Martinlest
Jet aircraft able to use EGLC?
Wed Sep 13, 2017 4:05 pm
Googling this extensively came up with no results, at least in the form of a list of aircraft current (or previously) in use (but then I seem to be a lousy Googler!).
I would like to know which civil jet a/c are able to take off and land at EGLC. I assume not an a320? I ask mostly because I want to try flying in and out of EGLC in X-Plane 11, but the available civil jets are very limited.. possibly an Emb170 BA City Flyer, if I could get any of the cockpit switches working.
skipness1E
Re: Jet aircraft able to use EGLC?
Wed Sep 13, 2017 4:08 pm
Any 146 series, Fokker 70, ERJ170, ERJ190, A318,CS100 small to medium biz jets too.
PatrickZ80
Wed Sep 13, 2017 4:23 pm
Wasn't the Sukhoi Superjet 100 also certified to land at London City? Other than that, I think the list in the post above is pretty much it when it comes to jets.
Of course there also are a lot of props operating in and out of London City. ATR 42 / 72, Dash 8, Fokker F-50, etc are all regular guests there.
32andBelow
Wed Sep 13, 2017 4:29 pm
757-200
PatrickZ80
Wed Sep 13, 2017 4:34 pm
32andBelow wrote:
757-200
Certainly not! The largest plane that is able to use London City is the A318. The 757 is way too big.
rnav2dlrey
Wed Sep 13, 2017 4:40 pm
PatrickZ80 wrote:
32andBelow wrote:
757-200
“able” and “certified” aren’t necessarily the same thing, especially when OP is asking about a flight sim. i wouldn’t be surprised if an empty 752 with RB211s and its beefy brakes handles approach, landing and takeoff just fine.
Martinlest
Wed Sep 13, 2017 4:47 pm
Thanks - sadly none really available for X-Plane 11 (apart from some expensive payware Embraers). The ATR might be an option... I'll look further. Who flies the ATR out of London City though?
PatrickZ80
Wed Sep 13, 2017 5:03 pm
Flybe and Aurigny at the moment and Aer Arann used to before they ceased operations.
ChrisKen
Wed Sep 13, 2017 5:16 pm
There was a list buried somewhere on LCYs site.
Basically, has to be multi-engined and certified for approaches greater than 5.5'. No single engine, no helos.
nipoel123
Wed Sep 13, 2017 5:56 pm
You're probably referring to this list: https://www.londoncityairport.com/downl ... 0fv_sm.pdf
The document's title suggests it's from 2011, so it's a little outdated (CSeries are not on the list for example).
Here's a list of business jets (and approved operators):
http://jetcentre.londoncityairport.com/ ... craft/List
one mile of road leads to nowhere, one mile of runway leads to anywhere
WIederling
Wed Sep 13, 2017 6:04 pm
https://de.wikipedia.org/wiki/London_Ci ... _Flugzeuge
remove the props.
A318 is afaik the biggest certified for LCY
Murphy is an optimist
Martinlest
Wed Sep 13, 2017 7:32 pm
Thanks - can't get the jetcentre link to open BTW.
KICT
Wed Sep 13, 2017 11:13 pm
Runway length isn't the issue. It's the approach certification and ramp space.
Andre3K
Thu Sep 14, 2017 12:41 am
It's a simulator, just pick planes and start trying. I mean how many times have people tried landing 747's on carriers?
GalaxyFlyer
Thu Sep 14, 2017 1:03 am
I'd be amazed, and like to see the data, that a B757 has anywhere near enough drag to fly a 7.5 degree glide path. Yes, it's 5.5 degrees, but the certification standard is 7.5 degrees to handle exigencies, poor technique, etc.
GF
qcpilotxf
Mon Sep 18, 2017 3:09 pm
remove the props.
Actually the CS100 is the largest aircraft operating at LCY... its slightly larger footprint wise
But regardless it is highly unlikely you will every see anything larger than that at LCY. They are getting really tight on space lately
B777LRF
Tue Sep 19, 2017 1:16 pm
I don't know anything about the fidelity of that sim, but rumours has it to be not too far from the truth. Anyway, I've landed a 757 there in real-life full-flight (Level D) simulator. 'Twas a bit sporty, and it was not possible to establish a stabilized approach as per the normal criteria. But we got it down, and stopped, without too much fuss. Good fun.
I know a bloke who landed a 777 there in a FFS, and there's rumours of a nutter doing the same in an A380.
From receips and radials over straight pipes to big fans - been there, done that, got the hearing defects to prove
B777LRF
Tue Sep 19, 2017 1:44 pm
GF
It doesn't. At least not without liberal use of speedbrakes.
flipdewaf
Tue Sep 19, 2017 1:53 pm
GF
That suggests you need to be able to fly with a L/D of some 7.5 @ approach speed, all of a sudden the speed brakes on the BAE146 make a lot of sense, maybe the ultrafan with its variable pitch blades akin to a turboprop will usher in a new class of aircraft into LCY.
Fred
Users browsing this forum: adools, skyhawkmatthew and 1 guest
