Will I Be On AA Or TWA
Sun Feb 24, 2002 1:45 am
We had booked our flight from STL-FLL on TWA. How can you tell whether it will be operated by TWA or AA like plane colours, crew, seats, etc.? Thanks!
SESGDL
RE: Will I Be On AA Or TWA
Sun Feb 24, 2002 2:14 am
Most likely a TWA/AA or TWA plane, but you could very well be put on AA.
aa777flyer
Sun Feb 24, 2002 2:59 am
It will be a TWA airplane/crew/seats....
The TSA was created to make the post office look efficient!
PSU.DTW.SCE
Sun Feb 24, 2002 8:48 am
All ops from STL with the exception of flights to JFK & one flight to TUL are all still "operated by TWA." The interior will resemble TWA, the crew will be TWA. Inflight services will resemble AA. The livery could be TWA, TWA/AA hybrid, or AA, but in either case it will still be an ex-TWA aircraft. STL is still isolated from the rest of AA's system.
flyaa757
Sun Feb 24, 2002 9:19 am
More than half of the ORD flights are switching to AA soon.
qfatwa
Sun Feb 24, 2002 10:22 am
The answer is even easier:
If the AA flight number is between AA2600 and AA3199 it is operated by the TWA STL based operation using original TWA aircraft.
AluminumShower
Sun Feb 24, 2002 3:17 pm
FlyAA757 is wrong, the aircraft flying STL-ORD is and will continue to be all TW aircraft.
