Indy
Re: IND - New Runway & Major FX Expansion Coming?
Thu Dec 07, 2017 12:32 am
Midwestindy wrote:
Indy wrote:
There is also the old terminal area. Not sure if that will be used for FX because of the distance.
? distance doesn't seem to be an issue for FX, they already have two hangars on the completely opposite side of the property...
A hangar is one thing, but I doubt you are going to tow cargo back and forth over a great distance. That seems far too inefficient.
Indy = Indianapolis and not Independence Air
flyPIT
Thu Dec 07, 2017 12:38 am
I agree the location of the hangar means nothing but towing cargo to the old terminal ramp doesn't look any further than towing cargo to the farthest reaches of the FX MEM ramp. The 777 ramp in MEM is even removed and separated by the cross runway from the main FX facility, much as it would be at IND using the old terminal ramp.
FLYi
Indy
Thu Dec 07, 2017 3:54 am
How long of a tug drive is it? The route from the FX sort facility to the old terminal location is very indirect. From the middle of the sort facility to the middle of the old terminal location is 10k feet. That includes taking the road around the end of the crosswind runway that a tug would have to take. Round trip is just under 4 miles. How long would that take at tug speed? Not sure that long of a run is practical. I checked MEM and the distance from the middle of the sort facility to the location across the runway is just shy of 7k feet. Round trip it is over a mile shorter.
jetmatt777
Support
Thu Dec 07, 2017 6:07 am
Tugs usually ride around 15-20 mph. Bobtail freight trucks can do whatever speed you want (F350 with a bobtail instead of a bed) but they are usually mechanically governed to 25-35 mph. Dolly/cart wheel speed is the limiting factor on those.
That would be a hellacious distance on a tug...
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
Krivak
Thu Dec 07, 2017 11:41 pm
I believe they use them, they dont own them. As far as the old terminal, nothing's been said about using it. MEM is currently at capacity for space for fedex, so IND is the next one to be expanded because we are not landlocked and full up. MEM has had to reorganize a few times, and they have aircraft specific gates to ensure max capacity. Fedex IND gates are, with the exception of the 757 area and the two 777 gates, all sized for MD-11 aircraft to ensure any widebody can park in any gate.
Looks like they're actually going to use that area near the contractor gate for more dolly parking, and move that tug lot down about 500 or so feet further towards the end of the ramp, as there is more space.
There's a postal tug or two that makes the trip to us, they say it takes over half an hour one way. Fedex tugs are governed to 10ish mph, as that is the speed limit in our drivelanes. Further reduced to 5 mph (policy) within 50 feet of an aircraft. Some of the tugs have broken governers, Ive even towed dollies with them. That course of action is NOT recommended, those dollies will start slamming into the hitch, then swaying the faster you go. I backed down on speed pretty quickly.
jetmatt777
Support
Fri Dec 08, 2017 12:49 am
I have a tractor I use at work (I try and beat others to check it out) because the governor is broken. Occasionally the airport will put up the feedback speed limit signs that tell you how fast you are going and it tops out at 21 mph without a load. Pulling a cart and 30 checked bags it runs about 17. So they are certainly not speed Demons. Most of ours are governed at 14 according to the signs.
