727LOVER
Airports where pax had to use stairs to board 747, DC-10, L-1011
Mon Jun 11, 2018 7:14 pm
I have no idea about outside the USA....but in the USA
The only one I know for sure is CLT
My analysis on others
MIA - when the 747 arrived in 1970, I think all the gates had bridges.
JAX - opened in 1968, all gates had bridges
TPA - new terminal opened before the tri-jets flew. Not sure if any airline brought in the 747 before April, `971
MCO - I think this is one. The jetways, I think, started showing up around 1976/77. National, Eastern & Delta had tri-jets in way before that
PBI - not sure about this one. DL terminal opened in 1974 with the bridges. Not sure when the main terminal got bridges
ATL - hmmmmm...well DL had bridges from the opening of the 1961 terminal (BEFORE actually)......Eastern, I believe, put the jetways on
Concourse A specifically for the L-1011. Don't know about Northwest Orient & the DC-10
JFK - The questionable terminals would be 1,2,3,& 4
Airports like MSY, BUF, DTW, STL or CLE...I have no idea
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
Dominion301
Re: Airports where pax had to use stairs to board 747, DC-10, L-1011
Mon Jun 11, 2018 7:27 pm
YOW needed stairs for widebodies until the expansion of the old terminal in approximately 1988.
In 1978 four loading bridges were added to the old terminal. However, I believe that the DC-8 was the largest aircraft they could handle. Might have even been the 727. They were low to the ground.
777PHX
STL had plenty of widebody gates back in the day, capable of handling up to the 747. LAX still uses the remote gates, which while they still utilize jetways, they're not much more than structures with stairs that lead up to the jetway.
747d10
Mon Jun 11, 2018 7:28 pm
KOA has no jet bridges. UA has flown D10 and 747 equipment there.
I think I boarded a DL L1011 with airstairs at OGG back in the late 80's.
flown: E145/190;F100;L10/15;DC8;D8S;D10;M11;D91/S/5;M80;M90;717;727;72S;732/3/4/5/G/8/9;
741/2/3/4;752;762/3/4;77E/L;A300;310;319;320;321;330;Concorde
FromCDGtoSYD
Mon Jun 11, 2018 7:30 pm
I remember back when ICN wasn't open yet, GMP wasn't very big and I recall being bussed to 747s.
KICT
Mon Jun 11, 2018 7:33 pm
The old Dubai airport comes to mind...
BUFJACK10
Mon Jun 11, 2018 7:47 pm
BUF always had jetways for widebody American DC 10’s in the old east terminal and Eastern L1011 in the old West Terminal
As far as I know there are a couple gates in the new terminal that can handle 747 aircraft now.
AA AK AL AQ AS B6 CO DL EA FL F9 HP KN NY MO NW PA PE PI RC QX TW UA UR US WN AF AN AO CS IB OA TR VS
A300 A319 A320 BAE146 BAC111 DC8 DC9 DC10 MD80 707 717 727 737 747 757 767 777 787 L10 F27 F28 F100 ERJ CRJ SE-210 SSC B1900 ATR42 ATR72 DH8 E120 SWM
SyracuseAvGeek
Mon Jun 11, 2018 7:49 pm
SYR, United 747-400 flew one in and used stairs. The jetbridges can go high enough, but the terminal can't handle a plane with that wingspan
"I haven't been everywhere yet, but it's on my list."
880dc8707
Mon Jun 11, 2018 7:51 pm
CDG was one of the worst. ARR A340 stairs Lv 747 stairs Arr 777 jetway depart A340 jetway
nest trip Arr A319 stairs Dep A340 stairs
They were all AF within 2 years, due to that we try to avoid AF at all costs
In addition ground staff was less than accommodation, In the air wonderful, like it was a different airline
evank516
Mon Jun 11, 2018 7:56 pm
Pretty sure EA flew L1011s to DAB at one point so I guess we can add that to the list too. No jetways before 1992.
mbmbos
Mon Jun 11, 2018 8:00 pm
In the early 70s TWA operated an L-1011 from ABQ - ORD daily. The first jetaway at ABQ was built for that L-1011 and other jumbos (charter operations), but I believe when TWA first started operating it, they had to rely on stairs.
"If I don't manage to fly, someone else will. The spirit wants only for there to be flying. As for who happens to do it, in that he has only a passing interest."
- R.M. Rilke
KICT
Mon Jun 11, 2018 8:03 pm
Speaking of ONT, the CI 77W flight uses airstairs...
727LOVER
Gate 5, if you block off gate 4?
On the UA side, gate 23?
philvardon
Mon Jun 11, 2018 8:06 pm
I have boarded BA 747s and KLM 777s by airstair at ACC. That is about to change as Kotoka is about to open a brand new Terminal 3 with air bridges.
philvardon
727LOVER
Mon Jun 11, 2018 8:08 pm
Oh....YES, YES, YES.....I forgot about that one !
AirMatt
Mon Jun 11, 2018 8:09 pm
AA flew a DC-10 to ONT during the late 90's for a short period, prior to the new terminals opening and it was a stairway. Also, I believe HA flew a DC-10 as well in the 90's.
Matt
n729pa
Mon Jun 11, 2018 8:11 pm
We used stairs for the Lufthansa 744s at TXL last year when they were using them on the FRA runs.
Years ago, 1986 I remember stairs at ORD boarding a BA 747. Seem to recall the international flights lined up with stairs including a SN DC10.
1990 ATH boarding an Olympic A300 plus seeing their 747s sitting on the apron for boarding too.
727LOVER
Mon Jun 11, 2018 8:16 pm
Years ago, 1986 I remember stairs at ORD boarding at BA 747. Seem to recall the international flights lined up with stairs including a SN DC10
1986?...That late? WOW !
SurlyBonds
Mon Jun 11, 2018 8:17 pm
I used airstairs to deplane from a 748 on the apron at FRA (originating at LAX) - I think this was about three years ago.
n729pa
Mon Jun 11, 2018 8:23 pm
Actually just remembered (shows short memory not as good as 1986!) ...boarding a BA 777 at MAD and that was last year. Disembarked at MAD from a B767 too using stairs, so occasionally they use a remote stand adjacent the main T4S
LupineChemist
Mon Jun 11, 2018 8:25 pm
MCT was only stairs until just a few months ago.
KICT
Mon Jun 11, 2018 8:26 pm
Easter Island is stairs only. Has been since opening. Currently LAN flies there with B787 but it has been other equipment in the past, incl. A340, etc.
evank516
Yup people today wouldn't recognize the DAB of yesteryear ;)
hlior
Mon Jun 11, 2018 8:27 pm
I believe it happens more than one might think...
TLV didn't have any jet bridges until 2004, I clearly remember boarding/de-boarding LY's 747s in TLV where they used 3 staircases and plenty of buses to unload a jumbo...
jubaexpress
Mon Jun 11, 2018 8:32 pm
In November and December 2017 I disembarked and boarded BA 747s at Nairobi via the stairs. Unclear if intended or the stairs and jet bridges are just broken.
SyracuseAvGeek
Mon Jun 11, 2018 8:49 pm
I don't know about that, although because they don't usually get B747's they don't have a mark on the ground for a B747
hiflyeras
Mon Jun 11, 2018 8:51 pm
I'll never forget deplaning in DPS (Denpasar, Bali) from a Garuda DC-10 down the stairs. There were blooming frangipani trees nearby and the smell was amazing!!
klm617
Mon Jun 11, 2018 8:52 pm
I boarded NW DC10 flights at FRA well into the 90's. The very end of concourse C was via air-stairs not to mention the remote parking areas. In 1996 boarded a ATA 757 via the air stairs at FRA in 1996
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
nomorerjs
T1, the original International was torn down while UAs new terminal was being built. T5 was not yet built and the parking garage was set up as the temporary international terminal. Flights deplaned / boarded where T5 is now and were bussed to the parking garage (T4).
As a kid I remember when BA & TW each had 1 flight to LHR, NW to NRT, AF to CDG, SR to ZRH, SN to BRU, LH to FRA, EI to SNN, FI to KEF, MX D10s, and not much more.
Things have change a lot!
paullam
Mon Jun 11, 2018 8:53 pm
Almost everytime I'm in Dubai I deplane EK's A380's via stairs. They seem to use remote stands rather frequently. Or maybe I'm just lucky. I'm always pleased when it happens as I can breathe some fresh air between two longhaul flights and it's quite an experience to walk around the A380.
712 733 734 735 737 738 744 752 763 77E 77L 77W 788 789 | A20N 318 319 320 321 332 333 343 346 388 | ASK21 | AT75 AT76 | BCS3 | C152 C172 C182 C210 | CR2 CR7 | DH8C DH8D | E190 | F70 F100 | LJ24 | PA31 | RJ85 RJ1H | SF34 | SU9 | YK2
bluejuice
Mon Jun 11, 2018 8:54 pm
I've deplaned via airstairs at SFO in the 90s.
Fuzzy memories of the 80s and I could be wrong but I seem to recall Pan Am 747s sometimes boarded at a remote stand at JFK.
Not biased against vacuum flush.
alancostello
Mon Jun 11, 2018 8:57 pm
Disembarked from a Qatar A340-600 using stairs last week at Doha. Boarded to my connecting 787 flight via stairs too.
ER757
Mon Jun 11, 2018 9:01 pm
FPO back in the 80's
Flew in on an EA L1011 and there was a PA 747 there at the same time - both de-planed and boarded via stairs
TC957
Mon Jun 11, 2018 9:04 pm
Many of the Caribbean airports don't have jetties.
bpat777
Mon Jun 11, 2018 9:08 pm
Actually many of the larger airports now have jetties including: MBJ, KIN, PAP, SDQ, BGI, POS and NAS. I know STT still uses stairs.
n729pa
Mon Jun 11, 2018 9:10 pm
2 years ago I also boarded a Finnair A350 at Helsinki.
Love the old picture of Dubai airport. How times have changed!
Iemand91
Mon Jun 11, 2018 9:13 pm
Zanderij in Suriname.
(old picture, but still the same today)
Some aviation photo's on my Flickr-page: https://www.flickr.com/photos/iemand91/
KLDC10
Berlin Tegel (TXL) 2017! (Lufthansa 747-400)
And if you'd like to bring in other widebodies, I disembarked from an A340-600 by stairs there a month or two ago too.
DC9/MD90/MD11/F70/BAE146
737/738/739/744/748/752/763/772/789
A319/A320/A321/A332/A333/A346/A359
Q400/E170/E175/E190/CS300
Begues
Mon Jun 11, 2018 9:20 pm
Neither Oslo, Copenhagen, Stockholm or Helsinki had any jetways when 747, DC10 or the tristar began operating for SAS and Finnair or any foreign airline. And most european airports on the continent had widebody traffic long before any jetways were installed. Only London, Paris, Amsterdam, Zurich and Frankfurt had any jetways installed before the mid to late 1970s, and many such as Vienna, Lisbon ,Barcelona, Milano, Athens, etc had non until the 1990s.
F27500
Mon Jun 11, 2018 9:34 pm
I boarded an Eastern L1011 at Hartford-BDL via airstairs in 1976 …. and in Orlando in 1977 (old terminal)
SLCUT2777
To this day none of the gates at SLC can take any 744 or 748, A34X or A388 any carrier brings in. KLM has used a 77W on an equipment substitution as recently as May 20 & that’s as big as will fit at gates D-1, D-3 or E-1 that are directly connected to the FIS desk. 2 years from now, the new international concourse u/c will take any of the super jumbos.
DELTA Air Lines; The Only Way To Fly from Salt Lake City; Let the Western Heritage always be with Delta!
airtrantpa
Mon Jun 11, 2018 9:40 pm
PIE i had to use airstairs to board a TZ L1011
Im not sure if people express used the 747 at PIE
Everyone used airstairs before they built the 2 jet bridges.
AVL my new Hometown airport! Farewell TPA
SmithAir747
Mon Jun 11, 2018 9:41 pm
I've done it twice if I remember rightly.
In 1994 I disembarked my TWA 747 at MAD (after arriving from JFK) via stairs and was bussed to what was then the international terminal in an articulated 5th-wheel-style bus. (This was long before T4.)
In 2002 I disembarked my EI A333 at DUB (after arriving from ORD) via stairs and was bussed to the terminal that was then used for international flights (the one with the large banjo).
SmithAir747
I will praise thee; for I am fearfully and wonderfully made... (Psalm 139:14)
Brickell305
For outside the US, just think of any Caribbean airport where BA/KL/AF/etc has historically flown the 747. Many of the airports now have jet bridges but most of them got them relatively recently and would have definitely been using stairs prior to that.
Old BW also flew the L-1011 to several Caribbean airports (including its own POS hub) that lacked jet bridges at the time.
sspontak
Mon Jun 11, 2018 9:42 pm
I remember using airstairs for TWA L-1011 and EA A300 in Nassau in the early 80's. Also airstairs for TWA L-1011 in Freeport in the early 80's.
Zidane
Mon Jun 11, 2018 9:55 pm
BGI doesn't have jetways, SVD does.
KL682
Mon Jun 11, 2018 9:56 pm
I Flew AMS-YUL-IAH-MEX v.v. about a dozen times between 1972-1975 with KLM 747-206B; deplaning in YUL was with stairs, transit in large seperated areas with CP Orange chairs, (can also recall IB 747 at that same airport/area); IAH was definitely equiped with jetways; MEX used stairs until 1974, after that KLM operated on the first jetways installed there.
SpaceshipDC10
Mon Jun 11, 2018 9:59 pm
ZRH and GVA were stairs only at first. Once the former built it's new terminals A & B, less wide-bodies were parked on a hard stand. I also remember arriving in 1989 at ORD on board a Swissair or Lufthansa flight from Europe and having to walk down stairss to be bused to the terminal where the immigration was conducted. International flights then departed from the Delta terminal, at least at the opposit end of UA's.
I have discovered that once people are truly captivated in their ignorance, they are generally unwilling to let the facts interfere.
(Rick Drury's Flightlines "Paychecks", Airways April 2003)
gwrudolph
Mon Jun 11, 2018 10:18 pm
As recently as the early 2000s most if not all of the inbound UA 747s at NRT used airstairs and a bus to customs and immigrations. Outbounds were at the terminal. I think the issue was that with the onward Asia operations at the time, they would have 15 or so aircraft on the ground at one time. As they shrunk the onward Asia operations and the terminal had gates added, they went to all bridges
