GSPSPOT
Re: MCI New Terminal Vote
Sat Nov 11, 2017 8:50 pm
sw733 wrote:
TWFlyGuy wrote:
LuvMoreMCI wrote:
Glad to see the terminal pass. What is causing the decrease in flights and passengers to the area? Metro area is growing much faster than STL area, but is lagging STL in flights.
In comparing to STL keep in mind that while growth is much stronger in KC, St Louis is still a bigger city overall. Also, STL terminal for WN is much more conducive to connections than MCI which helps drive some of the additional flying.
Yeah, KC vs STL is interesting...Kansas City is the largest city in Missouri, but the St. Louis metro area (MO/IL) is bigger than the KC metro area (MO/KS).
But which metro generates more business travel and/or has not only more warm bodies, but more people who can afford to fly for leisure?
Great Lakes, great life.
atypical
Re: Kansas City passes new terminal for MCI Airport
Sun Nov 12, 2017 12:05 am
NZ321 wrote:
Call it wishful thinking :) but now there is opportunity for MCI to be a hub city for midwest flights.
OKC, DSM, OMA, LNK, CID, FSD, SUX, ICT, ROC, MSN, GBD, GCK, SLN, TUL, FSM, SGF, LIT, LBF, RAP, AMA, FSM, JAN..... for example. For a number of these regional cities MCI would be a more convenient and shorter connection point than backtracking to ORD, DFW, DEN.
MCI could then field more frequency on key routes to major coastal cities. With an efficient connection terminal a lot more is possible.
MCI is never going to justify the levels of service that can be at ORD, DFW, and DEN. Unless they can do that chances it will be more inconvenient regardless of backtracking or not. From OKC to ORD, DFW, and DEN there are a minimum of 7 flights a day to each. OKC may get 3 flights a day to MCI but that would be max. 3 flights a day would have to compete against 21 other flights so the O & D needs to be healthy on any routes because making a bet on connections is a good way to lose a lot of money fast. Not a ding against the airport or area, it just does not have the critical mass needed to make it a decent hub.
Jshank83
Re: Updated: MCI New Terminal Vote Passed
Fri Dec 15, 2017 4:10 am
Looks like the Kansas City city council isn't going to make things easy. Rejected the MOU with Edgemoor today.
http://www.kansascity.com/opinion/edito ... 96119.html
blhp68
Fri Dec 15, 2017 9:04 pm
I was actually at one of the open house events that Edgemeoor has been putting on, right as this was all going down. They had to come up and tell everyone it was cancelled. Super awkward.
Jshank83
Fri Dec 15, 2017 11:01 pm
oh man, that sucks. It sounds like it is a mess.
blhp68
Fri Feb 09, 2018 5:47 pm
MOU has advanced out of the council, paving the way for the next steps with Edgemoor. I was in attendance at city council, 90 minutes of debate with plenty of theater. Whew!
http://www.kansascity.com/news/politics ... 96599.html
RJNUT
Fri Feb 09, 2018 6:04 pm
Ironically "NO" votes came from ALL council members who represent the Northland , where the airport is located. Just astoundingly foolish. There is going to be a movement, I have read, to unseat those councilmembers , primarily based on their resistance to this project.
ADrum23
Fri Feb 09, 2018 6:48 pm
Why are they resisting the project so much?
