capitalflyer
JFK Diverting Flights due to shear
Fri Jan 12, 2018 4:41 pm
EDV 3515 has diverted to IAD after missed approach at JFK. OZ 222 also missed approach as well as TAM 8102. Tower reporting gain of 20-35 knots
capitalflyer
Re: JFK Diverting Flights due to shear
Fri Jan 12, 2018 4:42 pm
In addition, Virgin 3N is leaking fuel on approach.
N62NA
Fri Jan 12, 2018 4:44 pm
Sounds like a busy day "at the office" there at JFK today.
How come I can't upload an avatar photo to my profile?
ilovelamp
Fri Jan 12, 2018 4:45 pm
That and RVR is down to 600-700. Probably the main reason EDV diverted since that’s way below their mins.
capitalflyer
Fri Jan 12, 2018 4:46 pm
Landed uneventfully
capitalflyer
Fri Jan 12, 2018 4:51 pm
OZ 222 trying again. And in.
Issue is also RVR - Runway Visual Range. Only around 1000 feet and when combined with shear below threshold for some.
capitalflyer
Fri Jan 12, 2018 4:53 pm
It appears TAM 8102 has diverted to IAD as well.
capitalflyer
Fri Jan 12, 2018 5:19 pm
CX830 just missed approach, going around for 2nd attempt.
capitalflyer
Fri Jan 12, 2018 5:20 pm
AF022 missed approach, going around for 2nd attempt.
flyguy84
Fri Jan 12, 2018 5:26 pm
KAL081 going missed, wind shear.
CapitalAvGeek
Fri Jan 12, 2018 5:31 pm
CX830 diverting to IAD
capitalflyer
B6 717 going around, as well as AA67, SU100, KE081, ...
Atlwarrior
Fri Jan 12, 2018 5:33 pm
Yikes delays over 2 hours now.
capitalflyer
Fri Jan 12, 2018 5:34 pm
B6 717 is headed back to BOS (oh boy), and CX830 looks like it is headed to IAD.
CapitalAvGeek
Fri Jan 12, 2018 5:38 pm
Now MU587 is diverting to IAD after only a couple of circles.
capitalflyer
Fri Jan 12, 2018 5:42 pm
JFK has had a bad January to say the least.
Atlwarrior
Fri Jan 12, 2018 5:48 pm
KAL 081 should just go to ATL, it appears to keep circling.
readytotaxi
Fri Jan 12, 2018 5:51 pm
WN1555 must have done 10 laps above ISP now diverting IAD. Going back further than where they started from. :(
Growing older, but not up.
aemoreira1981
Fri Jan 12, 2018 5:58 pm
I should also note that JFK is inundated with fog and rain, leaving only the 22s as available for use with winds from the south.
AF22, SU100, and KE81 all landed on their second attempts after circling.
In another hour, the airfield will completely go to pot with heavy rains, which are already battering EWR.
GolfBravoRomeo
Fri Jan 12, 2018 6:48 pm
BA 117 diverted to BOS an is headed back to JFK after an an hour and half on the ground.
devron
Fri Jan 12, 2018 6:49 pm
B6 502 also going to BOS but seems to be under control now
flymco753
Fri Jan 12, 2018 6:51 pm
I believe more snow is on tap for the NYC Area? Hopefully everything goes smooth than or we have a repeat of what happened last week.
Whether you're here on business, returning home, or visiting our world class attractions, welcome to Orlando and Central Florida...
danj555
Fri Jan 12, 2018 6:55 pm
Will the a380s have any trouble?
shantahan
Fri Jan 12, 2018 7:05 pm
Jetblue 26 diverted to ewr
Tpa-jfk
shantahan
Fri Jan 12, 2018 7:10 pm
EK201, an a380 from DXB, is on approach now
shantahan
Fri Jan 12, 2018 7:16 pm
AM408, B788, diverted to IAD
MEX-JFK
neomax
Fri Jan 12, 2018 7:17 pm
That is the understatement of the century, and we’re not even halfway through January!
Super80Fan
Where's the usual suspects saying "Jetblue should be in complete control of this"?
RIP McDonnell Douglas
shantahan
Fri Jan 12, 2018 7:25 pm
AM414, E190, diverted to EWR
MTY-JFK
aemoreira1981
Fri Jan 12, 2018 7:50 pm
All rain since it's about 60 degrees. However, tomorrow night, it dips back to 15 degrees. (All temps Fahrenheit.)
At least with diversions to Newark, passengers can choose to terminate there and take the train to NYC. This also underscores the need for a new Terminal A at EWR.
DiamondFlyer
Fri Jan 12, 2018 7:51 pm
As if that's an 9E problem. That's Cat 3 category level ILS. Very few regional airlines are equipped for that
From my cold, dead hands
m0ssy
Fri Jan 12, 2018 7:54 pm
I'm sure if it was ATL it would all be Delta's fault too, since they control the weather down there as well. :roll: ;)
:duck:
ilovelamp
Fri Jan 12, 2018 7:58 pm
I’m well aware of that. I didn’t say they were the only one impacted by the low RVR. They were the only regional flight mentioned in the OP.
capitalflyer
Fri Jan 12, 2018 8:38 pm
AA148 just missed approach.
devron
Fri Jan 12, 2018 9:24 pm
and now B6 1528
devron
Fri Jan 12, 2018 9:30 pm
B6 502 and B6 26 seem to be on the road agian from BOS and EWR
Brick
Fri Jan 12, 2018 9:59 pm
jetBlue 26 is back in a holding pattern for JFK. Was diverted to EWR earlier (scheduled routing was TPA-JFK).
A noble spirit embiggens the smallest man...
jfklganyc
Fri Jan 12, 2018 10:14 pm
They stopped all arrivals and departures from 12-1230 ET today due to WS. Long taxi
Web500sjc
Fri Jan 12, 2018 10:19 pm
Generally CAT II and CAT III approaches are prohibited with reported wind shear.
Boiler Up!
richierich
Fri Jan 12, 2018 10:29 pm
If you are flying Delta mainline today from JFK, the great news is that your flight will very likely be operating. If you are flying on a DL regional today, please know that your flight was likely sacrificed to make said mainline flight operate and/or show optimal metrics. Please contact DL to rebook as, at best, your flight will be cancelled, but at worst you will be severely delayed and forced to spend hours of your time stuck inside the hell that is Terminal 2, or for the lucky few, crammed into a CRJ on the ramp.
None shall pass!!!!
Fri Jan 12, 2018 10:30 pm
I listened to the ATIS, didn’t hear LVP in force, and Wx at CAT1 minima. The b wind didn’t sound that bad, 190 18G24 with RW22L in use.
jfklganyc
Fri Jan 12, 2018 10:31 pm
Bingo. 15 kt xwind limitation on many types. Also limited with runway contamination.
Fri Jan 12, 2018 10:32 pm
It’s only 12kts crosswind on 22L with that gust value of 19G24.
william
Fri Jan 12, 2018 10:45 pm
Why land to the south with a tail wind when they can land toward the north and still not interfere with LGA?
arcticcruiser
Fri Jan 12, 2018 10:54 pm
You don't get the wind, do you? 190/18G24...
TOGA10
Fri Jan 12, 2018 11:01 pm
Why would an A380 be any different from the T7's, 747s, A320s etc etc?
The natural function of the wing is to soar upwards and carry that which is heavy up to the place where dwells the race of gods. More than any other thing that pertains to the body it partakes of the nature of the divine. - Plato
TW870
Fri Jan 12, 2018 11:03 pm
Looks like they sat at Dulles for 3 hours and went back to JFK, and after a few more circles are short final.
There is a break between lines right now so it looks like they are getting some of the diversions in, but all flights are held at origin until at least 6:30 eastern - so it is going to be a never ending night. What a horrible January in all ways for JFK.
AirbusMDCFAN
Fri Jan 12, 2018 11:04 pm
Sitting in the back of the aircraft complaining that they had a middle seat and were uncomfortable, and that the in-flight crew
should be bowing down to them and giving them comped drinks for the inconvenience of a roller coaster ride.
ucdtim17
Fri Jan 12, 2018 11:19 pm
Not worth its own thread but fog diversions at SFO today. LH A380 to OAK https://twitter.com/henrykleeKTVU/statu ... 8705204225
TK787
Fri Jan 12, 2018 11:57 pm
I have a 8:00am DL flight out of JFK. Looks like the weather is improving after 4am. Fingers crossed, I don't get delayed more than 3-4 hours :)
