Etops Extention
Sat Aug 28, 1999 2:48 am
What do you think about the FAA's idea to extend ETOPS range to 240 minutes? I think it sounds slightly risky, but I also realize that ETOPS has a great safety record.
mirage
RE: Etops Extention
Sat Aug 28, 1999 3:19 am
I think that´s to protect the 777 against the A340 on the routes over the Pacific. That will permit the 777 users to reroute these crossings saving money.
Luis, Faro, Portugal
CX747
RE: Etops Extention
Sat Aug 28, 1999 3:29 am
Then maybe the Airbus should have never made a twin and started ETOPS.
"History does not long entrust the care of freedom to the weak or timid." D. Eisenhower
RE: Etops Extention
Sat Aug 28, 1999 3:35 am
I think they only want to extend it to 207 minutes. That will be enough for 777 operators using the pacific routes...It is a drawback for the A340 but again the decision to go for the 777 or the 340 is not only based on two or four engines. After all the rules are going to apply to the A330 as well, and it is up to airbus to extend the jet's range if it wants to compete more efficiently...
JZ
RE: Etops Extention
Sat Aug 28, 1999 4:06 am
With the track record of 180-minute ETOPS, I think 240-minute ETOPS will be fine. But I wonder what routes can this be applied. On the Atlantic, 180-minutes is more than enough. On the Pacific, I think 210-minutes ETOPS can cover the majority of the routes.
cedarjet
RE: Etops Extention (& CX747)
Sat Aug 28, 1999 4:20 am
240 minutes (at least) is needed for some routes across the South Pacific, ie Argentina to Sydney, also Perth to Harare and Joburg. CX747, never missing a chance to deliberately misinterpret a remark and kick off that Airbus vs Boeing thing. Airbus may have pioneered heavy twins, but the 767 was the first ETOPS twin by a mile. A300 Classics have never been used on ETOPS routes, only the -600R. So sorry to deprive you of your moral high horse, Boeing started it. And please refrain from reading things into posts that aren't in fact meant (as is usually obvious).
wingman
Mon Aug 30, 1999 7:49 am
A commercial jet hasn't gone down on twin engine failure EVER. So isn't it time to extend the limits for the 777? The argument is very simple. Boeing needs it, Airbus fears it.
BryanG
RE: Etops Extention
Mon Aug 30, 1999 9:23 am
Last year I remember reading in AW&ST magazine that the fraction of flights that have engine trouble over an ETOPS area is absurdly low: 1 in 60,000 if I remember correctly. The technology in engines is incredible today; the engines of today are much more dependable than even the engines of a decade and a half ago, when twin ETOPS operations started.
