GBMRA757SF
Re: DHL orders additional A330-300 P2F
Thu Oct 19, 2017 12:04 pm
Channex757 wrote:
MajMattMason wrote:
These A333 P2F's acquisitions, are they to replace or augment the existing fleet? If replace, I assume it's going to be for the A300's?
Anyone know what the fate of the B757 fleet is??
DHL have been swapping a lot of aircraft recently. They just took a pair of late build 757s from AA for conversion.
This is a fairly up to date list of the UK-registered DHL fleet
http://jethros.org.uk/fleets/fleet_listings/dhl_air.htm
The older 757s have been going to the breakers recently, with newer models (and better engines) replacing them.
A330's may well go to Air Hong Kong ( Ops by ASL ) but this is DHL we are talking about
BOEING777EK
Wed Nov 29, 2017 10:28 pm
So how's the A330 certification going? I would imagine it being done soon also how's the flight test's going? The recently converted A330 flew in October 2017 since then. And what's the status of HS-TEM DHL's 4th A330?
KarelXWB
Fri Dec 01, 2017 10:34 am
It's done:
Conversion specialist EFW has secured European supplemental type certification for the modified Airbus A330-300 passenger-to-freighter modification.
https://www.flightglobal.com/news/artic ... al-443774/
Aircraft has been delivered:
DHL Express has become the first operator to take delivery of the A330-300 Passenger-to-Freighter (P2F) converted aircraft from Elbe Flugzeugwerke (EFW), the joint venture between ST Aerospace and Airbus. This delivery, which took place at EFW’s freighter conversion facilities in Dresden, follows the successful completion of test flights in October and awarding of the Supplemental Type Certificate (STC) by the European Aviation Safety Agency (EASA) in November. DHL Express has firm orders for eight A330-300P2F units in total, with additional options to receive another 10.
http://newsroom.aviator.aero/first-a330 ... -with-dhl/
Lilienthal
Fri Dec 01, 2017 11:09 am
So the nose-down angle is not an issue for the operators or is it just not possible to reconfigure the nose gear section?
Martinairger
Fri Dec 01, 2017 2:41 pm
Tomorrow is planned the delivery flight of the first A330-300P2F (ASL Airlines) to Dublin (DUB).
A picture from today: https://www.mach-photos.com/single-post ... ery-flight
Martin Rogosz
BOEING777EK
Fri Dec 01, 2017 4:12 pm
Nice! I'd imagine the conversion of D-AAEB getting done by Mar/Apr 2018. Are there any more A330's due for ASL?
KarelXWB
Fri Dec 01, 2017 4:13 pm
I suppose so, DHL has 8 A330 conversions on firm order.
Stitch
Fri Dec 01, 2017 7:05 pm
I expect the modifications are too expensive to justify when they can just jack up the front of the plane if they require a flat load floor.
KarelXWB
Wed Dec 06, 2017 11:40 am
Another view of the fully finished aircraft. Does anybody know if it will be painted in DHL colors?
Uploaded by Martin Rogosz http://www.skybird-ev.de/p2f/2017/fp----17.html
blrsea
Wed Dec 06, 2017 11:47 am
What do they replace the windows with? Is it more like aluminum like the aircraft's outer skin?
bwvilla
Wed Dec 06, 2017 2:44 pm
Has a mechanised cargo handling system and the incline is no issue
jeffrey0032j
Wed Dec 06, 2017 4:26 pm
I hope so, as the reinforcements to the frame are pretty obvious in the picture.
Stitch
Wed Dec 06, 2017 4:58 pm
The windows are removed and an aluminum plug is installed in it's place.
tvh
Wed Dec 06, 2017 5:18 pm
Does that save weight ? Otherwise why the trouble?
Revelation
Saves maintenance cost as well as weight.
The heart has it's beaches, it's homeland and thoughts of it's own
The heart has it's seasons, it's evenings and songs of it's own
Stitch
From what I hear, the weight is a wash (the more windows you plug, the heavier the combined weight of the plugs is). However, the plugs are much more reliable from a maintenance perspective and with the inside of the fuselage covered in thick cargo liners, getting to the windows for maintenance is extremely difficult. So they plug them from a maintenance savings perspective rather than a weight savings one.
WIederling
Wed Dec 06, 2017 10:09 pm
plugging windows counts per plugged window.
There is no penalty for plugging more :-)
Though the maintenance reduction counting more than the weight reduction is probably correct.
Murphy is an optimist
Stitch
Wed Dec 06, 2017 10:16 pm
WIederling wrote:
plugging windows counts per plugged window. There is no penalty for plugging more :-)
Some people have said that on large planes with lots of windows the combined weight of the plugs was greater than the combined weight of the windows removed. Others noted on smaller planes with less windows that the plug weighed less than the window so overall the airframe ended up lighter. So maybe the larger planes with larger windows have larger and heavier plugs. *shrug*
blrsea
Thu Dec 07, 2017 1:59 am
Good info, thanks guys! Had another question. After the modification, does the passenger cabin hold same type of containers as the cargo hold (LD3/2 etc)? Or can they hold bigger size containers, as passenger area is much bigger? Do they plug some of the doors too, as they are no longer required?
Stitch
Thu Dec 07, 2017 2:43 am
The main deck can take much larger pallets and ULDs then the hold. On an A330, the most common size pallet/ULD would be 96x125" side-by-side.
I would expect the doors other the forward and aft sets would be plugged.
precure787
Thu Dec 07, 2017 4:56 am
The A330 P2F looks like a great candidate for a modernization project for many airlines.
Edward Zen/Precure 787
HPRamper
Thu Dec 07, 2017 6:42 pm
LD3/2 would be belly only. Upper deck containers are much larger - AAD/AAX type most likely on this size of aircraft.
BOEING777EK
Thu Dec 07, 2017 8:56 pm
So what's the status of HS-TEM? it's the next A330 for DHL after TRI and TEL which is at conversion right now I would imagine TEM being de-mothballed by now and completing engine runs test flights before heading for a maintenance check.
trex8
Fri Dec 08, 2017 12:54 am
So the factory A330-200F has no powered floor system?????
Aesma
Mon Dec 11, 2017 10:17 am
Bluebird191 wrote:
ap305 wrote:
behramjee wrote:
Oh I didnt know that the A333 was also now part of the P2F program which I'm really happy it is now !
How many tons can the A333F uplift? As the B77F does 101T and MD11F has 80.
You can find the relevant data for the a33p2f here
http://www.elbeflugzeugwerke.com/filead ... 2F_web.pdf
With the A333 P2F being able to uplift just 1 tonne more than the A332 P2F, what is the use of it? Unless mail/courier carriers like DHL want the extra volume over the lack of extra weight uplift - the internal volume is the only thing I can think of that would be of benefit to airlines.
Don't mix P2F and pure freighters, P2F have always less capacity (but cost a lot less).
The 777F has a different floor than the 777 PAX, the A330F has the ugly blister, pure freighters come with no provisions for galleys, lavs, IFEs, simplified aircon, etc., they're quite different from PAX A/C.
TriniA340
Fri Feb 09, 2018 12:27 am
Saw a photo today with her painted...just like the Polar Air Cargo 747.
· longer · larger · farther · faster · higher · quieter · smoother ·
KarelXWB
Sat Feb 10, 2018 12:44 pm
Aircraft has finally been painted.
https://tinyurl.com/y99daydx
ap305
Sat Feb 10, 2018 1:56 pm
That is the second one? for some reason the first one is sitting in Rome for one week.
Racing, competing, is in my blood. It's part of me, it's part of my life; I've been doing it all my life. And it stands up before anything else- Ayrton Senna
KarelXWB
Sat Feb 10, 2018 3:49 pm
Rome has a widebody paint hangar; sometimes A330s get painted in Rome.
Is the first A330 P2F getting a paint job in Rome?
SpaceshipDC10
Sat Feb 10, 2018 10:07 pm
I had hoped they would be painted all yellow... Too bad!
Revelation
Sat Feb 10, 2018 10:13 pm
Love the way the big twin freighters have such clean lines.
TriniA340
Sat Feb 10, 2018 10:22 pm
Wait....how many birds have been converted already? I thought was only 1..
Mumrik
Sat Feb 10, 2018 10:45 pm
Are these A330s to be operated by another company, or DHL them selfs?
Thought that livery was only painted on aircraft operated by other companies, such as Southern, ASL, Air Hong Kong and Kalitta.
Aircraft enthusiast and model custom maker
SpaceshipDC10
Sat Feb 10, 2018 11:10 pm
ASL
https://www.planespotters.net/airline/A ... es-Ireland
WIederling
Sun Feb 11, 2018 11:44 am
You plug one window with a known delta dX in weight. you plug 100 windows and you show a delta of 100 * dX in weight.
It just doesn't suddenly get heavier from plugging more windows when a single window shows a net reduction in weight.
That is not "shrug" that is plain wrong.
KarelXWB
Sun Feb 18, 2018 5:06 pm
The first A330 P2F has indeed been painted in Rome.
https://twitter.com/zeTravelersClub/sta ... 8742921216
royroy
Sun Feb 18, 2018 5:42 pm
Any news on the egyptair p2f A330?
KarelXWB
Fri Feb 23, 2018 12:33 pm
BOEING777EK
Fri Mar 30, 2018 10:20 pm
Any news about more A330's getting converted into freighters for DHL and Egyptair cargo?
TriniA340
Wed Apr 04, 2018 8:28 pm
BOEING777EK, Haven't heard anything yet. I see EI-HEA is being operated by Air Hong Kong & flying 1-2hr rotations between HKG, PEN, SGN, BKK.
cougar15
Sat Apr 07, 2018 6:56 am
Rumour only, but I hear DHL (ASL) want more for the European Express Network. Presume they are kicking tyres as we speak....
some you lose, others you can´t win!
