Zoedyn
Moscow's Sheremetyevo airport to be renamed Pushkin Airport
Thu Dec 06, 2018 1:14 am
https://au.news.yahoo.com/moscows-shere ... --spt.html
Moscow's main Sheremetyevo airport will be renamed after the name of Russia's greatest poet Pushkin, according to results of a recent nation-wide vote across Russia to rename airports in dozens of cities
Meanwhile another airport of Moscow——Domodedovo Airport will bear the name of 18th century scientist and polymath Lomonosov
Interesting. Seems the Russians are finally interested in naming their airports after the names of famed people
Wondering whether their IATA codes will be changed accordingly, like the switch from IDL to JFK for NYC’s flagship airport following a renaming move
aemoreira1981
Re: Moscow's Sheremetyevo airport to be renamed Pushkin Airport
Thu Dec 06, 2018 1:32 am
The renaming of DME is interesting since that airport (except for the runways) is privately owned by Dmitry Kamenshchik through East Line Group (SVO and VKO are owned by the Russian government).
Cunard
Thu Dec 06, 2018 1:42 am
Surely it if it goes ahead Sheretmetyevo Airport will be renamed Moscow Alexandra Pushkin Airport rather than just Pushkin Airport
Same applies to Domodedovo Airport if it changes it's name to Lomonosov Airport which out of the four Moscow airports is actually privately owned. I find it strange, if it does actually change it's name, but it's just a people's poll so it might not actually happen anyway.
If the name changes do actually go ahead perhaps the other two major Moscow airports of Vnukovo and Zhukovsky could equally be renamed in a similar way to Sheretmetyevo.
Possible names could be,
Ivan Franko Airport
Mikhail Lermontov Airport
Shota Rustaveli Airport
Taras Schevchenko Airport
94 Countries, 327 Destinations Worldwide, 32 Airlines, 29 Aircraft Types, 182 Airports, 335 Flights.
dcajet
Thu Dec 06, 2018 1:46 am
Quite a few Russian airports are being renamed after historical figures. The plan has hit a roadblock in the European enclave of Kaliningrad, where the plan was (or is) to name the local airport after Immanuel Kant, the 18th century German philosopher from back when Kaliningrad was Kant's home when the Baltic city was Prussian Königsberg. It appears that folks from Kaliningrad think that Kant is not Russian enough, calling him a traitor.
https://www.bbc.com/news/world-europe-46440713
albertocsc
Thu Dec 06, 2018 5:17 am
That's already the name of TBS airport :D
N415XJ
Thu Dec 06, 2018 5:39 am
Maybe, but ORD’s code hasnt changed since its name changed from Orchard Field to O’Hare in 1949, Beijing is still PEK, Mumbai is still BOM, there are no plans to change HNL’s code that I know of, etc. Although maybe codes based on a city name are different and ORD is the exception among codes based on the airport’s name...
Come to think of it, it would be interesting to see how many airports change their IATA codes vs. how many stay the same after a change to the official name of the airport or the city.
gabrusha
Thu Dec 06, 2018 5:52 am
Zoedyn wrote:
https://au.news.yahoo.com/moscows-sheremetyevo-airport-bear-pushkins-name-201044812--spt.html
In Spain neither Madrid nor Málaga Airport codes (MAD/LEMD and AGP/LEMG) did not change after they were renamed Adolfo Suárez and Pablo Ruiz Picasso respectively.
redzeppelin
Thu Dec 06, 2018 6:21 am
Cunard wrote:
Ivan Franko Airport
The fathers of Ukrainian literature won't be giving their names to any Russian airports in the current political environment.
avier
Thu Dec 06, 2018 6:37 am
Pushkin Airport.
Sounds Brutal. Why would anyone want to push their kin. :lol:
Blerg
Thu Dec 06, 2018 7:19 am
Great initiative! Especially love the fact they are not naming them after politicians. Why would it be a problem if they are privately owned? I am sure their owners wouldn't have anything against it. It's great PR for them.
If we look at other airports across eastern Europe are these the only major ones left without a name: VNO, RIX, MSQ, KBP, SOF?
We are going to have three airports named after scientists: Belgrade (Nikola Tesla), Moscow (Lomonosov) and Wroclaw (Copernicus).
P1aneMad
Thu Dec 06, 2018 7:26 am
I would think that one of Moscow's airports could/should be named after Leo Tolstoy.
conaly
Thu Dec 06, 2018 7:36 am
Did you guys read the article at all? It was clearly said, that the name will be ADDED to the airport name, not replace it. Therefore you can assume it will be called "Moscow Sheremetyevo Pushkin Airport" or something like that, so no need for either remembering a new name or change any IATA-codes. This makes this just a PR-action and nothing more. This is actually quite a common way of pushing some publicity to the airport. For example, Berlin Tegel airport has the name of Otto Lilienthal, still hardly anyone ever said "Otto Lilienthal airport", it still is just called "Tegel airport". Or Madeira airport was officially named "Christiano Ronaldo Airport", still FNC was kept as IATA code and not changed to CR7 or whatever. So people and authorities will still refer to Sheremetyevo airport and not Pushkin airport, I'm pretty sure
As the airport names are quite stuck in the heads of people, changing the local name would be quite a hassle to everybody.
Another source: https://www.flightglobal.com/news/artic ... -s-454162/
"Moscow Sheremetyevo’s operator states that it “gladly accepts” the result of the national renaming scheme, adding that it will display the new name on special plates on the terminal buildings."
Sounds like a confirmation, that the name will be just for display.
Airports 2018: ADB, ALG, CAI, DAC, DEL, DUS, FRA, GRU, HAM, HAU, HND, IST, KTM, LYS, MUC, NUE, OSL, PKR, QSF
Planned: no new airports
Cancelled: Lukla :/
SCQ83
Thu Dec 06, 2018 8:03 am
conaly wrote:
Did you guys read the article at all? It was clearly said, that the name will be ADDED to the airport name, not replace it. Therefore you can assume it will be called "Moscow Sheremetyevo Pushkin Airport" or something like that, so no need for either remembering a new name or change any IATA-codes. This makes this just a PR-action and nothing more..
Indeed. For instance, MAD is now officially named Madrid-Barajas Adolfo Suárez Airport. They just added the "Adolfo Suárez" and kept the rest.
http://www.aena.es/en/madrid-barajas-airport/index.html
Cunard
Thu Dec 06, 2018 9:06 am
redzeppelin wrote:
Cunard wrote:
Ivan Franko Airport
How silly of me I should have realised that before I suggested those examples!
HELFAN
Thu Dec 06, 2018 9:18 am
"Wondering whether their IATA codes will be changed accordingly, like the switch from IDL to JFK for NYC’s flagship airport following a renaming move"
Interestingly St.Petersburg airport still has the old IATA code LED.
Jomar777
Thu Dec 06, 2018 9:45 am
Quite interesting really. Pulkovo (LED) should be the one to bear Pushkins name since he was a citizen from St Petersburg and mainly lived his whole life there. Died there also (a duel but that's another story...).
I would have expected Tchaikovsky (the author of the Russian - and Soviet - National Anthem) or, as already mentioned, Tolstoy.
But the Russians have voted and at least they respect the result rather than what happen elsewhere...
MrPeanut
Thu Dec 06, 2018 12:45 pm
How long until we see Vlad name an airport after himself ?
neutrino
Thu Dec 06, 2018 1:15 pm
If its all up to him alone, that would be yesterday.
Potestatem obscuri lateris nescitis
ro1960
Thu Dec 06, 2018 1:43 pm
Names are often for PR purposes or to pay tribute to a national figure. Yet people use whatever is more convenient. In France we fly out of Roissy, not Charles De Gaulle.
You may like my airport photos:
https://www.flickr.com/photos/aeroports
CometOrbit
Thu Dec 06, 2018 2:08 pm
Sheremetyevo airport is already named indirectly after a famous Russian family - the Sheremetevs.
They were sponsors of the arts, particularly theatre and opera, and owned Ostankino Palace just north of Moscow.
The village of Sheremetyevskiy, further north, was named after the family, and this is where Sheremetyevo airport was later established.
WorldFlier
Ivan Franko Airport
Aeroport imeni Aleksandra Pushkina (Airport named after/in the name of Alexander Pushing)
IADCA
Thu Dec 06, 2018 2:50 pm
Your statement makes rather little sense, as ultimately it is all up to him.
Sand0rf
Thu Dec 06, 2018 3:02 pm
I hope they will use the complete name of the poet for the airport as Pushkin is also a brand of Vodka in The Netherlands:
Some might argue that that might be even more fitting for Russia though :mrgreen:
BREECH
Thu Dec 06, 2018 3:20 pm
You do realize that Sheremetyevo and Domodedovo are the names of places where airports are built. Like, for example, Le Bourget or Lignate or Fumicino, right? I personally think it's a stupid idea. Those airports are well established names in the minds of the Russians and quite a few foreigners.
Besides, some ideas are just horrible. In Omsk they want to name the airport after Yegor Letov who was the frontman of a band most famous for writing the most obscene songs. And in some cases, like with Sheremetyevo, it simply makes no sense. Pushkin was born, lived all his life and died in St.Petersburg. And everyone knows that. Why rename a Moscow airport after him? Lomonosov was from Archangelsk, but for some reason his name will be given to a Moscow airport. I doubt he's ever even BEEN to Moscow!!!
LED didn't change after Leningrad became St.Petersburg.
No friendship, love or respect unite people as much as shared hatred.
Sergey Dovlatov
ltbewr
Thu Dec 06, 2018 3:45 pm
Recall that EWR is officially Newark Liberty International Airport. The 'Liberty' part was put in after 9/11 for political reasons. This may be to appease certain interest groups, sometimes as the original name was of someone of a past and difficult history or for marketing purposes.
concordeforever
Thu Dec 06, 2018 5:14 pm
Pushkin is already the name of the Russian Air Force Airbase near to St. Petersburg, so changing the name of Pulkovo LED Airport to Pushkin would be totally confusing....
raylee67
Thu Dec 06, 2018 5:22 pm
For some reason, when I first saw the subject line, I thought it's a typo for Putin Airport.
319/20/21 332/33 342/43/45 35K 388 707 717 732/36/3G/38/39 74R/42/43/44/4E/48 757 762/63 772/7L/73/7W 788 D10 M80 135/40/45 175/90 DH1/4 CRJ/R7 L10
AY LH OU SR BA FI
AA DL UA NW AC CP WS FL NK
CI NH SQ KA CX JL BR OZ TG KE CA CZ NZ JQ RS
kjeld0d
Thu Dec 06, 2018 7:19 pm
Plus its the name of a totally awesome James Bond character played by John Rhys-Davies...
BuildingMyBento
Thu Dec 06, 2018 7:35 pm
Viktor Tsoi International Airport?
workhorse
Thu Dec 06, 2018 10:52 pm
This is the only one that made sense, IMO. And the only one that would stick with the people, if it wasn't censored.
How much are you willing to bet that no one will be saying "Pushkin airport" instead of "Sheremetyevo"? But I can totally see locals proudly saying "Yegor Letov airport" instead of "Centralny". But anyway, whatever, they killed it. Dumbwits.
PSAatSAN4Ever
Thu Dec 06, 2018 10:55 pm
As I have read on numerous threads here, IATA codes are almost NEVER changed, due to the possible confusion between old and new. Sioux City and Fresno are first in line if this situation changes, as it SUX to be so FAT. But as pointed out here, Beijing is still PEK, and probably always will be.
As for the airports themselves, I highly doubt that a change of name means that the pulbic will automatically be calling by the "new" name. SVO, DME, VNK, because of their codes will be called (at least for many years to come) Sheremetyevo, Domodedovo, and Vnukovo, just as BWI is "Baltimore", despite the plethora of names, Chicago will always call their airports "O'Hare" or "Midway", Minnesotans will continue to refer to their airport as "Em-es-pee", and ATL is "Atlanta" or "LaToya Jackson Intergalactic Hairport and Check-Cashing Boutique".
Sorry about the last one - it's the only airport I know where there are dozens of great names like that you will see if you go to check-in on Facebook.
BREECH
Fri Dec 07, 2018 4:08 am
Right. How about play his songs inside the airport. At the volume that idiot preferred. I'm sure some WWII veterans who fought for you in Stalingrad would LOVE that. What terrible dumbwits, not succumbing to morons! How dare they!
Sergey Dovlatov
BREECH
Fri Dec 07, 2018 4:10 am
I'd rather chew glass!
Sergey Dovlatov
Jomar777
Fri Dec 07, 2018 9:26 am
Not really since the Airport would be named Alexander Pushkin, for example. Also, other places in the world have airbases together with the airport and have no issues (GRU and GIG for instance...).
Have a great day!
Airdolomiti
Fri Dec 07, 2018 9:52 am
Didn't Lomonosov study in Moscow for several years? Moscow State University is also named after him.
Besides, there are plenty of examples of airports named after famous people who were not from the immediate area, e.g. Rome-Fiumicino "Leonardo da Vinci" (Leonardo was, as his name suggests, from the town of Vinci, just outside Florence), New York JFK (Kennedy was from Massachusetts, although he did live in New York for a time), and Belgrade "Nikola Tesla" (Tesla spent less than two days in Belgrade in his entire life), just to name a few.
EricAY05
Fri Dec 07, 2018 9:54 am
Why would one of the most famous Russian academics never have been to Moscow? (Yes, I know that St.Petersbuirg was the capital and the cultural center at the time of Lomonosov) He even studied there. Isn't it only logical to name the most important airports in the country after the most important people? JFK is in New York, have a problem with that? I kind of agree that Pushkin should have been "given" LED, but the air base reasoning explains why this is not done.
Phosphorus
Fri Dec 07, 2018 12:17 pm
Murmansk is now named after Emperor Nicholai II Romanov. Does he qualify for being not a political figure?
Voronezh is renamed after Emperor Peter I, and Kaliningrad after Empress Elizaveta Petrovna. Who are they, if not political figures?
There are some noises to give an additional name to KBP; IEV eventually did get named after Sikorsky, afterall.
But honestly, I'm not a fan of further lengthening the name of "Kyiv Boryspil International Airport".
AN4 A40 L4T TU3 TU5 IL6 ILW I93 F50 F70 100 146 ARJ AT7 DH4 L10 CRJ ERJ E90 E95 DC-9 MD-8X YK4 YK2 SF3 S20 319 320 321 332 333 343 346 722 732 733 734 735 73G 738 739 744 74M 757 767 777
Ceterum autem censeo, Moscovia esse delendam
LTU932
Fri Dec 07, 2018 12:48 pm
Krakow's airport was renamed John Paul II. Didn't have any effect on its IATA code, same with HAM after it got the name Helmut Schmidt attached to it.
On the other hand, in some instances the IATA codes (and even ICAO codes) can change. One prominent example was SDA (Saddam International), which was renamed into Baghdad International (with the invasion of Baghdad in 2003 still in progress) to disassociate it from Saddam Hussein, the airport itself changed its IATA code from SDA to BGW. Even the ICAO code changed from ORBS to ORBI.
Blerg
Fri Dec 07, 2018 8:30 pm
Well they were monarchs and highly successful ones. I wouldn't put them in the same category as Yeltsin and so on.
Phosphorus
Fri Dec 07, 2018 8:41 pm
Nicholai II Romanov -- "highly successful" monarch? You can love him or loathe him, consider him a lazy ruler, or a figure of tragedy, or a simpleton taken for an abdication ride by his own inner circle, or a bloody tyrant, or a good family man caught up in political intrigue and revolution, or a martyr -- now canonized, and thus a saint. But "highly successful" monarch? Seriously?
Ty134A
Sat Dec 08, 2018 12:26 am
there is only one name for Leningrad Airport (LED): "Vladimir Vladimirovich Putin"
if they don't bring that, they should fry in hell!
other than that, russia/cis tends to not change it's 3 letter designators. LED is Leningrad, SVX is Sverdlovsk, KUV is Kuibishev, GOJ is Gorki and in KSSR GUV is Gurev, hell even TSE is actually Tselinograd, then Akmola, and finally Astana. FRU is Frunse, KRV is actually Krasnovodsak and not Türkmenbashi (who was a funny dude and a great symbol of us- türkmen friendship). but not all soviet names made it into the designator. Stalinabad was always DYU or dyushanbe.
flown on: TU3,TU5,T20,IL8,IL6,ILW,IL9,I14,YK4,YK2,AN2,AN4,A26,A28,A38,A40,A81,SU9,L4T,L11,D1C,M11,M80,M87,
AB4,AB6,318,313,342,343,345,346,712,703,722,732,735,741,742,743,74L,744,752,753,763,772,77W,J31,F50,F70,100,ATP,
142,143,AR8,AR1,SF3,S20,D38,MIH...
A321Lufthansa
Sat Dec 08, 2018 2:54 pm
But in Samara the KUF code can be also interpreted as Kurumoch. I don’t argue that it originally came from Kuybyshev but that’s better than having no other variants for LED. In my opinion, it should be changed to SPB, as well as SVX to EKB.
Ryanair01
Sat Dec 08, 2018 2:59 pm
:lol: I've got to admit I glanced at this title and read "Putin"
