lowbank
Re: AF66 CDG-LAX (A388-F-HPJE) diverts to Goose Bay (YYR) with an uncontained engine failure to #4 engine
Sat Oct 14, 2017 5:52 pm
Balerit wrote:
the flange shown in red on the diagram is the flange that's fractured.
Many of the other diagrams are pointing too far back in the engine.
I think the confusing is coming from the pictures show a design which is different for the GP7200.
Every days a school day.
Revelation
Sat Oct 14, 2017 6:38 pm
I appreciate any correction.
The source image ( http://www.pw.utc.com/Content/GP7200_En ... y_high.jpg ) is from a PW web site and is labelled as from EA in 2014.
What aspects do you think are different?
The heart has it's beaches, it's homeland and thoughts of it's own
The heart has it's seasons, it's evenings and songs of it's own
lowbank
Sat Oct 14, 2017 6:51 pm
In this picture the inside diameter of the fan disc appears to slide over the main shaft.
speedbored
WIederling wrote:
one step further forward afaics? ( ps: probably not )
Well I'm definitely not an engine expert but it doesn't look that way to me, especially when you look at the more side-on photos of the damage. I'm pretty sure that the central shaft has sheared off where I have indicated, and the rest of it appears to have gone pretty much level with that.
lowbank
Sat Oct 14, 2017 6:57 pm
Whilst I am not going claim to being 100% correct, I have been to the engine build line several times and the fan disk manufacturing facility recently. I suggest your looking to far back into the engine.
As per the AD it's the Fan Disc/hub that's failed and you can see the area it failed in red.
lowbank
Sat Oct 14, 2017 7:01 pm
speedbored wrote:
Is this what everyone is looking for:
This Fan disc is bolted to the component behind it, no idea which engine this is, different configuration to what I am used to. I wonder if this photo is confusing people.
speedbored
Sat Oct 14, 2017 7:47 pm
Well you probably know more than I do - I'm only looking at pictures and it is entirely possible (likely even) that the schematic is not 100% accurate. It's also not easy to tell in the schematic (due to the offset angle) exactly how things line up.
Until we get more official information, I suspect that we are all mostly guessing.
Possibly. I was informed that this is a picture of a GP7200 but I have no way of verifying whether it genuinely is or not. I don't see anything that disagrees with the other images though.
lowbank
Sat Oct 14, 2017 8:35 pm
I agree schematics are not accurate.
Having not seen a GP7200 being built I cannot agree or disagree with you
There is a bolt at the back of each position where the Annulus filler go, that would be a static structure on engines I know, they could just be slave bolts put in whilst the engine is being built, but that's just a guess.
lowbank
Sat Oct 14, 2017 8:39 pm
Having looked at the failed engine again, you can see the bolt holes, but it is a static structure so I am going for slave bolts and the engine does look like a GP 7200.
dgrev
Sun Oct 15, 2017 2:45 am
speedbored wrote:
Revelation wrote:
Would be interesting to see where that is in the cut-away drawing I posted above
I think it is probably roughly like this:
Sorry, but I disagree. Please see attached re-mark of your photo. What you are identifying as bolt holes show no damage or eccentricity. The way I see it is those holes are normally covered by the flange that extends from the missing hub. See where I have extended your lower arrow.
Sun Oct 15, 2017 8:25 am
Some good closeups of GP7200s here
https://www.aeroreport.de/en/articles/r ... pruefstand
https://www.aeroreport.de/en/articles/g ... ser-werden
And the fan separated from the rest of the engine
speedbored
Sun Oct 15, 2017 8:49 am
Thanks for those - excellent images. And it confirms that the fan hub image I posted on the previous page is from a GP7200.
|'ve also found a better side-on schematic (from the manufacturer's site):
Seems to me that the ring with holes in that we see in the picture of the damage is the front of the LPC:
i.e it is the ring that the blue-coloured fan hub is bolted on to. If you zoom in on the high resolution version of the front-on view of the damaged engine, you can clearly see that every 4th hole on that ring is slightly larger than the other holes, which would tally with the bolts on the fan hub close-up images.
Seems to me that the fan hub mounting bolts have all sheared off (possibly by design to protect the remaining structure) due to excessive forces from the fan.
WIederling
Sun Oct 15, 2017 9:28 am
structural cone with the flange visible and just outside the aerodynamic shroud (a bit deformed )
that guides airflow coming past the aerodynamic hub cover of the fan into the LP compressor.
Murphy is an optimist
Revelation
Sun Oct 15, 2017 10:50 am
zeke wrote:
Yes, comparing this one to the earlier frontal shot makes it very clear as to what departed and what stayed.
Balerit
Sun Oct 15, 2017 12:04 pm
Gee, those fan blades are massive.
Licensed Aircraft Maintenance Engineer (retired).
lowbank
Sun Oct 15, 2017 3:37 pm
Now we have a better schematic I agree the bolts are not slave build bolts but assembly bolts. I am no stress engineer but those bolts would sustain the loads once the fan hub/disc had fractured.
It appears that the LP fan is bolted to First LP compressor which must obviously rotate together. Driven by the LP turbine.
lowbank
Sun Oct 15, 2017 3:39 pm
You want to see the XWB 97k ones, they are huge.
treetreeseven
WIRED: How Air France will rescue its A380 with a shattered engine
Sun Oct 15, 2017 6:35 pm
Then the team will mount a spare engine in its place on the right wing. Here's the weird thing, though: The airline probably won't use it to power the plane back to France. The stand-in is there for weight balance, and won’t actually work, according to Reuters. BEA says the exact plan is still being studied.
https://www.wired.com/story/how-air-fra ... red-engine
ikramerica
Re: WIRED: How Air France will rescue its A380 with a shattered engine
Sun Oct 15, 2017 7:15 pm
Why ship an engine there? Ship a weighted slug to mount instead.
lowbank
Sun Oct 15, 2017 7:21 pm
A good effort on behalf of the ante guys to get photo and schematics of the GP7200.
We should all now understand the area of failure and what's left.
We know it's cyclic fatigue from the AD .
What we don't know is:-
Is it a manufacturing fault.
Is it a maintenance fault.
Is it a material fault.
Worst off all is it a design fault.
I suggest it's 1 or 3.
Reason is the engine has been operating for some time and there will be engines with higher cycles out there.
First report will make interesting reading
dashdrvr
It used to be 4 engine aircraft were capable of 3 engine ferry flights. I presume the same still applies. W&B, engine location on the wing, aerodynamics, length of flight and WX all have to be factored on a ferry flight let alone a 3 engine ferry flight. Some airlines even have special qualified crews for out of the ordinary ferry flights.
itchief
Sun Oct 15, 2017 8:09 pm
That is what AF is doing and this weighted slug has the correct aerodynamics built into it.
WIederling
Mon Oct 16, 2017 8:18 am
What will they use as a "weighted slug"? Another "real" engine?
( Building a bespoke concrete engine probably would be time and paper consuming to no end?)
rouelan
Mon Oct 16, 2017 8:46 am
I dont know if someone already did it but I really wanted to pay tribute to the whole crew, both Technical and commercial.
There were some scary minutes after the "bang", with, of course, no immeditae statement from the captain and cabin crew going quickly to their positions. Then, captain said situation was under control and all passengers remained remarkably quiet on our way to Goose Bay. And after, it was the same despite a long wait (I think 15 hours) before we could take another aircraft.
Revelation
Mon Oct 16, 2017 10:45 am
The flight software already needs to deal with a windmilling engine, so they chose to require it for this scenario too.
Good point. Congrats to the crew for handling this situation with a high level of professionalism.
Aesma
Mon Oct 16, 2017 10:54 am
The aircraft is not certified to fly with that attached. The slug itself is not certified to get in the air either.
Klaus
Tue Oct 17, 2017 8:19 am
Just a few observations from what had already been posted before:
One of the posted inflight videos shows a good part of the upper outboard fan shroud still attached before the airstream apparently ripped it off before landing. So it stands to reason that at least the main part of the fan did at least not depart in that direction but more down and inward. Very fortunate that it mostly spared the wing and the cabin.
Passengers reported that for a time there were substantial vibrations. I'm not discounting the possibility that the core or the turbines might have sustained enough damage to cause this, but wouldn't that be consistent primarily with first one and then a few fan blades separating and the vibrations resulting from the imbalance then weakening and ultimately breaking the fan disk flange? (Which would still be a much worse outcome than the kind of contained blade-off scenario the engines are tested and certified for, raising its own questions.)
Given the spectacular high-energy takeoffs they've demonstrated at air shows it seems very plausible that with the proper precautions under controlled conditions a 3-engine takeoff and ferry flight should be feasible, just compensating the imbalance by not carrying any passengers or freight and only a reduced fuel load. Since the pylons are designed with frangible engine mounts the airframe will also be designed to survive and remain controllable with only three engines attached at all, even if takeoff may be more restricted and if they'll actually choose to keep the damaged rest of the engine attached after some cleanup.
I'd guess they'll perform DNA tests on the remains of the engine (both the attached and the separated ones) to check for a possible bird strike at takoff or during climb which might have triggered the event.
uta999
Tue Oct 17, 2017 8:50 am
Surely a take-off at empty weight on three engines, with enough fuel to get to Iceland, then Prestwick, and then on to Toulouse is possible? It would just need reduced thrust on engine number 2, to compensate for having no engine number 4. It could probably even take off as a twin at a push at these low weights, though I understand losing another engine on take-off would cause a problem.
Your computer just got better
7BOEING7
Wed Oct 18, 2017 12:19 am
Don't you mean reduced thrust on engine No 1? 747's back in the day did 3 engine JFK to LHR so the 380 should be able to get all the way without stopping I would think.
Klaus
Wed Oct 18, 2017 3:25 pm
I'd think it makes a difference when the engine quits. Taking off with a full fuel load and then losing one is one thing, but trying to get takeoff clearance with just three of four engines operational to begin with would be very different.
itchief
Wed Oct 18, 2017 3:43 pm
I hope you understand I am referring to a spare engine as the weighted slug. A spare engine is the proper weight and has the proper mounting points already built into it along with the correct aerodynamics.
boeing767300
Wed Oct 18, 2017 4:42 pm
Is the aircraft still on the ground at Goose Bay?
7BOEING7
Wed Oct 18, 2017 5:22 pm
I wasn't talking about passenger flights, but 3 engine ferry flights which Boeing was under contract to do for BA and several other airlines -- 2 engine ferry flights for 727's also.
iahcsr
Wed Oct 18, 2017 6:30 pm
Indeed it is
uta999
Wed Nov 08, 2017 10:41 am
Is AF any nearer getting this bird back to France for repair, or will some of the repair be carried out at Goose Bay? What is the latest plan, and has any work been done yet to remove the engine?
It must be costing AF quite a bit just sitting there getting cold.
PanHAM
Wed Nov 08, 2017 12:22 pm
Somehow related, famous Spantax once tried to Ferry a CV990 from STO to ZRH with only 3 engines. Unfortunately that flight crashed on take off.
Was Erlauben Erdogan!!!
SheikhDjibouti
Wed Nov 08, 2017 6:56 pm
That's just teasing everybody.
On the basis that hardly anyone here can even remember Spantax, how about some bullet-points to help us out?
1) It took off with three crew, plus seven passengers (!)
2) The crash was NOT attributed directly to the missing engine.
3) The remaining three engines did not fail, although one was throttled back slightly to reduce yawing on take-off.
4) Atmospheric conditions were far from ideal. Strong winds, wind shear, extreme temperature inversion ( -27 °C )
PROBABLE CAUSE:
5a) Unexpected early loss of external visual reference after take-off and loss of directional control during transition from visual to instrument flying.
5b) Windshear.
Then there is the aftermath of the crash.
Although the crash site was only 1800 metres from the runway, Swedish emergency services took four hours to reach the plane.
The statistics state that 5 died/ 5 survived. Reading between the lines, some of those that died could have lost their lives due to frostbite!
:cry:
I promised myself I'd leave before the party turned ugly. I would quit at 1000 !
Here I am stuck at 994; each time I'm tempted to post, I find myself wondering who will even read it / what is the point?
Or maybe I've just got nothing left to say.
Planesmart
Wed Nov 08, 2017 8:51 pm
AF would need one off insurance for such a ferry flight, and approval to overfly various countries airspace, which would be prohibitively expensive. Even if obtained, inspections would need to be done. And no way would the remains of the engine be permitted to stay on the wing.
aerolimani
Wed Nov 08, 2017 9:29 pm
I believe it is already the plan to attach a new engine, but fly with it non-functioning. Essentially, it's there just for weight, balance, and aerodynamics. Not sure what the progress is on this, though.
https://www.reuters.com/article/us-air- ... SKBN1CF2RA
FlySSC
Wed Nov 08, 2017 10:09 pm
This is indeed the plan to ferry back F-HPJE to CDG.
According to the « Air & Cosmos » magazine (usually well informed), the « fake » engine that will be used for the flight back of F-HPJE will be taken on the A380 MSN4 F-WWDD that was flown recently to Le Bourget Air and Space Museum to be displayed.
<https://www.usinenouvelle.com/article/comment-l-airbus-a380-d-air-france-au-moteur-endommage-va-rentrer-en-france.N601213>
KarelXWB
Wed Nov 15, 2017 8:15 pm
Update:
The engine for the return ferry will be carried to Goose Bay on an An-124 on 24 Nov. The damaged engine will be transported to Cardiff on 25 Nov.
Schedule details and updates at https://blog.flightradar24.com/blog/air ... greenland/
https://twitter.com/flightradar24/statu ... 4523356165
KarelXWB
Tue Nov 21, 2017 8:15 pm
pugman211
Tue Nov 21, 2017 9:34 pm
And the pylon too plus some fairings and slats. It's turning out to be a fairly big job just for the ferry flight home
SheikhDjibouti
Tue Nov 21, 2017 10:27 pm
You are most probably correct, but it worries me that 50 days have elapsed and painfully slow progress is only being made at enormous cost & inconvenience. This is a FOUR engine a/c with a massive surplus of power when flying empty, that has already proved itself capable of flying on three engines whilst heavily loaded with pax.. What kind of sorry world have we arrived at where this ferry flight is such a problem?
ps on this occasion, the only two countries that absolutely need to agree this overflight are Canada (departure from Goose Bay over very sparsely populated land), and France.
iahcsr
Tue Nov 21, 2017 10:36 pm
Rather surprised there is a hanger large enough for a 380 at YYR.. unless it’s just the wing inside.
KarelXWB
Tue Nov 21, 2017 10:40 pm
Apparently several repairs to the wing have been performed.
KarelXWB
Tue Nov 21, 2017 10:43 pm
https://twitter.com/gilleslaurent81/sta ... 6869987330
D L X
Tue Nov 21, 2017 10:55 pm
Three engine takeoffs are tricky and dangerous. Assymmetrical thrust meets speeds too slow to correct with rudder. It's a different animal than landing a bird with three engines. Indeed, the amazing amount of thrust is part of the problem.
http://www.nytimes.com/1995/02/18/us/at ... -to-3.html
https://www.ntsb.gov/investigations/Acc ... R9506.aspx
SheikhDjibouti
Tue Nov 21, 2017 11:48 pm
Yes indeed, and likewise the Spantax CV990 mentioned earlier in the thread.
https://en.wikipedia.org/wiki/1970_Span ... vair_crash
Of course these are the two that made the headlines, not the thousands of similar events that passed without any problem.
In post #536 Revelation quoted CaptainDave detailing specific training and procedures to be used by this A380 ferry crew. I'm not certain how to provide a link back to that, but I'm sure it would be right up your street. Post #536
And God Bless you for mentioning the key issue of "asymmetric thrust"; you are only the third person to directly mention it, or eighth if you count indirect quotes by others.
Now if only I could remember who it was first mentioned it way back 1½months ago at the outset of this thread......
itisi
Wed Nov 22, 2017 12:10 am
Ask CI about three engine ferry flights.... 742F, Manila.
737-300/400/500 ... are NOT classics :)
