VSMUT wrote:Gemuser wrote:You are forgetting a very major point, for aviation technical areas, the UK IS A MEMBER OF ICAO, independently of the EU. It can simply use existing EASA rules/regulations by adopting them under UK law. As an ICAO member ALL other members HAVE to recognise them, under ICAO rules unless they are shown to be deficient. The EU is NOT a member of ICAO.
Undoubtedly there will be disruption but not the fall off a cliff you envisage
Gemuser
They still need to adopt them though, which means passing them through the parliament. Given how many laws would have to be adopted (and not just in aviation), there is a pretty good chance that there could be disruptions in case of a hard brexit. The Economist had an article on this subject a while ago. Back then, the British parliament would have to pass something like 500 laws each day in order to achieve it by the exit date, quite impossible.
Either way, I will make sure to stay far away from British airports and airlines in those days, regardless of what deal is or isn't made.
Arion640 wrote:Amazing how the EU is a big organisation for “freedom” yet there’s no freedom to do your own trade deals or control your borders. Irony.
Dutchy wrote:LTU330 wrote:However, back on topic, there is no way that flights will simply have to stop or RR Engines suddenly become unusable. The UK will still be part of EASA. You don't just get kicked out of an organization like that because of Brexit, just like British Airways won't just get kicked out of the IAG Group.
The European Aviation Safety Agency or EASA is an agency of the European Union. So that means that when Brittian has left the EU, they are also out of all its agencies, thus also the EASA. They aren't kicked out, they decided to leave. And that's why there will be administrative problems with real-world consequences if there is no-deal Brexit: flights will stop and Airbus's wings will be unusable. That is the simple but harsh answer to the question of the OP.
After a marriage of 40 years, you need to work something out or you will have problems, new spare parts and new engines of RR (if made in the UK) will be unusable. All these kind of agencies were EU, not local, for good reasons, with Brexit, Britain needs to form their own agencies and they need to be validated as a 3rd country agencies if no deal is reached. The no-deal option isn't a real option for all involved, but mostly to the UK itself, hence the cliff edge.
f4f3a wrote:It’s worth noting that easa hasn’t been in operation that long as a governing body . Uts only been about 5 years since easa has been issuing common licenses etc . Before was the joint aviation authority which harmonised all the different authorirties. Despite easa they still operate there own variances . For example the German caa quite difficult to deal with that’s why many airlines reg in Ireland and Austria . If it gets to the point where fights stop that will be the least of our worries as everything will stop. Another example is that most major insurance and financial policies for many European organisations are underwritten by London . If nothing happens by March much of Europe will be affected as much as the uk . This is not a one way street . The eu as much as uk gov needs to step up to sort this out.
reidar76 wrote:Irony? Enjoying the four freedoms and at the same time having the freedom to do your own trade deals, is called the "Norway option". EU has offered this option to the UK, but the UK turned it down.
Following the news in British media, I'm puzzled and amazed of the UK focus on trade and tariff free access to the EU market. EU tariffs are not high. Norway has had two referendums concerning EU membership and both times the majority (52% against 48%) said 'no' to joining the EU. The main reason is that we want tariffs and customs borders. Norway has high tariffs in order to protect a higher average standard of living and a significantly higher salary level than the EU. Without tariffs it would be impossible to stay competitive in sectors like agriculture.
But, there is a huge majority in Norway that supports the four freedoms, the implementation of EU law and its agencies, including oversight by the EU court. Having a common aviation market and letting the EU agency (EASA) handle certification and safely regulations, is unproblematic for Norwegians. The same goes for all sectors, like energy, nuclear, medicines, financial etc. where there are EU agencies. People just want flying to be cheap and safe, and that medicines are tested, works well, and a safe to use etc. In the UK politicians talk about "taking back control". What they mean is removing the cooperation, influence and authority of EU governmental agencies like EASA. At the same time the UK is unprepared to handle the workload and functions these agencies provide. See the irony?
RobK wrote:48% of the voting population is not a "huge majority" no matter how you try to spin it.
Gemuser wrote:Undoubtedly there will be disruption but not the fall off a cliff you envisage
Dutchy wrote:Arion640 wrote:Dutchy wrote:(at all cost, right?)
Yes. I don’t want to live in a superstate 10 years down the line.
So this is the real reason you want a Brexit at all cost: being afraid of something that might happen in 10 years?
Do you want Brittian to fall apart? Then you are part of even a smaller state, England I presume. Or perhaps a county is the right size for you? Or perhaps only a city with some surrounding farmland?
Some problems can't be tackled at a national level, so on a supranational level it might be solved, so why not do this at this level in a permanent structure? You have to deal with problems at a so low level as possible.
VSMUT wrote:[They still need to adopt them though, which means passing them through the parliament. Given how many laws would have to be adopted (and not just in aviation), there is a pretty good chance that there could be disruptions in case of a hard brexit. The Economist had an article on this subject a while ago. Back then, the British parliament would have to pass something like 500 laws each day in order to achieve it by the exit date, quite impossible.
Gemuser
Dutchy wrote:So in conclusion, everything will stop on the Brexit date without a deal.
JayBCNLON wrote:All the countries that have joined the EU have benefitted from it tremendously. When I flew to the UK the first time when I was 12 in 1975 (remember UK joined 1973 and btw it was on a BEA Trident) it was a visibly poor country, significantly poorer than my EU home country. The UK have benefited so much from EU membership it is now really on par with the rest of its Neighbors.
To me there is nothing wrong and everything right with further European integration until - yes - it’s one federal state.
Any negative impact of Brexit on the UK is 100% the resonsibity of the UK, its politicians and its people. All the UK needs to do to avoid building up a whole new bureaucracy and any negative consequences of Brexit is to stop Brexit. I would welcome that.
But again the choice is for the UK to make and to live with.
RobK wrote:reidar76 wrote:Irony? Enjoying the four freedoms and at the same time having the freedom to do your own trade deals, is called the "Norway option". EU has offered this option to the UK, but the UK turned it down.
noviorbis77 wrote:Dutchy wrote:So in conclusion, everything will stop on the Brexit date without a deal.
Not necessarily. Who knows what will happen. Maybe an agreement will be made to allow business continuity.
Trouble with anti Brexit folk, they do look to the worst of things.
Dutchy wrote:noviorbis77 wrote:Dutchy wrote:So in conclusion, everything will stop on the Brexit date without a deal.
Yes, necessarily. If no deal or agreement is reached.
I don't think no agreement/deal will be reached, but if no deal is reached, then everything will stop by law apparently.
That is an opinion.
Lets see what happens.
N
Gemuser wrote:Dutchy: You are forgetting a very major point, for aviation technical areas, EASA/EU itself has no authority in international civil aviation, its authority is derived from the membership of ICAO by the various nation states of Europe, including the UK. The UK is still a member of ICAO and Brexit will/can not change that. They can simply use existing EASA rules/regulations by adopting them under UK law. As an ICAO member ALL other members HAVE to recognise them, under ICAO rules unless they are shown to be deficient. The EU is NOT a member of ICAO.
Undoubtedly there will be disruption but not the fall off a cliff you envisage.
Gemuser
prebennorholm wrote:Gemuser wrote:Dutchy: You are forgetting a very major point, for aviation technical areas, EASA/EU itself has no authority in international civil aviation, its authority is derived from the membership of ICAO by the various nation states of Europe, including the UK. The UK is still a member of ICAO and Brexit will/can not change that. They can simply use existing EASA rules/regulations by adopting them under UK law. As an ICAO member ALL other members HAVE to recognise them, under ICAO rules unless they are shown to be deficient. The EU is NOT a member of ICAO.
Gemuser
No, Gemuser. That is totally wrong.
ICAO is a UN organisation which makes recommendations to UN member states about how civil aviation rules are made in individual countries or groups of countries. And they recommend as much harmonisation a possible.
There is of course no reason the EASA after Brexit cannot certify or license UK companies which are overseen by a future UK civil aviation agency. ... Until the UK has a working and capable agency like the FAA, or the TCCA in Canada etc, and the EU has a bilateral agreement with it, then there is a huge problem.
How, dear Gemuser, will you avoid the cliff with much less than 7 months to go? Dutchy is right. .
Gemuser wrote:I have no real knowledge of these outside Australia, however given the amount of money involve IMHO there will NOT be any real, widespread problem with non EU countries, at least.
Gemuser
Dutchy wrote:A deal needs to be negotiated or an extension needs to be granted.
par13del wrote:Dutchy wrote:A deal needs to be negotiated or an extension needs to be granted.
I honestly believe that this has always been the basic plan of the opponents of Brexit, if nothing is negotiated by end March 2019 the public will be forced to accept an extension of the EU membership by paying the agreed price, which is most quarters is accepted as the price for actually giving and taking a vote.
The extension and the ultimate re-vote is to be expected, it has been thus in other member nations the UK should be no different, just more difficult.
Like Andy Capp zig zagging all over the place to get across the road to his house....
londonistan wrote:I know it's slightly off topic, but it's still something that flies...I'm talking about Galileo. The EU have no business expelling us (the Brits) from this project.
Loew wrote:EU commission has already issued a notice to stakeholders in januray 2018 in connection with air transport in a case of a no deal hard brexit.
https://ec.europa.eu/transport/sites/tr ... nsport.pdf
Bottom line is, if the UK leaves the EU without an aviation agreement, flights would immediately cease between the UK and the EU since EU issued operating aviation licenses would no longer be valid in the UK, and British airlines would no longer have the right to fly to EU countries, because UK issued operating aviation licences would no longer be valid in the EU. The UK would also cease being a member of the European Aviation Safety Agency (EASA), which issues the certification and licenses EU aircraft require. Third country airlines could be hit too, as those carriers will no longer benefit from access to traffic rights to or from the UK, or any other rights where these have been granted to their country under any air transport agreement to which the EU is a party. An example of such agreement is EU-US open skies agreement.
PanHAM wrote:That however requires Special customs tratment ( handling at origin and at Destination. Something which had become obsolate with the single market. saving millions of manhours and billions in costs.
PanHAM wrote:Knowing the facilities at LHR, there simply won't be enough spaces at the LHR horseshoe, just to mentione one Location. The result would be instant melt down for air cargo throughout he UK . Same would happen at the trucking borders. Even of clearance is diverted to Inland customs facilities, But even checking the T1 (third Country( and T2 (single market EU Transit documents would take time, man power and use of facilites which are simply not available.
Either way you look at it, if the UK does not pull the emergency brake and Exit the Brexit asap, the damages to the national economy of the UK will be huge.
par13del wrote:londonistan wrote:I know it's slightly off topic, but it's still something that flies...I'm talking about Galileo. The EU have no business expelling us (the Brits) from this project.
Galileo is a EU project, since the UK is leaving the group they can no longer receive the benefits of the project, if they made financial commitments they have to continue to meet those obligations. Probably better to move that thought to the Non-Av section.
As it relates to traffic between the UK and the EU after Mar-2019 if no deal, even if a last minute extension is granted, I would expect some disruption at local secondary airports frequented by FR for example, as some authorities may not have gotten the "memos" and may refuse to clear or release a flight.
par13del wrote:Galileo is a EU project, since the UK is leaving the group they can no longer receive the benefits of the project, if they made financial commitments they have to continue to meet those obligations/
Virtual737 wrote:par13del wrote:Galileo is a EU project, since the UK is leaving the group they can no longer receive the benefits of the project, if they made financial commitments they have to continue to meet those obligations/
Wouldn't that be a perfect example of cherry picking by the EU? Something that the UK (possibly rightly) is also being accused of.
You're leaving the EU so everything you've contributed to it so far is written off, but, but the way, you still have to pay for future commitments you made in the past.
YYZYYT wrote:What about overflight and ATC? Will TATL traffic have to be routed from Ireland to the continent without entering UK airspace if there is a no deal Brexit?
JayBCNLON wrote:The Brexit vote was rigged in so many ways, based on lies and manipulated by interest groups and foreign governments. It can not be taken seriously.
JayBCNLON wrote:I am really shocked how far the British political system and the political cast have gone down the drain.
JayBCNLON wrote:I wonder how Britain can maintain a permanent seat in the UN Security Council.
PanHAM wrote:EASA is not a Problem, the European Common Aviation Area includes a number of countries which are not member of the EU, whoch means that "Third Countries" which the UK will be then, can be members.
JayBCNLON wrote:The Brexit vote was rigged in so many ways, based on lies and manipulated by interest groups and foreign governments. It can not be taken seriously. The same circles that are in favor of Brexit would never accept the so-called referendum as valid.
I wonder how Britain can maintain a permanent seat in the UN Security Council. Theough Brexit the UK has lost credibility, has become an unreliable player without an basis of power.
But let’s return to aviation: what if ownership of BA is not British but EU? Who says it has to change to a majority British ? Are we maybe seeing the end of BA?
UltimoTiger777 wrote:YYZYYT wrote:What about overflight and ATC? Will TATL traffic have to be routed from Ireland to the continent without entering UK airspace if there is a no deal Brexit?
Overflight rights are governed by the International Air Services Transit Agreement which the UK, US and the rest of the EU are members of. I can't see that being anymore of an issue than it is now. The CAA website specifically states that a foreign carrier permit isn't required for UK overflights nor is one required for "Flights exercising traffic rights permitted by Chapter III of the European Market Access Regulation".
https://www.caa.co.uk/Commercial-indust ... r-permits/
I mean I suppose the EU could block UK flights overflying to non-EU destinations but that would just get us all in a very nasty legal battle wouldn't it? Especially if both parties are signed up to an agreement governing said rights.
frmrCapCadet wrote:Again to Brexiters, agreements for most of these problems are possible. But braindead Brexiters did not do their homework. Plans for the various sectors of the economy and political implications should have been worked out - sector by sector before the vote, and certainly before triggering exit. Don't blame Remainers. Then again anarchists set off the bomb and blame everyone else for the results.
As an aside, we can think simplistically that a plane flies because of the the physics forces involved. But as much, and for safe flying it is the sheaves of paper (or iPods), bureaucrats, treaties hammered out by diplomats, sausage making in political assemblies, and innumerable others without whom those planes cannot fly.
What does the CAA say about Brexit? Have a look at https://www.caa.co.uk/Our-work/About-us/EU-exit/
Dutchy wrote:I don't think no agreement/deal will be reached, but if no deal is reached, then everything will stop by law apparently.
VS11 wrote:I don't see AA/BA keeping their JV. VS can potentially become US majority owned by DL.
