before the SFO-HNL flight. ORD-LAX and LAX-HNL are both very important routes that has a storied history for both CO and UA.
audidudi
Fri Nov 03, 2017 3:38 pm
KVH68 wrote:
747-400
N118UA
I assume you mean the flights are on Nov 7th and Nov 8th?
iahcsr
Fri Nov 03, 2017 4:48 pm
audidudi wrote:
KVH68 wrote:
747-400
N118UA
Answering on his behalf, affirmative... typo demon strikes again.
KVH68
Fri Nov 03, 2017 11:08 pm
audidudi wrote:
KVH68 wrote:
747-400
N118UA
Sorry, my mistake. Here is an updated routing
N118UA (8418)
SFO-HNL, 11/7, Flight# 0747, 11:00-14:45
HNL-SFO, 11/8, Flight# 2796, 08:00-14:55
SFO-VCV, 11/9, Flight# 2778, 08:00-09:25
Currently, there is no routing information for N121UA (8421)
VC10er
Sat Nov 04, 2017 6:44 am
Unbelievable. In a way I thought the day would never come although I’ve known all year that she would be gone! As it’s been said “Denial is bigger than just a river in Egypt”
(May have to say that out loud to get it)
CALTECH
Sun Nov 05, 2017 2:54 pm
Not a scratch, skin penetration. Stringers being replaced........photos are nasty.......
The gun is a precious Symbol of Freedom
Criminals are the deadly cancer on American society
Those who believe otherwise are consumed by an ideology
That is impervious to evidence of tyrants who disarm their citizens
calpsafltskeds
Sun Nov 05, 2017 3:28 pm
738:
N79521 entered IAH 2047/23Oct, slimlines?
N76522 entered LCQ 2698/1Nov, slimlines
N76529 entered LCQ 2776/11Oct, slimlines
772:
N206UA entered XMN 2776/2Nov, maint
UAX:
CRJ200:
N432AW (1998 build) entered revenue service with ZW (UAX)
N439AW (2003 build) entered revenue service with ZW (UAX)
N440AW (2003 build) entered revenue service with ZW (UAX)
E145:
N13913 is in for fleet exit prep
N15912 is in for fleet exit prep
redrooster3
Sun Nov 05, 2017 8:00 pm
738:
Those are all SFP -800s, doing a lot of flying to Hawaii from west coast. Do you think the extra 12 seats will add any payload hits? :scratchchin:
CALTECH
Sun Nov 05, 2017 8:28 pm
Ns Gear #....Type..................#..........Mfg SN.....N#...............Fus #....Yr.......Fmr Op
2145.............777-322ER.......045......64989.......N2645U......1548......18......UA
2146.............777-322ER...... 046......64990.......N2846U......1550......18......UA
2147.............777-322ER.......047......64991.......N2747U......1554......18......UA
2148.............777-322ER.......048......64994.......N2748U......TBD.......18......UA
787...............Fus#....Yr......Fmr Op
TBD 787-9...TBD......TBD. CO
TBD 787-10 0731 18 TBD CO
TBD 787-10 0763 18 TBD CO
iahcsr
Sun Nov 05, 2017 10:39 pm
Is this 789 Ship 0974 N24974 LN 663 ? Or an additional new order?
Interesting no Ship or registration info yet on the 78Js.. There’s a good gap Ship#s 0920-0949... we’ll see. :twocents:
CALTECH
Sun Nov 05, 2017 11:21 pm
That should be 0971.......
CALTECH
Mon Nov 06, 2017 12:15 am
738:
N79521 No SlimLine install......
N76522 SlimLine Install........
#4888 in LCQ for Induction......
KVH68
Mon Nov 06, 2017 1:57 am
747-400
N121UA (8421)
SFO-SFO, 11/8, Flight# 2696, 08:00-09:30, (test flight?)
calpsafltskeds
Mon Nov 06, 2017 2:14 am
738:
N76529 exited LCQ 2791/5Nov, first slimline conversion at LCQ
iahcsr
Mon Nov 06, 2017 3:22 am
Ship 0971 is on the CHS FAL, LN642 N29971 .... odd it would show as TBD :confused:
CALTECH
Mon Nov 06, 2017 6:49 am
Slightly old update, it was lumped in with the 2 787-10s.......
calpsafltskeds
Tue Nov 07, 2017 4:50 am
739:
N78438 exited RFD 2692/6Nov with slimlines
N36469 entered RFD 2799/6Nov for slimlines/scimitars
This will complete 739 slimline program.
KVH68
Tue Nov 07, 2017 5:13 am
Update
747-400
N121UA (8421)
SFO-VCV, 11/8, Flight# 2690, 08:00-09:25
iahcsr
Tue Nov 07, 2017 8:01 am
Trying to imagine how a beltloader could do such damage... :crazy:
jetblastdubai
Tue Nov 07, 2017 1:22 pm
iahcsr wrote:
Trying to imagine how a beltloader driver could do such damage... :crazy:
Every zoo is a petting zoo......if you're a man!
iahcsr
Tue Nov 07, 2017 4:35 pm
jetblastdubai wrote:
I imagine the driver received some serious damage as well. Don’t think those things have seatbelts :fever: :faint:
calpsafltskeds
Tue Nov 07, 2017 5:31 pm
Probably did some damage to his/her career.
763:
N670UA sked to exit MIA 2770/7Nov
772:
N781UA exited HKG 2805/7Nov
cosyr
Tue Nov 07, 2017 6:03 pm
Where are said photos?
KVH68
Tue Nov 07, 2017 8:06 pm
As an employee, if I had those photos, I would not be showing them on the internet.
cosyr
Tue Nov 07, 2017 8:46 pm
Seems like some random ground crew has their iphone out whenever anything happens. Otherwise, we would never see any of these situations. Press don't get to go out on the ramp, generally.
AA737-823
Tue Nov 07, 2017 9:20 pm
After a fatality involving a Delta tug driver a couple years ago, I know that we were forced (by OSHA, of course) to install seat belts on any remaining ramp equipment that didn't already have it. At my little airline, we already had them on everything. I'm assuming United was subject to the same draconian OSHA knee jerk.
(I'm certainly a fan of seatbelts, of course... just not OSHA!!!)
