Alee
Aeronautical Question.
Sun Feb 24, 2002 2:58 pm
I want to know the difference between course and heading.
flightsimfreak
RE: Aeronautical Question.
Sun Feb 24, 2002 3:32 pm
Course is the path over the ground (wind can move you) and heading is the direction through the mass of air around you, sort of like airspeed VS groundspeed.
Bjones
Sun Feb 24, 2002 3:43 pm
Or more simply, heading is the direction the aircraft is pointing in and course is the actual direction it is travelling after the effect of winds.
NZ767
Sun Feb 24, 2002 3:56 pm
I second that Bjones.
There can be a few degrees difference between the two if winds are significant enough.
FredT
Mon Feb 25, 2002 3:03 am
Quite a few degrees in fact, especially in slower aircraft. Ever see an Il-2 do a slow 180 degree turn in a 25+K wind?  Big grin
Fred
