hayzel777
Norwegian 789 Takesoff From Wrong Point at LGW
Thu Dec 06, 2018 5:32 pm
A Norwegian 789 departing LGW-EZE started their takeoff roll at the landing displaced threshold instead of the beginning of the runway on the standby runway(26R). AAIB notes that "the distance did not meet regulatory requirements" and engine failure on V1 would've resulted in a catastrophic event if the crew decided to stop or continue. AAIB also cites the lack of lighting and awkward lineup as reasoning.
This is the 4th incident since September 2017 with the threshold and wrong takeoff points on the standby runway at night.
http://avherald.com/h?article=4c135b66&opt=0
rbavfan
Re: Norwegian 789 Takesoff From Wrong Point at LGW
Thu Dec 06, 2018 5:48 pm
4th incident with Norwegian or 4th incident multiple carriers. It would make a big difference showing an Airline training issue or an airport markings issue.
817Dreamliiner
Thu Dec 06, 2018 5:53 pm
it mentions in the link:
Gatwick reports indicated there had been at least four incidents, involving multiple operators, between September 2017 and this incident involving G-CKWC.
I'll wake from the dream, To keep and relive, Now life it is a dream, And dream's on a... BREAK!
NYPECO
Thu Dec 06, 2018 6:01 pm
Why can't they takeoff from the displaced threshold? I thought those were for taking off and not landing.
Eikie
Thu Dec 06, 2018 6:06 pm
A displaced threshold is almost always for landing. I.e., the airplane can't land in front of it.
You can depart from a position in front of the displaced threshold (in most situations).
The problem in this case was probably that the takeoff calculations were done for the full length, but due too reasons they took a wrong line up point resulting in a shorter runway available.
scbriml
Thu Dec 06, 2018 6:36 pm
Departing from the displaced threshold on 26R at LGW results in a runway that's about 1,400ft shorter than using the full length.
Given it's happened multiple times to different airlines, it seems like the airport needs to fix something quickly.
rbavfan
Thu Dec 06, 2018 7:57 pm
So now that I've read the entire report to find that answer. It is an airports issue, not Norweigans training. Mind you I did not need the 10 sections that had nothing to do with the comment I made. Would have been easy to say "multiple airlines" in your reply as you already knew the answer.
