outbackair
Saab 340 loses propeller in flight
Fri Mar 17, 2017 4:30 am
It seems a REX Saab 340 in Australia lost a prop in flight and made a Mayday call before landing safely. We don't often hear of props coming off, do we?
http://www.9news.com.au/national/2017/0 ... -propellor
http://www.perthnow.com.au/news/western ... 4d57bfecb3
Photos on both links above.
Reason: Edited spelling
KTPAFlyer
Re: Saab 340 looses propeller in flight
Fri Mar 17, 2017 4:39 am
Crikey!
Dalavia
Fri Mar 17, 2017 4:53 am
According to the ABC site (link below), which contains a nice close-up photo, the propeller has not yet been found, adding it will become a significant piece of evidence for the enquiry.
http://www.abc.net.au/news/2017-03-17/r ... er/8364218
CXfirst
Fri Mar 17, 2017 6:09 am
Performance wise, probably better one engine performance with the prop completely gone, as there is no drag. However, probably very lucky that the prop didn't cause any catastrophic damage to other parts of the aircraft as it fell off!
-CXfirst
T prop
Fri Mar 17, 2017 6:27 am
Looks like the prop shaft fractured.
VirginFlyer
Fri Mar 17, 2017 6:32 am
Clearly the front fell off.
V/F
"So powerful is the light of unity that it can illuminate the whole earth." - Bahá'u'lláh
DexSwart
Fri Mar 17, 2017 6:58 am
Scary situation handles very well.
Curious how no one has yet to find the propeller.
Definitely good it got away so cleanly.
V/F
:rotfl: :rotfl: :rotfl: :rotfl:
You win best comment for the month!
For any one you non-Aussies, here is the best piece of Australian journalism, ever:
http://youtu.be/3m5qxZm_JqM
Durban. Melbourne. Denver. Hong Kong.
RyanairGuru
Fri Mar 17, 2017 11:56 am
VapourTrails wrote:
It didn't land in a really remote area...
This is just an uninformed guess based on the flight path, but I wouldn't be surprised if it was either in the water or in Ku-Ring-Gai Chase National Park. Not remote per se, but dense forest nonetheless.
Worked Hard, Flew Right
dragon6172
Fri Mar 17, 2017 12:21 pm
All I can picture is the whole propeller zooming past the cockpit as it was suddenly free of the weight it had been dragging thru the air the whole flight.
Phrogs Phorever
SWADawg
Fri Mar 17, 2017 2:24 pm
They're very lucky that the number two prop was the one that departed the Aircraft. I lost a relative back in the 60's on Lake Central Flight 527 when the propeller on their Convair 580 departed the wing and sliced the fuselage in half forward of the wing. The CVR transcript of that crash is truly horrific. Glad this one turned out better and everyone is OK.
My posts are my opinion only and do not reflect the views of Southwest Airlines
nc3rd
Fri Mar 17, 2017 3:11 pm
Lucky it left the airplane completely unlike the E120 that lodged onto the wing in Georgia.
The views written above are mine and mine alone and do not represent any official information from any airline or compan
WIederling
Fri Mar 17, 2017 5:05 pm
going by the ragged holes in the engine enclosure that probably is not how it went :-)
( But didn't some 747 or other loose an engine "the goodbye way" ?)
Murphy is an optimist
Spacepope
Fri Mar 17, 2017 5:47 pm
I was going to make a snarky comment about "Loose" vs. "Lose" but upon further reflection, the word in the title is brilliant comedy. Well played, sir.
tp1040
Fri Mar 17, 2017 6:15 pm
V/F
Wind hit it, one in a million chance, perfectly safe.
F9Animal
Fri Mar 17, 2017 7:37 pm
What did I watch on 9news.com? Competent journalism? The Aussies have informative media! Pleasantly surprised by the way! I concur with another posters statement! Clearly, the front fell off!
I Am A Different Animal!!
FredrikHAD
Fri Mar 17, 2017 10:05 pm
Those "ragged holes" are meant to be there :) Have a look at other photos of 340's and you'll see. The cowling is intact as far as I can tell, albeit a bit dirty...
There have been two 747 crashes (and several incidents, including similar ones for 707's) where engines have "departed" as far as I know. Google "Bijlmerramp" and "China Airlines Flight 358".
Is the broken tube we see on the close-ups the actual drive shaft or a guide tube? I know the drive shaft is hollow and is used also for the hydrualic oil controlling the prop blade pitch, but it seems thin. If it's a guide tube, it almost certainly broke away to the right (in the direction of flight) since the cut is clean on the left edge and not on the right.
/Fredrik
727200
Fri Mar 17, 2017 10:18 pm
I hope this is a mechanical failure and not a maintenance one or else someone is gonna be handing over their license and looking for a job.
WIederling
Fri Mar 17, 2017 10:35 pm
FredrikHAD wrote:
sorry said the hedgehog and backed away from the hairbrush :-)
Swiss cheese.
Why do they have a cowling at all? :-)
iamlucky13
Fri Mar 17, 2017 10:50 pm
There's been a few instances on various models. A B-52 recently lost an engine in the midwest.
Here's a cargo flight from a few years back:
https://aviation-safety.net/database/re ... 20041020-0
Another cargo flight that ended quite a bit worse:
https://en.wikipedia.org/wiki/El_Al_Flight_1862
This is a different model, but was one of the more engine loss events because of the high number of casualties:
https://en.wikipedia.org/wiki/American_ ... Flight_191
outbackair
Fri Mar 17, 2017 11:49 pm
I apologise for not checking the spelling. Unfortunately, it can't be edited. But hey, at least it's a very common error AND I did use punctuation, which seems to be a dying art. If, however, we worried too much about spelling on this site, we would have a battle between those who write in correct English and those to the West of where the language originated!!! :stirthepot:
Kent350787
Sat Mar 18, 2017 12:55 am
Very, very lucky the prop didn't impact the aircraft as it went past. One report I read indicated that the flight crew were in the process of initiating an engine shutdown when it happened, so would have been prepared for the change in thrust, if not the reason why.
My wife hates flying on prop aircraft, and had luckily not seen the news just before boarding a Q400 flight yesterday. She's not looking forward to her next flight in a few weeks time especially when the only direct flight is on a Rex SF340
fiscal
Sat Mar 18, 2017 12:57 am
Now let me think this through - The cockpit is in front of the propellers, and they are going forward, so does that mean that this Australian airline has used boomerang propellers so that the pilots can see it zoom by when it falls off? :D
qf2220
Sat Mar 18, 2017 1:20 am
1. Other local reports were saying that it was a Pan pan, not a mayday that was called.
2. If the prop fell into the dense bushland south west of Sydney, its going to be a tough search.
3. Given that Rex has been a little marginal for the last few years, it will be interesting to see the ATSB's comments on the maintenance regime.
OzRogOne
Sat Mar 18, 2017 8:49 am
Read the ABC report again and note the words "over Camden" and "south-west of Sydney"
CXfirst
Sat Mar 18, 2017 9:46 am
Report also says at 6,000ft during the approach, which, from FR24, is just passing Sydney harbour. Anyway, I would be hesitant to rely on media for location. FR24 data doesn't really give a good clue about the whereabouts of the incident.
ATSB says 19km from SYD. Not sure if this is before passing SYD first or after. However, 19km is about the 6000ft mark, and just after passing Sydney harbour (so populated, but also area of water). Or if it is before overflying SYD, then it would be in the forest area just East of Campbelltown. Forest, but not particularly remote.
https://www.flightradar24.com/data/airc ... x/#cc2d4ec
-CXfirst
SomebodyInTLS
Sat Mar 18, 2017 3:35 pm
So has the titled been edited in the meantime? Otherwise I (native English speaker and occasional translator/proofreader) can see nothing wrong with the current "Saab 340 loses propeller in flight"...
If it was "Saab 340 looses propeller in flight" - well then that would be the "comedy option", which happens to work in this case.
"As with most things related to aircraft design, it's all about the trade-offs and much more nuanced than A.net likes to make out."
Spacepope
Sat Mar 18, 2017 4:22 pm
Indeed the title was edited. A bit of a shame really, truly cerebral comedy.
longhauler
Re: Saab 340 loses propeller in flight
Sat Mar 18, 2017 4:32 pm
They are truly lucky that the propellar left the airframe so cleanly. As others have noted, other aircraft were not so lucky!
The Reeve L188 flying CDB-SEA (diverted to ANC for a safe landing) or a Trans-Canada Viscount (one fatality) flying ORD-YYZ comes to mind.
qf2220
Tue Mar 21, 2017 4:12 am
Propeller found. Im pleasantly surprised
http://www.smh.com.au/nsw/missing-prope ... v2x35.html
VirginFlyer
Tue Mar 21, 2017 4:31 am
I hope they'll take it out of the environment.
V/F
Spacepope
Tue Mar 21, 2017 4:34 am
V/F
I've been to the environment once. It gave me a sunburn. Zero stars.
BreninTW
Tue Mar 21, 2017 5:01 am
I do have to appreciate the pilot's turn of phrase -- the "*inaudible*" part in the recording in the article above sounded a lot like "we've just had uncommanded end to operations ..."
belfordrocks
Tue Mar 21, 2017 5:14 am
Such a large propeller in a place as populated as Metropolitan Sydney? I'm surprised it took this long.
A340-500 Queen of the Skies
cjg225
Tue Mar 21, 2017 2:23 pm
V/F
That was AMAZING.
And it fits perfectly with this scenario. hahaha
Restoring Penn State's transportation heritage...
litz
Tue Mar 21, 2017 6:23 pm
Looks surprisingly intact ...
qf2220
Tue Mar 21, 2017 10:51 pm
The potential area that it could have fallen included some pretty rugged bushland and good parts of the Georges River - check out a satellite pic (google maps is good) and you'll see what I mean. It wasnt in a built up area of Sydney with houses and shops all around that is for sure otherwise it would have been found the same day.
Alias1024
Tue Mar 21, 2017 11:15 pm
Wow! Based on the picture the front really did fall off.
TempestDriver
Wed Mar 22, 2017 2:38 am
The crew made a PAN call, not Mayday. The propeller has now been found. Safe landing was made without much drama.
VapourTrails
Wed Mar 22, 2017 5:14 am
They've removed it from the environment. Here is a video and article about the update. http://www.abc.net.au/news/2017-03-22/r ... nd/8376238, REX plane propeller that fell off mid-flight winched out of Revesby bushland, Jessica Kidd, 22 March 2017.
Saw on the 7 News last night where they interviewed a man residing in a house nearby who he was home at the time, said he heard nothing at the time it came down. The police spotted the area because of the damaged trees it was said.
It was reported that the pilot had already shut down the engine before it separated.
REX has grounded five of its aircraft that are similar to the damaged plane until the outcome of the investigation. Not often we get to see the inside of a (damaged) prop blade like this. I 'look forward' to reading the ATSB report.
m1m2
Wed Mar 22, 2017 7:30 am
Looking at the pictures of the airplane it looked as though the shaft had sheared off. However, looking at the closeup of the assembly on the ground after it had been dropped off by the helicopter, I can't see any evidence of the flange attached to the prop. I'm assuming the shaft had been removed from the assembly before these pictures had been taken, and probably even before it was hoisted from where it fell. Too bad because I was really interested in seeing what damage was on that gearbox shaft. The mounting studs are certainly there and all appear to be in good condition with no missing threads or damage to be seen.
SomebodyInTLS
Wed Mar 22, 2017 10:44 am
Ha ha ha! I love how the helicopter downwash turns the propeller so the winch cable is completely twisted up at the end! I suppose that's why the chopper was so careful setting down after that.
The prop is remarkably intact.
qf789
Crew
Thu Mar 23, 2017 3:40 am
Another REX aircraft has had an emergency landing today after an engine had to be shut down in flight
http://www.abc.net.au/news/2017-03-23/r ... bo/8379712
Forum Moderator
T prop
Thu Mar 23, 2017 3:54 am
Yes, it looks as if the shaft on the aircraft has sheared and the flange should be on the propeller. It appears the flange is not on the prop, why would it be removed out where the propeller fell? I hope it didn't come off the airplane like that.. :shock:
BruceSmith
Thu Mar 23, 2017 5:12 am
Someone on a paintball forum posted a photo
https://www.dropbox.com/s/ysunj5ta7pd6qsx/Lost%20propeller%201.jpg?dl=0
and a screen grab from the news report
https://www.dropbox.com/s/dup6m4nfd6jd74e/Lost%20Propeller%202.jpg?dl=0
The photo has the flange on the prop still and looks like the nuts on the mounting studs are missing. The damage in the photo is identical to the damage seen in the news video, so it is the same propeller.
If the flange was completely unbolted, would the ATSB have removed it after documenting to keep it from falling off during the helicopter lift?
