• 1
  • 3
  • 4
  • 5
  • 6
  • 7
Revelation
Re: Lithium-ion battery fails on UA 787 flight
Thu Dec 07, 2017 1:26 pm
747classic wrote:
Seen the history of 787 main battery issues It should have been SOP to report the main battery failure frequency to the FAA and the NTSB
And that's what happened: NTSB was informed.
Both NTSB and Boeing agreed that by NTSB rules ( ref: https://www.ecfr.gov/cgi-bin/text-idx?S ... 9.7.830_15 ) this was not a "reportable" incident, but that is a very specific term to them.
For the rest of us, we should just say NTSB was informed, and move on.
The heart has it's beaches, it's homeland and thoughts of it's own
The heart has it's seasons, it's evenings and songs of it's own
747classic
Thu Dec 07, 2017 1:42 pm
That's not what I wrote down.
In this particular occurance the NTSB was informed.
SOP means : report every 787main battery failure to the authorities to establish a failure rate (or are both the FAA and the NTSB not interested ?).
Operating a twin over the ocean, you're always one engine failure from a total emergency.
Revelation
Thu Dec 07, 2017 2:03 pm
SOP means : report every 787main battery failure to establish a failure rate to the authorities (or are both the FAA and the NTSB not interested ?).
In this context, "reporting" is what is used to decide to trigger an official investigation or not.
In this case both Boeing and NTSB has told us that this event did not meet that criteria.
As for less official reporting methods, we've been told they are in use.
As for gathering failure rate data, I'm not sure of what the requirements are.
Does government regulators gather failure rate data on other things (let's say, tire blowouts) to establish a baseline?
Do we know if such monitoring is or is not happening for batteries?
SheikhDjibouti
Thu Dec 07, 2017 2:38 pm
747classic wrote:
The main battery provides backup power for critical systems during flight in the extremely unlikely event of a total electrical power failure.(e.g.all six generators unable to provide electrical pwr), it's a certification requirement.
Firstly, there are TWO main batteries; one at the front, one at the rear.
I'm guessing (or I have read it somewhere) that the one at the front backs-up the cockpit critical systems.
The one at the rear primarily starts up the APU. It probably also covers some critical systems. But it seems sensible if there is also a connection between the two batteries.
Except DC voltage doesn't travel too well, and low DC voltages fare even worse. (just ask Thomas Edison). There are tricks to get around this problem; I don't know if they have them on-board a 787.
As for "six generators"; that is another bit of publicity speak. It's technically correct, but two of them are on each engine, and two driven by the APU. So it's three pairs.
If you have a double-engine failure, you have lost four generators.
You then need a fully functioning battery to start the APU, in order that the other two generators can re-charge the battery. This is a bit of a Catch-22.
It's at this point you are suddenly 100% relying on the RAT (Ram Air Turbine)
And that is exactly why we have these back-up systems. :D
I promised myself I'd leave before the party turned ugly. I would quit at 1000 !
Here I am stuck at 994; each time I'm tempted to post, I find myself wondering who will even read it / what is the point?
Or maybe I've just got nothing left to say.
747classic
I would welcome a more open attitude of both the FAA and NTSB in this case, seen the history of this type of main battery.
LI-ION has a bad name in aviation, after the "high profile"delayed 787 certification and numereous incidents with smaller (laptop) batteries, especially when carried in large quantities as cargo..
Publication of the actual 787 main battery failure rate, the required failure rate and a comparison with other main battery failure rates at other aircraft types would restore the convidence in this important "back up system".
SheikhDjibouti
Thu Dec 07, 2017 2:54 pm
Don't worry about it; I've had exactly the same problem myself. :lol:
If it helps, earlier Rev wrote
It should {end the argument}, but this is a.net, so we're going to revisit 2013 and earlier time and time again.
Some of us here want to examine the big picture; some of us want to focus on this failure in isolation.
To be fair; the thread title is quite specific....
Meh; everybody has their own agenda.
ps; I've also got a small wager with myself running on this - more on that later.
Revelation
Thu Dec 07, 2017 3:52 pm
I think people are jumping from "this is not a reportable incident according to NTSB rules" to "FAA and NTSB have the wrong attitude when it comes to Li-Ion batteries". Not sure why this is.
Publication of the actual 787 main battery failure rate, the required failure rate and a comparison with other main battery failure rates at other aircraft types would restore the confidence in this important "back up system".
The main failure rate to be tracked is that of the containment system, and so far the failure rate is 0%.
WIederling
Thu Dec 07, 2017 3:57 pm
Case in point:
The Transat A330 out of fuel dead stick landing at Lajes air base
replicated with a 787 could probably have been done
but would require the working battery to not kill all aboard from overshooting the runway ( see, no brake!)
As the APU battery can be MEL it seem to play no role in supplying juice to the electric brake.
Question is if the failure rate of these batteries is sufficiently low to show the emergency provisions to be valid.
immediate endangering the plane from failure uncontained or not does not play into this question.
Murphy is an optimist
Stitch
Thu Dec 07, 2017 4:54 pm
enzo011 wrote:
Has the failure rate calculations changed from when the 787 was certified? Or are they still predicting the failures at the rate as before the 2013 problems?
I don't know, but I would not be surprised if it is less conservative (predictive of a higher failure rate) than before. There have been over one million revenue flights so they should be generating more accurate models for the MTBF.
dtw2hyd wrote:
What good is a toasted main battery in a box?
Failure analysis via post-mortem.
WIederling wrote:
Case in point: The Transat A330 out of fuel dead stick landing at Lajes air base replicated with a 787 could probably have been done but would require the working battery to not kill all aboard from overshooting the runway ( see, no brake!)
LN002 successfully landed at Laredo International on the RAT and their runways are between 650m and 1500m shorter than Lajes Field where TS236 landed.
WIederling wrote:
Question is if the failure rate of these batteries is sufficiently low to show the emergency provisions to be valid. Immediate endangering the plane from failure uncontained or not does not play into this question.
The certification program would have taken into account a RAT-only landing, just as certification takes into account landing in an airframe with hydraulically-actuated brakes where the hydraulics have failed.
WIederling
Thu Dec 07, 2017 5:09 pm
with running engines. the RAT dropped out from the short circuit. We actually don't know on which path brake energy was sourced.
Anyway, they hadn't lost the battery.
and the battery is integral to this certification.
just like the hydraulic backup pressure storage on the Airbus A380.. (LEHGS)
if the battery availability turns out to be below expectations in scope of the certification ..
That again is why I think cell failure (incidence and mechanism) is of interest well beyond this being contained or not.
in context this might be of interest ( not read yet ):
http://www.ncl.ac.uk/media/wwwnclacuk/s ... per20a.pdf
http://www.icas.org/media/pdf/Workshops ... ublish.pdf
http://www.fzt.haw-hamburg.de/pers/Scho ... ngGear.pdf
Stitch
Thu Dec 07, 2017 5:29 pm
No but they had lost the power distribution panels so that electricity produced by the engines and the APU, as well as that stored in the battery, wasn't going to a fair number of systems including at least some flight and engine controls that are electrically-operated. Hence why the RAT deployed. That being said, since the engines were running, reverse thrust likely would have been available (unless it was disabled by the electrical faults).
trex8
Thu Dec 07, 2017 5:45 pm
Isnt that like saying if the engine nacelle casing has no penetration from the blades coming off we dont care what caused the blades to come off as the failure rate for the casing is zero????
Stitch
Thu Dec 07, 2017 5:56 pm
From a flight-safety standpoint, you could argue "yes" since the nacelle casing has contained the blade-off as designed and the airframe continued on and landed safely.
However, the airline is not going to be pleased with the downtime of swapping the failed engine and nacelle casing and the engine manufacturer is not going to be pleased with the costs of replacing said engine as well as any penalties owed for the aircraft being out of service during that period. So if nothing else, the engine manufacturer will care what caused the blade to come off to try and prevent it from happening again, but I also expect the airline will care as if the currently-operated engine family is more-likely to suffer a blade-out then another, that will influence their future engine selections to some extent which could be bad for the current provider.
Same with the battery. The Safety Authorities may be satisfied that the battery failure did not affect the safety of the flight, but UA won't be satisfied about having the plane out of service for the replacement and the battery unit vendor won't be satisfied having to replace it and compensate United. So the battery unit vendor will be reviewing the unit once it is returned to try and identify what caused the failure and remediate it going forward.
747classic
Thu Dec 07, 2017 8:08 pm
If a battery fails , contained or not contained , this failure will be added to the battery failure rate.
The containment has only been installed because a violant battery runaway (failure) could cause an immediate emergency situation.
B737900ER
Thu Dec 07, 2017 9:58 pm
QueenoftheSkies wrote:
Umm maybe so that they don’t fail in the first place? I mean yea the containment works but that’s a bandaid to the real issue. They never really solved the problem. It’s not a safety issue? Potential for repeat incidents of what caused this containment “solution” are most definitely a safety issue.
Then you can’t have avation. Things fail all the time and in potentially big ways. The key is containing the failure. You will never solve the problem of failures anywhere.
ER757
Thu Dec 07, 2017 11:52 pm
Very well said, Stitch - this post sums up the whole situation - the thread should end here, and I am NOT being sarcastic.
iamlucky13
Fri Dec 08, 2017 12:31 am
If the blade failure is required to be reportable, however, there is a difference. I'm not certain one way or the other, but I assumed it was.
Speaking mostly for trex8's sake, I presume the reason for this would be as I suggested earlier - a blade failure leads to a loss of flight performance and generates "contained" debris, both of which can potentially lead directly to worse consequences. A contained battery failure does not. In the close scrutiny that the grounding drew to this issue, they even went as far as analyzing whether there was a risk of re-ingestion of the vented gases by other systems (I assume the intakes for cabin air were one of those considered) and what the consequences of that could be.
Rather, a contained battery failure is, if WIederling is correct that the generator on the RAT can not power the brakes, and assuming the APU battery can not either, a reduction in redundancy, which could only lead indirectly to worse consequences.
Stitch
Fri Dec 08, 2017 12:51 am
I expect it is, as well.
But the crux is that if the NTSB viewed a battery venting event as something worth being reported, it would be. They make the rules (in conjunction with the FAA). Boeing doesn't get to decide. Nor Thales. Nor GS Yuasa. Boeing reported it as a "courtesy", but they might very well have a policy to report all such events even if not required to.
7BOEING7
Fri Dec 08, 2017 3:30 am
Cheat sheet for reporting. Maybe slightly out of date but gives you the general idea of who is looking for what
F=FAA (Part 21.3)
N=NTSB SEct 830.5)
Aircraft accident F N
Fire/Inflight Fire F N
Smoke/Fumes Toxic Gases F
Flight Controls Interference F
Flight Controls Malfunction/Failure F N
Engine Failure F
Engine Structural Failure F N
Sustained Loss of Thrust N
Electrical Use of Backup System N
Electrical Loss of More Than One System F
Hydraulic failure/Reliance on Single System N
Hydraulic Loss of More Than One System F
Brake System Failure F
Loss of More Than One Primary Flight Instrument F
Flammable Fluid Leak F
Structural Defect/Failure F
Abnormal Vibration/Buffet F
Near Miss F
Inflight Collision F N
Emergency Evac N
Crewmember incapacitated N
Dropped Object F
Bird Strike F
Wake Turbulence in RVSM F
Laser Emcounter F
Property damage > $25,000 N
MatthewDB
Fri Dec 08, 2017 7:10 am
So, why is nobody mentioning Ni-MH? (apart from myself).
Ni-MH is pretty good for most household applications. But they perform poorly at low temperature.
All battery types perform less well as temperature drops well below freezing. But in this respect Ni-MH is pretty much inferior to Ni-Cd and Lead-Acid. And of course also Li-Ion.
Ni-NH never replaced Ni-Cd on planes because when parked overnight on a cold winter night the Ni-Cd battery vastly outperforms Ni-MH.
Thank you, I was curious about that myself. NiMH dominated the first decade of hybrid vehicles. The batteries in that application fared very well, with battery failures being very rare. Of course, one of the advantages of a hybrid vehicle is that the engine can be started at any time if the battery isn't keeping up.
MatthewDB
Fri Dec 08, 2017 7:27 am
WIederling wrote:
They'd have some difficulty. Battery capacity is needed for an engine out landing as braking is fully electric actuation.
Below where the RAT is effective braking to a standstill requires most of the "very short term" available battery capacity.
( much less then nominal (1/5th 1/10th C discharge) capacity.
Engine start puts similar loads on the battery. After that you need to fast charge the batpack to be able to brake in an emergency.
incompatibility with ground power units aggravated this use case. Instead of starting from ground power crews started from bat power.
Why is engine start on the 787 any harder than any other aircraft? Boeing's page says that the main engines start on APU power, ground power and / or the other engine:
http://www.boeing.com/commercial/aeroma ... _02_4.html
The power source for engine starting may be the APU generators, engine-driven generators on the opposite side engine, or two forward 115 VAC ground power sources. The aft external power receptacles may be used for a faster start, if desired.
The batteries are used to start the APU, just like any other aircraft. Only the method of starting (permanent magnet alternator used as a synchronous motor vs. a DC starter motor) is different.
WIederling
Fri Dec 08, 2017 9:31 am
As far as I understood this:
due to the high electric power but no air power demand a single GPU unit was not sufficient to start an engine.
syncing two GPU units and the solid state 3ph AC infrastructure on board was problematic ( killing GPU units ).
"Simple" solution was : Start APU from battery, Start one engine from APU ...
( afair both battery nonfires started about 30..45 minutes after the APU was started/used ).
MatthewDB
Fri Dec 08, 2017 2:35 pm
So I'm not getting how that makes a 787 unique in the battery demand. AFAIK, ground air start is rare, most of the time all large aircraft use APU start. All that is unique is that the 787 APU generator is the motor instead of a DC start motor and the APU generator has to power the engine start vs. the conventional pnumatic bleed from the APU.
Either way, battery starts APU, APU starts engine.
Revelation
Fri Dec 08, 2017 2:48 pm
Yes, that is the primary case, but it seems the secondary case of ground start using GPU (due to APU unserviceable which is allowed on MEL) occurs frequently enough to be an issue. Not sure if there is actual data available on this or not.
MatthewDB
Fri Dec 08, 2017 5:37 pm
Does anyone know if the battery assists the GPU in getting the engine started? If that was the case, it would make sense that starting the first of the two engines would be hard on the batteries too.
7BOEING7
Fri Dec 08, 2017 6:05 pm
No, it doesn't
BREECH
Sat Dec 09, 2017 8:44 am
B737900ER wrote:
The arguments on this tread are getting silly. How about we just don’t fly, stop improving technology, and stay in our padded rooms with no windows where we know it’s 100% safe.
How about we kindly ask American aircraft manufacturers to test a technology before using it and build planes that don't catch fire instead? Like, I don't know, European manufacturers? Maybe think less about "bottomline" and a bit more about passengers safety? And maybe not allow the management of the companies they buy to take over and turn their own into a lying, deceitful, irresponsible, greedy ghoul? Without any undue respect, Boeing is now run by the same people who lied to FAA about fixing the DC-10 cargo door leading to deaths of hundreds of people on at least two flights.
No friendship, love or respect unite people as much as shared hatred.
Sergey Dovlatov
SheikhDjibouti
Sat Dec 09, 2017 10:23 am
I think you are going a bit OTT there, although the DC-10 reference has peaked my interest just for curiosity sake.
Meanwhile, if you push the "European design is safer" angle, it's bound to bite you in the ass one day soon.
A more moderate line would perhaps be more appropriate. Just my two drachma.
Balerit
Sat Dec 09, 2017 11:40 am
This thread is getting a bit tedious. What would you do if your cars' battery kept blowing up? Would you ask for your money back or would you rather buy a different make of car? Or would you insist that they install another battery in the boot or tell them to just fix the bloody problem? But they way people are arguing here it sounds like you'll just accept the situation and keep replacing the battery every time it blows up. The reality is that the car manufacturer would recall every single car and have them fixed.
Trying to compare this to engine failures is totally irrelevant, engines packed up from the early days, so more engines were fitted just in case. If this must be treated equaly to engine failures then Boeing must double up on the batteries - maybe even have triple redundancy, knowing that this aircraft relies more on electrics than hydraulics, which would defeat the object in the first place. I think the problem is the FAA don't know how to handle this and by making it non reportable is akin to them burying their heads in the sand and hoping this doesn't come up again.
This whole battery saga to me is exactly the same as the fatigue cracks that downed the Comet airliner. If they don't want to fix this properly then I think the airlines should say in the small print on your ticket: There is a possibility that the battery may explode and there are no parachutes under your seat. 'sarcasm off.'
Licensed Aircraft Maintenance Engineer (retired).
Revelation
Sat Dec 09, 2017 12:04 pm
We should not compare the battery issue to an engine failure, we should instead compare it to a structural failure?
Really?
You do realize the Comet crashes killed everyone on board, twice, and the uncontained battery failures killed no one, and there now is containment that has just been shown to be effective, no?
Revelation
Sat Dec 09, 2017 12:16 pm
Indeed.
One post mentions the superiority of European design and manufacture, then the next talks about Comet structural failures.
At the same time the Trent engines are ejecting turbine parts at an alarming rate, I guess someone should kindly ask them to test their technology a bit before deploying it.
Either that, or we should just go with the line that the Brits aren't Europeans anyways.
Personally I doubt any of the "same people" who were senior enough at MDD to be interviewed by the FAA in the 1970s are still of working age, they're retired or dead.
And so, this thread is worse than tedious, it's rubbish.
scbriml
Sat Dec 09, 2017 12:41 pm
All some of us have been arguing is that this isn't a flight safety issue, it's a reliability issue. And yes, if the airlines are unhappy with the rate of battery failures/replacements and the cost of interruptions to their schedules, they should be hammering Boeing for a solution.
StTim
Sat Dec 09, 2017 12:55 pm
Indeed.
Yes when I read that I though people and glass houses. Even the mighty respectable pillars of quality being German and Japanese engineers have recently had their halos damaged somewhat (I am thinking the VW emissions scandal and the Japanese metal producer who has admitted falsifying test results).
Balerit
Sat Dec 09, 2017 2:16 pm
Well I beg to differ, it is a serious flight safety issue considering that the whole concept of the B787 was the move towards electrics rather than hydraulics or pneumatics. Boeing put an aircraft into production using untried technology and so far we are lucky these incidents have occurred on the ground.
WIederling
Sat Dec 09, 2017 2:36 pm
https://gizmodo.com/faa-is-doing-nothin ... 1738751945
Looks like battery decompositions are less rare than thought ore presented.
SheikhDjibouti
Sat Dec 09, 2017 2:39 pm
Yes, maybe, and no. In that order.
All the way back at the beginning, poster#1 wrote:
A United Airlines Boeing 787 experienced a lithium-ion battery failure on approach to Charles de Gaulle Airport on November 13. United Flight 915 was at the end of a seven-hour flight from Washington's Dulles Airport when ....
Revelation
I guess you're not reading along.
The technology in the Boeing batteries is not "untried technology". It was in use in the Space Station before Boeing used it.
This incident occurred in the air, not "on the ground", and the containment system worked as designed, so no "serious flight safety issue" occurred.
scbriml
Sat Dec 09, 2017 3:10 pm
OK, in what way is it a "serious" flight safety issue if the containment is working as designed?
WIederling wrote:
https://gizmodo.com/faa-is-doing-nothing-about-continued-boeing-dreamliner-1738751945
Hmmm. That's a two year old article with no numbers or sources to back up the claims of "one failure per thousand". Poor journalism, frankly.
WIederling
Sat Dec 09, 2017 3:37 pm
What ever. Christine Negroni isn't really know for dilettante journalism.
It places some additional incidents into the timeframe 2014 .. 2017
certainly:
Failures in these batteries typically come at a rate of one in five million. But the Dreamliner lithium-ions are failing at a shockingly high rate of one in a thousand.
is a bit unspecific. failures per $what? item, hours.
"unreportable" is a rather insidious way of getting the issue out of sight.
2175301
Sat Dec 09, 2017 4:07 pm
Indeed.
Lets get the facts straight here: Thales Avionics - A highly respected FRENCH Aerospace electrical system supplier (which Airbus also uses), selects GS Yuasa - A highly respected JAPANESE Battery supplier with a history of supplying aerospace batteries (which I suspect that Airbus also uses) for use in the 787 electrical system that Thales is designing for the 787 (same as Thales designs electrical systems for Airbus). Then the end result for some is that this is all Boeing and American engineering and regulatory shortfalls.
Did I miss anything?
In my opinion: the real issues here lie with GS Yuasa and Thales (Japanese and French companies and engineers). I speak as one who sells professional design services to Nuclear Power Plants (I am a registered Professional Engineer). When a plant contracts with me - I'm both morally and legally responsible for getting the design and component selection right... Not the company that hired me to do that. It is me and my companie's "Errors and Omissions" insurance policy that is responsible for mistakes (and PE Errors and Omission Insurance is expensive for a reason). If I make a mistake - I may never be insurable again as a PE.
Similar to the Aircraft Certification by FAA, etc. A Nuclear Power Plant may have to submit my design to the NRC, etc. for approval as part of their operating license. NRC, etc. approval does not release me from my legal and moral responsibilities.
Have a great day,
WIederling
Sat Dec 09, 2017 4:25 pm
YES there is no indication
that Thales selected the Yuasa Japan cells,
that Thales sected Yuasa USA for the enclosure nor
that Thales selected a hobbyist outfit for designing the charger.
Proof: Historically: If Boeing has even a minimal chance of moving blame to another party they will do so.
What happened here is they upended the cesspot on Yuasa Japan.
Revelation
Sat Dec 09, 2017 4:31 pm
And yet Boeing DID report it to NTSB, so they're nefarious, but they're just not very good at being nefarious?
Seriously, maybe Boeing should have just filled in the damn NTSB forms so we could put all these wild-eyed accusations to rest.
Repeat after me: The NTSB knows about this incident. The NTSB knows about this incident. The NTSB knows about this incident.
SheikhDjibouti
Sat Dec 09, 2017 4:42 pm
You equate the Power Plant as Boeing, and you as Thales/Yuasa.
I'm seeing it differently
I equate the Power Plant as the operating airline, you are Boeing, and the components you select equate to Thales/Yuasa.
As you say; you/Boeing are "both morally & legally responsible for getting the design & component selection right"
SheikhDjibouti
Sat Dec 09, 2017 4:54 pm
Repeat after me: "...a very broad claim based on one incident"...... "a very broad claim based on one incident"........"a very broad claim based on one incident"
You do remember writing those exact words earlier in this thread, don't you Rev?
scbriml
Sat Dec 09, 2017 5:03 pm
WIederling wrote:
certainly:
As I said, poor journalism.
Yet the NTSB were notified and we all know about this incident, so it's hardly "out of sight", is it? What is your real issue with it?
2175301
Sat Dec 09, 2017 5:16 pm
See the link below for an indication of who selected who:
http://www.gsyuasa-lp.com/content/thale ... dreamliner
You are correct that historically ALL companies shift responsibility (Airbus does the same). They hire recognized experts in specialized areas who then have the responsibility. This is standard business practice with appropriate legal separation of responsibilities. Boeing hired Thales to design the electrical system. Thales chose Yuasa and did the prototype testing and chose the final design working with Yuasa. Boeing (and other companies) has oversight; but, would rarely have the expertise to validate details of a design submitted by an expert who claims it meets the required criteria. The entire industry has found that it is far cheaper to have companies like Thales and Yuasa than for them to become experts and own production facilities for everything.
Have a great day,
2175301
Sat Dec 09, 2017 5:26 pm
Totally; my analogy on responsibility is correct and your's is not: Boeing, Airbus, and virtually all companies hire expert subcontractors to design and supply things... That is standard business practice as no company can afford to become experts and produce everything. Legal standards also reflect the division of responsibility. Boeing (Airbus, etc) have general oversight; but, is not expected to have the expertise to validate detailed design decisions by an expert. Boeing (or Airbus) would be expected to see things such as that the battery capacity was only 80% of what was needed (if that occurred). There are no indications to me in this situation of the kind of errors a company providing general oversight should have noticed.
We will probably never know the details: But, I am sure that both Thales and Yuasa took a solid financial hit with the initial problems, and if the batteries are failing at an unacceptable rate that Yuasa is still taking a financial hit.
Have a great day,
Revelation
Sat Dec 09, 2017 6:01 pm
I don't see what my response to an asinine Nightmareliner comment three days ago has to do with how incidents are reported to the NTSB.
I see you've launched your entry into the "most obtuse comment in this thread" contest, but, sadly, it's not even a contender for the title.
I'd give it dishonorable mention, however.
SheikhDjibouti
Sat Dec 09, 2017 6:12 pm
Isn't that the truth! ;)
Planesmart
Mon Dec 11, 2017 4:49 am
If it was as simple as THE battery, it would have been fixed by changing the battery design.
Just like finance, insurance and processes, it's not black and white.
So it must be the thousands of permutations and algorithms that manage the battery. The battery management system (BMS), which handles temperature, voltage, reporting, healing, cell interaction, cycles, and increasingly can forecast problems.
The physical containment system recognises the current BMS database hasn't been developed yet to the point a physical fail-safe system is no longer required. Failure is a natural part of learning, as long as the risks of failure are mitigated.
I would have thought all parties are ticking the appropriate boxes.
Must have been paying attention at a meeting of aviation leasing & finance participants recently which included a presentation on IEC standards.
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
