Av8
Why Is It Tilted?
Fri Feb 22, 2002 5:47 am
I've noticed that in a lot of the pic's of cockpits, if nothing's running, the attitude indicatior is tilted. Why is this?
TurbineBeaver
RE: Why Is It Tilted?
Fri Feb 22, 2002 5:50 am
The Attitude indicator runs on a gyro system, which works by the suction of a vacuum. If nothing is running, the vacuum is off, and the gyro stops spinning so the Attitude Indicator won't work.
TB
TWAL1011
Fri Feb 22, 2002 7:29 am
Interesting...I always thought gyros were electrical. If they're vacuum, how do they work without an engine running?
TWAL1011
Fri Feb 22, 2002 7:33 am
Okay, I'll be the first to admit when I'm wrong...
Note to self: Research and then post. Not the other way around.
Anyway, here's a detailed explanation:
http://www.avweb.com/articles/attitude.html
Sorry!
ThirtyEcho
Fri Feb 22, 2002 8:01 am
Gyros are either electrical or vacuum; to provide redundancy, one gyro is electric and the other vacuum. Its a whole other thing in a glass cockpit, though.
TurbineBeaver
Fri Feb 22, 2002 10:45 am
TWAL1011...that's the whole point, your DG (Directional Gyro) and your Attitude Indicator are vacuum run, so when you loose your engine, you lose your vacuum, and lose your attitude indicator and DG.
Click for large version
Photo © Mike Elliott
(see in the pic, it says VACUUM on the DG and Attitude Indicator)
TB
