dc-9-10
Pan Am At JFK
Sun Mar 10, 2002 10:20 am
I know that this is a simple quesiton, but if some one could tell me the answer I would be very pleased.
Was Pan Am's termonal at JFK the one that Delta uses now??
Dc-9-10
flyguy1
RE: Pan Am At JFK
Sun Mar 10, 2002 11:09 am
Yes
727, L1011, MD80, A300, 777-200, 737-300, 737-700, 747-400, 757-200, 737-800, A320. E190, E135, 767-200, CRJ9
mjzair
RE: Pan Am At JFK
Sun Mar 10, 2002 12:32 pm
It was called the Worldport
OA412
Crew
RE: Pan Am At JFK
Sun Mar 10, 2002 2:59 pm
Didn't DL also call it the worldport for a while after purchasing PA's atlantic division or am I way off?
Hughes Airwest - Top Banana In The West
STT757
RE: Pan Am At JFK
Sun Mar 10, 2002 3:10 pm
World Port (Terminal 3) Pan Am
Click for large version
Photo © Joe Pries
World Port (Terminal 3) Delta
Photo © Matthew Lee
skyhawk
RE: Pan Am At JFK
Sun Mar 10, 2002 10:37 pm
In fact the original part of the "Worldport" was the round portion in the front. Paax were checked in and moved to their planes via "people movers"..later the rear portion or the terminal was built. Not sure of the dates on this.
ContinentalEWR
RE: Pan Am At JFK
Sun Mar 10, 2002 10:44 pm
The current Delta terminal (designated T3) is the former Pan Am WorldPort. From here, Pan Am operated flights to Europe, South America, Asia (before 1986) and the Middle East as well as domestic US markets and the Caribbean. It was amazing to see so many PA 747's, A310's, 727's, and the occasional 737 parked there up until Pan Am's demise in 1991.
The terminal adjacent to it (formerly the Delta and Northwest Terminal) is now part of the Delta complex at JFK. I don't recall if Pan Am used it much in its heyday. Officially, it is the Delta domestic terminal and also serves TACA Airlines and a few other carriers.
ContinentalEWR
N202PA
RE: Pan Am At JFK
Mon Mar 11, 2002 4:12 am
I don't think this is true. In the 80s, there were gates at Worldport, and in the 50s and 60s, aircraft pulled up to the terminal and were met with stairs and open airbridges. The large roof was built to overhang the aircraft and provide all-weather boarding in comfort for the passengers.
Photo © John F. Ciesla
Photo © Mel Lawrence
Pan Am did use the terminal next door (Terminal 2) and this is where they used the people movers, at least in the 80s, before the connection bridge between the two was built. Terminal 2 was used by Pan Am as the domestic terminal, including Pan Am Express commuter flights. The "rotunda" of Worldport was also used commonly for domestic flights, while the Worldport terminal extension was used for international flights.
skyhawk
RE: Pan Am At JFK
Mon Mar 11, 2002 5:01 am
N202PA-What I wrote was relayed to me by crews that I flew with(I started with National, hence didn't use the Worldport until the takeover). It may have been the way it was said and I misunderstood, I don't know, but more that once it was said that people movers were used a lot. Actually they were also used even after the takeover and left from what was Gate 8(don't know what that gate is now). Could be that they used a lot of the movers as they didn't have as many gates before as after the rear of the building was completed. BTW, I don't remember ever using a people mover from Terminal 2(what we called Terminal B).
N202PA
RE: Pan Am At JFK
Mon Mar 11, 2002 8:22 am
Skyhawk,
What you're talking about may be related to space issues...I do remember a few times PA aircraft were parked out by the IAB, and you had to take a people mover out there.
I do, however remember on several occasions having to use one of those mobile lounges to go from one terminal to the other, because there was no other way to get there (short of actually exiting the terminal and taking a shuttle bus of some sort). If I recall correctly, the bridge wasn't built until 1989 or 1990.
clipper471
Crew
RE: Pan Am At JFK
Mon Mar 11, 2002 8:57 am
The intra-terminal connector, linking T2 and T3, was completed May-1989.
panamair
RE: Pan Am At JFK
Mon Mar 11, 2002 5:00 pm
After Delta took over in '91, they did not call it Worldport...it was called the Delta Flight Center...as usual with Delta, Atlanta (or 'Mecca') took over the 'Worldport' moniker for a short period of time.
Yes, Pan Am I did use Terminal 2 for a short while in the late eighties. After Nov'91, the slimmed down Pan Am with service only to Latin America moved all of its ops to Terminal 2 (from Nov 1 until Dec 4, 1991) while DL operated out of Terminal 3 (and part of 2).
