FrenchPotatoEye wrote:scbriml wrote:They can't cancel an order they haven't placed! EK has let LOI/MOU lapse in the past, so it shouldn't be that shocking.
Leeham news are suggesting that the 78X is still underpowered for EK's requirements.
https://leehamnews.com/2019/02/04/ponti ... -emirates/But Emirates’ interest in the A350 stems more from a realization the Boeing 787-10 won’t do the job the airline wants, according to the sideline conversation at the conference.
Yet neighbouring Etihad is experiencing NO issues with its 787-10s....so I call BS on that front.
And EY's 787-10s are duel class I believe, so not exactly lightly loaded machines.
kevin5345179 wrote:and Leeham reported that market intelligence says EY wants out from remaining 78J order
AsiaTravel wrote:I find it baffling that EK would order a type without making sure it can fly out of DXB at all times. Unless the order is conditional to an engine improvement but we see how this is going with RR and the A380.
Stitch wrote:kevin5345179 wrote:and Leeham reported that market intelligence says EY wants out from remaining 78J order
That is said to be due to EY's financial situation, not 787-10 performance.
Revelation wrote:747-8i technically still can be ordered.
Apparently Boeing keeps it on the book because if they cancel it officially they have to write some checks to some of the vendors of the pax specific parts.
kevin5345179 wrote:while they take other -9 ? hum .......
AsiaTravel wrote:
There are no evidences for or against it and EY's 781 haven't flown in summer yet. For all we know Etihad might be limited on some routes or can only fly full load in the morning or they just don't have any issue. Anything right know is speculation. Time will tell.
Eyad89 wrote:AECM wrote:A339NEO
Span: 64 m
Mean chord: 7.270 m
Area: 465 m2
AR: 8.8
Thrust: 2 x 324.0 kN / 72,834 lbf
B78J
Span: 60.12 m
Mean chord: 6.27 m
Area: 377 m2
AR: 9.59
Thrust: 2 x 340 kN / 76,000 lbf
Airbus and Boeing have different ways of calculating wing area. Boeing’s method gives a smaller area than Airbus’s method while measuring the same area. So it won’t be right comparing those numbers without using the same method.
AR should be (effective span)^2/ area. A339’s effective span should be more than 64m since it has a blended winglet. 78X’s effective span should be less than 60m since it has a raked wingtip.
Planeflyer wrote:I Doubt rr will become part of ab but I’m curious about thinking why they will.
smartplane wrote:Because RR Commercial provides 100% of Airbus WB engines, and GE almost 100% of Boeing WB engines.
When RR catches a cold, so does Airbus. And ditto Boeing, when problems occur at GE.
Erebus wrote:smartplane wrote:Because RR Commercial provides 100% of Airbus WB engines, and GE almost 100% of Boeing WB engines.
RR's portfolio of products goes well beyond WB engines supplied to A, granted they are probably the most significant source of revenue. A acquiring RR will be taking on a lot of deadweight and distractions in managing them when they should be focusing on their own end of things building the airframes and managing their own projects. I mean this isn't as easy as absorbing a struggling cabin parts maker or something similar to it. Powerplant manufacturing is far more complex, much more resource-intensive, and in itself deals with a vast number of sub-suppliers, not to mention the amount of risk involved.
ClipperYankee wrote:I don't think either deal would pass regulatory muster on either side of the Atlantic. Remember that P&W and Boeing were basically the same company once (along with United and Hamilton Standard) and the U.S. feds forced it to be broken up.
emiratesdriver wrote:smartplane wrote:emiratesdriver wrote:
The 'widely accepted' breakeven LF's seems a bit economic with the truth, given the difference in the number of non-Y seats on these two models (assuming both V1). Using the latest reported financials, if the LF / breakeven calculation treats every seat as Y, you can get close to the not top secret numbers. Assuming upgrades and points use are at similar ratios, 80% LF in business (89% more seats) and first (75% more seats) paints a different picture.
I’m not going to engage in a tit for tat prove this etc discussion that is typical for this wesite. I will say that the numbers are accurate, generic and widely known around EK.
They have been produced by EK and distributed around the organisation.
I accept that there will always be some variance between types, but no airline would produce a document to specifically identify individual airframes in the fleet.
sonicruiser wrote:The biggest winner of all of this is gonna be the 747-8. Boeing is not as stupid as Airbus to willingly throw away a massive order, this is Boeing's order to lose.
ewt340 wrote:sonicruiser wrote:The biggest winner of all of this is gonna be the 747-8. Boeing is not as stupid as Airbus to willingly throw away a massive order, this is Boeing's order to lose.
This B747-8 fever is getting worse and worse by day.....
Boeing kill B747-8i with B777-9. Just like how Boeing kill the previous B747 with B777-300ER.....
I still can't believe how people still thinks Emirates would order B747-8 instead of B777-9.
moa999 wrote:If, as everyone seems to predict here, the A380 is dead, do you think Airbus will release some of the A380 Plus enhancements as retrofit options (particularly Winglets and 11-across economy)?
Could possibly add some life and value to the existing fleet in a shutdown scenario, and allow Airbus to recoup some R&D dollars.
moa999 wrote:747-8i is dead either way.
RJMAZ wrote:moa999 wrote:747-8i is dead either way.
It aint over til the fat lady sings.
I could see the 747-8 still in production as a freighter after the A380 ends production.
The NMA engines would make a good option to re-engine the 747-8 in 10 years time. It would give a big boost as a freighter and without the A380 on the market it might gain momentum as a passenger aircraft.
I'm curious how many aircraft Boeing would have to pay to cover tge development of a straight engine upgrade.
morrisond wrote:Wiki has the 330CEO at 361.2m2 wing - I don't think the new wingtips added 94m2 of wing area.
lightsaber wrote:Erebus wrote:smartplane wrote:Because RR Commercial provides 100% of Airbus WB engines, and GE almost 100% of Boeing WB engines.
Pratt would love it if Airbus bought RR, it would open the high end business jet market.
I personally think it would be a strategic mistake. No longer would Airbus bid RR/Pratt/GE or a joint venture. It lock out RR from future Boeing projects, at least bids before public disclosure. e.g., competitors would have a multi year head start designing for a new Airframe.
Since this is an EK thread and they like good competition, it means in the future they would have to encourage ,(buy from) a new entrants.
RR also has expensive service contracts. Will their always be a good business case for it?
Lightsaber
Kindanew wrote:Who in their right mind would want a 747-8 Max when the 777-x can meet 95% of the requirements with two fewer engines?
The passenger version of the 747-8 sold about 50 copies. It’s not getting re engined.
Kindanew wrote:RJMAZ wrote:moa999 wrote:747-8i is dead either way.
RJMAZ wrote:Kindanew wrote:Who in their right mind would want a 747-8 Max when the 777-x can meet 95% of the requirements with two fewer engines?
Cabin area and range:
777-9 - 364m2 7525nm
747-8 - 444m2 8000nm
The 777-10 stretched to 80m only has 385m2 and just manages to reach the 747-400.
The 747-8NEO would have a brochure range near 9000nm. On a 7000nm long haul flight the 747-8NEO could carry twice the payload weight of the 777-9.
That is a massive step up in size and range. Similar to going from the 767 to the 787 in size. Or going from the 787 to 777 in size.
Kindanew wrote:But who would want such a machine to transport passengers?
The passenger 747-8 is a flop and the trend in the industry is for planes to be getting smaller.
What makes you think a 747-8 max would be a success and not an A380 neo?
RJMAZ wrote:Boeing can make the 747-8 at a profit at 12 aircraft a month. So if the VLA market can only support 12 aircraft a month then the 747 is the only one that can make it to 2040.
Airlines also like smaller aircraft. The 747-8 is actually half way between the 777 and A380 in size. This is an advantage to the 747.
The 747-8 has a better wing aspect ratio and a better fuselage fineness ratio than the A380.
Geoff1947 wrote:Just 37 in airline service with three airlines.
RJMAZ wrote:Kindanew wrote:But who would want such a machine to transport passengers?
I think the VLA market is only big enough for one aircraft to sustain a profitable production rate.
From all reports the A380 makes a loss if it is built at 12 aircraft per month. Boeing can make the 747-8 at a profit at 12 aircraft a month. So if the VLA market can only support 12 aircraft a month then the 747 is the only one that can make it to 2040.
The 747-8 has a better wing aspect ratio and a better fuselage fineness ratio than the A380. The A380NEO might need more than just new engines.
Kindanew wrote:RJMAZ wrote:Kindanew wrote:But who would want such a machine to transport passengers?
If the passenger 747-8 has so many advantages over the A380, why has the A380 outsold it substantially?
331 firm orders vs 37?
smartplane wrote:It's just a natural progression of what's happened from the day the first aircraft, engine, car, tyre, etc was built. Mega airlines are part of the reason suppliers and support industries must re-invent themselves and form mega groups. And vice versa.
Noshow wrote:The 747 freighter is certainly not dead for the time being. Think Amazon. They haven't even started yet.
However as all those 777-300ER will come to the freighter conversion market soon they might kill 747F freighter demand from below.
JoeCanuck wrote:Kindanew wrote:RJMAZ wrote:I think the VLA market is only big enough for one aircraft to sustain a profitable production rate.
The fact is, neither has sold particularly well. The twins have pretty much sounded the death knell to the big quads...at least as passenger aircraft. The 748F will likely sell a few more but it doesn't compete in any way with the 380.
The 777-9 will probably be significantly more efficient than either, and it isn't exactly flying off of the shelves.
It kind of seems to me that we may be getting close to the peak of airliner demand for this cycle. I won't be surprised if we see a lot more deferrals from a bunch more airlines in the near future. I suspect the downsizing won't be limited to just aircraft size...but numbers as well...with the single aisles being the most immune to this trend.
Kindanew wrote:If the passenger 747-8 has so many advantages over the A380, why has the A380 outsold it substantially?
RJMAZ wrote:Kindanew wrote:If the passenger 747-8 has so many advantages over the A380, why has the A380 outsold it substantially?
You might want to check your sources.
In the past 4 years the 747-8 has had 36 orders the A380 only 4 orders. The 747 also cost Boeing less than a third to develop. The 747-8 is a borderline success the A380 program is a total failure.
15 billion dollar development for 331 aircraft.
4 billion dollar development for for 154 aircraft.
The 747-8 will definitely break even and it has and will continue to make money on each frame.
The accounting is complex but I'll try and dumb it down for you. These numbers are made up but are approximate to keep the math simple.
On each frame Boeing might make $40 million profit. $20 million of that profit will be allocated to pay off the development cost. The other $20 million goes to the end of year company profit. The remaining money from the sale covers the cost of construction.
That $20 million allocated for development is calculated by taking the development cost of $4 billion and dividing it by 200 aircraft. If Boeing works out that it will sell only 150 aircraft then it must take a one off hit of $1 billion. This is what Boeing has done.
Some members think that one off hit means the program has made a loss. That is not the case. Boeing has still been making $40 million profit per frame, they simple did not allocate enough of that profit towards paying off develooment. With 150 frames sold that would be $6 billion of profit which is well over the $4 billion development cost. As Boeing is still making profit on every frame it will or already has broken even and will continue to slowly make a profit.
Now the same can not be said about the A380. It has not been making enough profit per frame to cover development. Airbus is now making a loss on every frame so it will never pay off the development cost.
Kindanew wrote:RJMAZ wrote:4 billion dollar development for for 154 aircraft.
I am specifically talking about the passenger A380 as the cited quotation clearly shows. Of course the freight version of the 747-8 has sold 100% than the freight A380.
