MarkATL
Southwest Flt 8500 OAK-PAE 2/11/18
Sun Feb 11, 2018 11:25 pm
Today I was flying from OAK to BUR. At the next gate was WN8500 going to "Snohomish County Airport". Anyone know what this flight was?
SpaceshipDC10
Re: Southwest Flt 8500 OAK-PAE 2/11/18
Sun Feb 11, 2018 11:29 pm
Couldn't it be an aircraft ferry ? So far it doesn't show up on flightradar for today however there's been several WN8500 lately, but not on the West Coast: https://www.flightradar24.com/data/flights/wn8500
I have discovered that once people are truly captivated in their ignorance, they are generally unwilling to let the facts interfere.
(Rick Drury's Flightlines "Paychecks", Airways April 2003)
tb727
Mon Feb 12, 2018 1:26 am
Lots of maintenance work done at PAE. Used to be BF Goodrich, looks like it's called ATS now. You'll see a bunch of SWA on google earth there.
canyonblue17
Mon Feb 12, 2018 1:36 am
You will eventually see scheduled service to that airport, as Southwest has announced its intention to fly there when the new terminal is open for business. If you are not familiar, this airport is home to the Boeing big jet (777, 787, 747...etc) production facility. Also know as Paine Field.
negative ghostrider the pattern is full
7673mech
Mon Feb 12, 2018 1:47 am
It went for unscheduled maintenance.
gunsontheroof
Mon Feb 12, 2018 2:50 am
WN sends planes to PAE all the time for mx. If you're monitoring the SEA area on a tracking site, you'll see several PAE-bound flights in a given week. Many of them come straight over from SEA. I live almost exactly halfway between the runways at PAE and SEA and have actually seen WN birds (AS as well) level off from a SEA departure and immediately set up for a PAE approach during north-flow.
Picked a hell of a week to quit sniffing glue.
SeaDoo
Mon Feb 12, 2018 3:17 am
When I first saw the title, I thought it was going to be a PAE announcent, but after reading the title I would agree with the above about the ferry flight for maintenance.
rbavfan
Mon Feb 12, 2018 3:18 am
You see a bunch of many Boeing aircraft there. As it is where the 747/767/777/787 are built and final delivery services as well as refitting go on there.
tb727
Mon Feb 12, 2018 5:13 pm
Yes IIRC a lot of landing gear work was done up there on the 727's in my experience. Back in the day of course.
evank516
Mon Feb 12, 2018 7:18 pm
There's already been a PAE Announcement: https://myeverettnews.com/2018/01/25/so ... this-fall/
737max8
Mon Feb 12, 2018 10:49 pm
FYI 8000 flight numbers are charters/ferries/etc
The thoughts and opinions expressed in my comments do not represent that of any airline or affiliate.
Flown on: 717 733 734 735 736 737 738 739 7M8 744 744ER 752 753 762 763 772 773ER 788 789 A319/20/21 A332 A333 A343 A359 A388
ctrabs0114
Mon Feb 12, 2018 11:23 pm
8000-8200s are typically charters; 8500s and up, IINM, are typically ferries.
2018: BWI, PIT, MDW, MCI, STL, DAL, ATL, BNA
GCT64
Tue Feb 13, 2018 2:36 am
As examples, over the last couple of days there have been quite a few Southwest flights into PAE:
Sat evening: SWA8509 from SEA
Sun morning: SWA8500 from OAK (as mentioned)
Mon early hours: SWA8536 from SEA
Mon afternoon: SWA8700 from BFI (N8562Z? - delivery?)
Flown in: A30B,A306,A310,A319,A320,A321,A332,A333,A343,A346,A359,A388,BA11,BU31,B190,(..54 more types..),VC10,WESX
ctrabs0114
Tue Feb 13, 2018 2:53 am
WN8700 appears to be the primary 'ferry' flight from Boeing to WN, though they're flown from PAE to PHX instead of DAL from what I've seen on FlightRadar24:
https://www.flightradar24.com/data/flights/wn8700
Ships 8552, 8554-8558, 8560 and 8561 have since gone from SEA to PAE and on to PHX, typically within a week. as WN8700. N8553W ferried to PHX as WN8701, while N8559Q ferried as WN8703.
How many more 738s will WN be getting from this current order? N8563Z, N8564Z, N8565Z and N8566Z are the next ones due within a matter of weeks, depending on when they get the final signoff.
737max8
Wed Feb 14, 2018 4:37 am
Yup all -800s go from BFI-PAE-PHX
MAX go straight from BFI-PHX
Still a good handful of -800s to go. They will almost fill up the 85XX range
BoeingGuy
Wed Feb 14, 2018 6:09 am
I see AS and WN fly maintenance flights out of PAE all the time. AA has a few planes parked at the south end. I think I’ve seen HA here a few times too.
The big former ATS and BF Goodrich hanger is now the Boeing KC-46 program headquarters but ATS apparently has other facilities at PAE still.
USAirKid
Wed Feb 14, 2018 6:42 am
I'm guessing the -800s make the PAE stop for split scimitar winglet installation?
