Newbiepilot wrote:I guess we know why they used CFM engines instead if PW engines for the first A321LR since PW equipped A321neos have suspeded all test flights.
I wonder who will come out to see the plane land
CobaltScar wrote:This is going to be a real danger to the Euro based LCCs that are flying trans Atlantic (Norwegian)
reidar76 wrote:But this is not really an A321LR, as it only has two additional center tanks onboard. This is the A321 ACF, the first aircraft with both the new engines and the modified fuselage. The third additional center tank will be installed later.
keesje wrote:
reidar76 wrote:ikolkyo wrote:reidar76 wrote:But this is not really an A321LR, as it only has two additional center tanks onboard. This is the A321 ACF, the first aircraft with both the new engines and the modified fuselage. The third additional center tank will be installed later.
The aircraft has the 97t MTOW so it is an A321LR, just missing the 3rd ACT.
The A321neo ACF is the base for the longer range variant known as the A321LR. As I understand it, there will only be one variant of the A321 going forward, with 0, 1, 2, or 3 additional center tanks onboard. All A321 from 2020 will have a MTOW of 97t (or be paper derated)
There is also a benefit of the increased MTOW to 97t going short haul with high payload. The A321 ACF is also necessary for the increase to a maximum of 240 passengers.
http://www.airbus.com/newsroom/press-re ... o-acf.html
thepinkmachine wrote:I think WOW Air stole the show by operating non-stop KEF-LAX a couple of weeks ago - a longer flight...
Dutchy wrote:The airspeed is quite a bit slower, around 50-80kn. The 757 seems to have the same speed as the WB.
TranscendZac wrote:Less people on board
arcticcruiser wrote:Dutchy wrote:The airspeed is quite a bit slower, around 50-80kn. The 757 seems to have the same speed as the WB.
Yep, even slower than a Norwegian 737. Doing maximum range cruise speed? Winds are bad today going west.
Dutchy wrote:arcticcruiser wrote:Dutchy wrote:The airspeed is quite a bit slower, around 50-80kn. The 757 seems to have the same speed as the WB.
I guess, this will hurt it on long runs.
ap305 wrote:The speed is not updated for a long time since its out of receiver range... It was at mach .78 at the last point which is the lrc of the a320 family.
Richard28 wrote:CobaltScar wrote:This is going to be a real danger to the Euro based LCCs that are flying trans Atlantic (Norwegian)
Although Norwegian also have plenty of A321LR's on order too.
barney captain wrote:ap305 wrote:The speed is not updated for a long time since its out of receiver range... It was at mach .78 at the last point which is the lrc of the a320 family.
....except they are being overtaken by everyone around them.
ap305 wrote:The aircraft is also nowhere near its weight limitations given that they went up straight to fl360... This test probably has more to do with seeing how the cabin systems work on a real long haul operation.
PerVG wrote:Just got back to live tracking and doing about the same speed as all other aircraft on a similar fly path..
CobaltScar wrote:So I suppose with comfortable flights from Paris to JFK, JetBlue is almost assuredly going to be using this plane. This is going to be a real danger to the Euro based LCCs that are flying trans Atlantic (Norwegian)
Theseus wrote:PerVG wrote:Just got back to live tracking and doing about the same speed as all other aircraft on a similar fly path..
Indeed, and EI137 did not overtake it.
I did not know FR24 was extrapolating (yes, I feel foolish), thanks for the brilliant demonstration.
CCGPV wrote:For those of us not using flighradar can we get a flight number or anything?
GE90man wrote:It looked as if it was going to land on one of the 22s, but nope. This is extremely unfortunate for me as I happen to live under the path that aircraft take to the 22s, and I was planning on spotting it.
Newbiepilot wrote:Theseus wrote:PerVG wrote:Just got back to live tracking and doing about the same speed as all other aircraft on a similar fly path..
A320s along with 737s, 757s and 767s are pretty slow going between Mach .78 and .80 compared to 747s, 787s, A350s and A380s going at 0.85. When Delta and United went head to head on SFO-NRT, the Delta 767 was blocked at 55 minutes longer than the United 747. 737s and A320s are some of the slowest ETOPS birds.
