SU27COBRA
Could Concorde go Supersonic when full?
Fri May 19, 2017 9:19 pm
I have been told that Concorde could never go supersonic when full? Is this true at all?
As I type it seems far fetched.
However I was told that BA and Air France never sold all the seats on the plane for this reason, and if there was a full compliment of 120 passengers or so it couldn't go supersonic.
Is there any truth to this?
Thanks.
ChrisKen
Re: Could Concorde go Supersonic when full?
Fri May 19, 2017 9:27 pm
No, not true.
BA Seat Count was 100 anyway.
GDB
Fri May 19, 2017 11:18 pm
Thanks.
Though certified for 128, there would have been weight savings elsewhere, more austere galleys for instance. A moot point as that config never happened. The time an AF Concorde would not do Mach 2, was in 1996 when one was painted to promote Pepsi. Much less white paint surface area restricted it to Mach 1.6 I think, due to increased heating of the skin as you go faster, which the Concorde liveries being essentially white was OK for up to Mach 2.2, though in service, both kept to Mach 2.04 at most. Though the protection was enough, increased friction heating beyond Mach 2.04 could, over time, affect the RR58 Aluminium alloy that was the aircraft's primary structure, this included some copper for airframe expansion but that in itself is of course a stress.
Avoiding that extra stress meant that the original estimated lifespan of Concorde, some 15-17 years, was easily achieved, when they went in for their 12000 re-life 1 check, the youngest BA one was G-BAOG, though that had spent some years in storage and brought back in 1985, the original 5 however, had been flying for around that 15-17 year period but were found to be in much better condition that expected, so adding 10 mins to a LHR-JFK route, which is all that speed reduction did, made life a lot easier later on, the aircraft more sustainable allowing more investment in the product without hitting the revenue generated.
SU27COBRA
Fri May 19, 2017 11:40 pm
Great thanks for the info on the paint... everything matters :-)
LAX772LR
Sat May 20, 2017 1:38 am
Of course not. What then would've been the point of building it?
crownvic
Sat May 20, 2017 5:05 am
Thanks.
I flew Concorde 2x in the final years. Both were full flights and the Mach meter read over 2.0 on both occasions, so this is not true.
factsonly
Sat May 20, 2017 10:43 am
Thanks.
This (layman's) story could be triggered by another Concorde fact.
Concorde could not make JFK-LHR or JFK-CDG v.v. with its max. design number of 128 passengers.
Concorde's seating of 100 passengers (AF and BA) was dictated by the fact that the aircraft's payload range did not permit a higher number of passengers for regular reliable year-round TATL crossings.
Check the Payload range diagram below, which indicates Paris was at the very limit of the payload range:
- 100 pax = 22.000 lbs
- JFK-CDG = 3153 NM
https://www.flightglobal.com/FlightPDFA ... 200448.PDF
vc10
Sat May 20, 2017 12:35 pm
Check the date of your article, which is 1964 so a lot changed between then and the aircraft's introduction into service and indeed a lot changed after 1976
GDB
Sat May 20, 2017 8:18 pm
Too right! The aircraft changed a lot during it's development. I don't like to call the first French and UK prototypes as such, today I think we'd call them Technology Demonstrators.
What were the first two pre-production aircraft were really what we'd call a prototype today, or indeed with most airliners being developed generally going back to Concorde's time and before. Concorde prototypes were more like the Boeing Dash-80 and about as different that was to a production B-707.
When you see the aircraft that flew first as Concorde, they were shorter, had a less refined ogival wing, less developed engines, analogue intake controls and those solid visors with mere peep holes for vision, which was never going to be certified, in case it got stuck in the flight config which would mean literally a blind landing!
In 1964, much of this was to be developed, those figures could only have been based on, at best, a somewhat developed version of the prototypes. At this stage, two versions were still planned, France would make a 'medium haul' higher capacity version, which an eye on routes to Francophone Africa as much as the USA as far as AF was concerned.
While the UK would build the longer ranged version, less capacity, more range, the transatlantic one (though AF's fleet of these would likely also come from Toulouse). BOAC only wanted this version.
It was not long after 1964, when it became clear that there could well be serious issues around overland supersonic flight, weakening the already shaky case for the 'medium range' version.
When I was going through the archives, I saw some fascinating letters, including one which were in effect the minutes of a meeting in 1964 between BAC and Pan Am, at a hotel in NY (Shades of Mad Men!)
PA, then a prospective customer who the previous year, had in effect started the US SST program by optioning Concorde.
They discussed loads, different cabin configs, noise and they really wanted an APU!
(I saw a BAC drawing of a proposed APU from 1970, with either a French one or the type used in the C-5A. But none was ever fitted to any aircraft).
Classa64
Sun May 21, 2017 3:21 pm
I would have thought it was not possible to go Supersonic at or close to MTOW as well just like most planes at MTOW cant get to MAX cruise height until fuel is burned off?
I have no idea just curious.
C.
"Freedom is the miles i'm rolling on"
ChrisKen
Sun May 21, 2017 5:13 pm
Classa64 wrote:
LAX772LR wrote:
C.
Yeah but Concorde goes supersonic at less than half it's max speed and less than two thirds of its ceiling.
LAX772LR
Mon May 22, 2017 3:18 am
It's understandable.
But as was pointed out earlier: you gotta realize that Concorde goes supersonic at far less than its maximum capable speed.
So while it's reasonable to wonder if it could get up to Mach2.02 at max weight minus spent fuel........to just "go supersonic" only requires exceeding Mach1, and if Concorde couldn't do THAT, even at full weight, then there would've been absolutely no point in even making the thing.
ojjunior
Mon May 29, 2017 9:42 pm
Oh dear... is this question real ???
In what world would anyone build something that did not have their main reason for existing allowed if they were in full capacity usage?
And even if some crazy build it up, who would buy something under these circumstances?
Don't know who told you this non-sense but tell them to use vinegar in the salad, not wine.
kurtverbose
Tue May 30, 2017 7:04 pm
A bit of research and I found a flight profile on this website: -
http://www.blodtandsmidigt.com/concordeprofiles.html
It doesn't say the route or give weights but it's a +3.5hr flight so must be at or near MTOW.
Concorde goes supersonic within 20 mins of takeoff, and is at mach 2 30 mins after takeoff.
This is the height profile: -
Incidentally, it might take 20 mins to go supersonic as it waits to clear land, or it might need to climb to altitude before accelerating, I have no idea. In any case, weight doesn't seem an issue.
GDB
Thu Jun 01, 2017 5:01 pm
Also of course, out of US East Coast airports like JFK and IAD, you are over-water sooner compared to out of LHR.
The same was even more true out of BGI.
As soon as you are over-water you can begin acceleration to supersonic.
(Though G-BOAG's last flight, to The Museum Of Flight in Seattle, went supersonic over a narrow area of northern Canada, from JFK, that is virtually uninhabited, as approved by the Canadians. This was also used on some charters, including BA's 1999 'Round The World' one).
Users browsing this forum: No registered users and 18 guests
