Tg 747-300
FR Emergency Landing
Fri Feb 15, 2002 7:05 am
I have just heard that a Ryanair jet enroute from STN to Vesterås in sweeden had to make an emergency landing somewhere in Denmark due to a engineproblem and loss of cabin preassure.
Yus wanted to now if this was a 732 or a 738?
tg 747-300
intentionally left blank
Nik
RE: FR Emergency Landing
Fri Feb 15, 2002 7:13 am
It was a 737-800.
Here is a link in Danish:
http://politiken.dk/VisArtikel.iasp?PageID=200424
Tg 747-300
Fri Feb 15, 2002 7:19 am
This article tells us that a FR B737-800 had to make an emergency landing in Tirstrup (denmark) due to loss of cabinpreassure and problems with an engine. The aircraft carried 105 pax (all uninjured) and 30 ambulances and 3 fire engines were sendt to the scene, among with a team of doctors.
tg 747-300
Fri Feb 15, 2002 7:30 am
Problem with engine no 1 and air pressure.
Engine shut down, divertion, noone injured
Even though I dislike FR(audAir) I´m glad they handled this situation good.
Wonder how long they´ll leave the pax stranded at AAR though!
prebennorholm
Fri Feb 15, 2002 7:35 am
Yep, this afternoon. There was an engine problem on an FR 737. The crew chose to close down that engine and descend to "safe altitude" since reserve cabin pressure is no longer present with on engine inop.
It was a brand new 737-800.
Plane landed eventlessly at Aarhus, Denmark (also called Tirstrup Airport) which incidentally also is a busy Ryanair destination.
The 105 passengers were kept on board after landing. It must indicate that it was an easy fix, probably a loose fire indicator wire or such.
Read ten lines (Danish language) at http://www.jp.dk/dbp/internetavisen/indland/artikel&art_id=3598552 - thanks to Jyllands Posten, a major Danish newspaper.
Good thing that airliners have (at least) two engines.
Regards, Preben Norholm
prebennorholm
Sat Feb 16, 2002 5:01 am
It was a low oil pressure indication on one engine. It was not told if the fault was in the pressure indicator, or the oil pressure really was low.
It could not be fixed in minutes, so a spare Ryanair 737 brought the 105 pax to their destination later in the evening.
