readytotaxi
BA27 A380 having problems currently.
Fri Feb 08, 2019 10:40 pm
https://www.flightradar24.com/BAW27/1f70aa0f
LHR-HKG got about 30 mins into the flight and is now doing laps over the East Coast at 10,000ft, fuel dump perhaps before returning?
Growing older, but not up.
CarbonFibre
Re: BA27 A380 having problems currently.
Fri Feb 08, 2019 10:42 pm
QF2 did the same last night!
TCX69K
Fri Feb 08, 2019 11:10 pm
The aircraft is unable to retract the flaps and so is returning to LHR to nightstop.
readytotaxi
Fri Feb 08, 2019 11:24 pm
Captain. "Better ring the wife incase the window cleaner is staying the night" :duck:
Slug71
Fri Feb 08, 2019 11:28 pm
:lol: :lol:
Utah744
Fri Feb 08, 2019 11:36 pm
Flew with a FO who's wife had the roofer spend more time inside than on the roof.
You are never too old to learn something stupid
MrBretz
Fri Feb 08, 2019 11:42 pm
The plane has been left hand racetracking for 3 hours now. I thought the A380 could dump fuel. Any reason why it hasn't?
AirKevin
Fri Feb 08, 2019 11:44 pm
Can you dump fuel with the flaps extended?
Captain Kevin
AndrewJM70
Fri Feb 08, 2019 11:52 pm
It was going to Hong Kong. That is a lot of fuel.
mwhcvt
Sat Feb 09, 2019 12:10 am
Purely from a PR perspective I can see an airline would rather not dump fuel unless it’s an emergency warranted it, in the age of social media and environmental activism so as this fault was not an immediate flight risk better just to fly until max landing weight is achieved, probably serve a few meals and drinks and more over give people on the ground time to book coaches and hotels without a baying crowd, just think they can wait a couple of hours, serve some complimentary drinks, and have hotel rooms and coaches waiting for when they land
Must think up a new one soon, slow moving brain trying to get into gear ;)
MrBretz
Sat Feb 09, 2019 12:18 am
Good point. I hadn't thought of that. Maybe you only dump fuel if it is a real emergency.
Slug71
Sat Feb 09, 2019 12:25 am
Is it not safe to fly with the flaps extended?
Polot
Sat Feb 09, 2019 12:32 am
Probably wouldn’t be able to make it HKG. Would be prerferabe to have the passengers and plane at home base rather than at a random outstation.
MaksFly
Sat Feb 09, 2019 12:33 am
Um... can, but limited and burn a lot more fuel would think. =) In either case, would be silly to go on.
kearnet
EDIT: sorry misread the question: they can't fly at full speed and the flaps increase full burn. So while it’s perfectly safe in general, it'll take them longer if they tried to go on and might end up not having enough fuel.
As said above, it’s better to just land back at home where there's MX readily available and resources for pax, instead of potential diversion.
*Original reply: Of course, just have to slow down a bit. The extra drag burns fuel faster which is what they want in this case, so they're good until they're ready.
C402 9K | B1900D US | ATR72 AA | DHC8 US | CRJ2 US | E190 B6 | D93 US | M88 US/AA | 727 US | 732 US | 733 US/WN | 734 US | 73G WN | B738 FJ/QF | B752 US/AA | B762 DL | B77W EK | F28 US | F100 US | A319 US | A320 B6 | A332 FJ | 380 EK
mwhcvt
Sat Feb 09, 2019 12:35 am
The added drag would likely mean they wouldn’t have enough fuel to make it there, stopping on route with a exisitng fault and or ended up tech at and outstation is not something ops would want better to RTB
blueflyer
Sat Feb 09, 2019 12:38 am
Any idea how long for they'll be going nowhere? Does the crew do their normal service in the meantime?
Inadequate healthcare killing more than illegal immigrants, that's a national emergency
Opioid crisis killing more than illegal immigrants, that's a national emergency
Would-be king who can't figure this out, that's a national emergency
MrBretz
Flightradar shows the next arrival at LHR at 4:45AM. And you don't see anyone landing there now. Is there a hard curfew at LHR? Maybe that's why they are holding?
CplKlinger
Sat Feb 09, 2019 12:43 am
If you've got a MX issue, they're going to let you land. Not like they can say "Sorry chaps, fields closed till 0600. Can you hang out a bit till then?"
Slug71
Sat Feb 09, 2019 12:46 am
Thanks for the replies. Was just curious why they didn't continue on to Germany or something. Make sense though.
reapermech77
Sat Feb 09, 2019 1:00 am
Still doing the racetrack over the channel
harleydriver
Sat Feb 09, 2019 1:05 am
According to FR24, looks like its leaving the holding pattern and heading back to LHR.
Department of Redundancy Department
reapermech77
Sat Feb 09, 2019 1:21 am
Just turned away from LHR according to FR24
Feroze
Sat Feb 09, 2019 1:23 am
It's now flying the Lambourne hold at FL80 and I've just heard it overhead!
EK413
Sat Feb 09, 2019 1:35 am
Is this the Le Tour de London? 4 hours to no mans land :D
EK413
Good evening, ladies and gentlemen. We are tonight’s entertainment!
Feroze
Sat Feb 09, 2019 1:42 am
Looks like it's now on final descent through 3000ft and heading for Heathrow 27L.
Correction: 27R
bhxalex
Sat Feb 09, 2019 1:56 am
She's just whistled past my window in Brentford. Could hear her reverse thrust from 4 miles away.
CplKlinger
Sat Feb 09, 2019 2:39 am
If it's close enough to their home field, it's easiest for MX and accommodating pax to just go back. Could also be visa issues for some folks in a third country, depending on their origin.
qf789
Sat Feb 09, 2019 8:27 am
Forum Moderator
arcticcruiser
Sat Feb 09, 2019 8:48 am
qf789 wrote:
“After having to dump fuel for 4 hours”. Idiots.
CarbonFibre
Sat Feb 09, 2019 9:01 am
BA28?
I have corrected the post, it should have said BA27
qf789
arcticcruiser wrote:
Dont be so naive. The fuel dumping was necessary in order for a safe landing. Without dumping fuel the aircraft would have been severly overweight and the runway would have not been long enough to stop the aircraft. Maybe you need to look at QF32, in that they were grossly overweight of which they would have had less fuel on board being SIN-SYD over LHR-HKG of which when they calculated how much runway they needed they would just make it on a 4000m runway
Forum Moderator
arcticcruiser
Sat Feb 09, 2019 9:27 am
Who is being naive? Silly wording by whoever these Twitter “Airlive” are. First you would not dump fuel “for 4 hours”, but you could be burning off fuel for 4 hours. Totally different. If they really had to dump fuel, that would have taken a lot less time. Do not need any lectures from you on runway length vs. landing weights, I have had to do overweights landings a few times. Last one about 4 months ago due to a medical emergency.
philvardon
Sat Feb 09, 2019 9:30 am
I think that the poster is implying that Airlive are idiots for saying that the aircraft dumped fuel for four hours. When what it really did was burn fuel for four hours to get under MLW
FlapsOne
Sat Feb 09, 2019 9:39 am
I’m a mere A320 flyer but jammed flaps will significantly increase your fuel burn. I guess given the size of big moma’s flaps and slats that the fuel burn would be even worse. Besides flaps or slats down mean you’re going to be flying very slowly which means an even longer flight to Honkers!
If the machine isn’t happy then where better to give it the TLC that it needs than its home base?
WIederling
Sat Feb 09, 2019 9:56 am
If you fly the passengers around all night long you don't have to pay for their hotel storage :-)
Murphy is an optimist
Armodeen
Sat Feb 09, 2019 10:46 am
You can't argue with that logic :lol:
Binford
Sat Feb 09, 2019 11:12 am
If they really dumped fuel why would they fly around for 4 Hours? Sound more like burning of fuel.
SEPilot
Sat Feb 09, 2019 1:04 pm
While dumped fuel will vaporize, it is still highly undesirable from an environmental standpoint. If there was a valid reason why it would be necessary to land as soon as possible (engine problem and medical emergency come to mind) then dumping fuel wins out over a dangerous overweight landing. But with a problem that is not going to get worse, like stuck flaps, burning the excess fuel off makes more sense.
peterinlisbon
Sat Feb 09, 2019 1:44 pm
It would be impossible to fly all the way to Hong Kong with the flaps extended and if it landed somewhere else BA would have a damaged aircraft away from home and need to fly engineers out there or find a local contractor which would charge them a high price. It would also have 500 pax at an airport that does not have enough BA staff to deal with them. Some pax may not even have visas for Germany and be unable to disembark there.
It's far easier to just bring the aircraft back to base and put the pax on the next flight to HK, then tow it into their hanger and have their own specialised staff look at it.
tallis
Sat Feb 09, 2019 2:07 pm
Just to end the speculation, they did dump fuel.
I know because I was operating an aircraft in the descent to Stansted at around 22:30z and they’d just been given permission on the same frequency (can’t remember if it was Thames or London) to begin jettisoning.
7BOEING7
Sat Feb 09, 2019 6:52 pm
Normally in a 4 engine airplane you fuel jettison to get below max landing weight -- in twins there are other reasons. However, in this case with a flap issue, they needed to dump a lot more fuel to get down to a safe landing speed. They probably couldn't move the flaps to the normal landing position and were forced to add 25 +/- knots to their landing speed. The fuel dump probably took a little over 2 hours with coming, going, troubleshooting and checklists covering the rest. If they just flew around and didn't dump fuel the flight would have been several hours longer.
neutronstar73
Sat Feb 09, 2019 7:35 pm
I like that idea. Very smart. Excellent observation.
SheikhDjibouti
Sat Feb 09, 2019 8:33 pm
I believe I read somewhere that fuel dumping from altitude rarely resulted in anything actually hitting the ground.
Whether that was the case from a relatively low 10,000 ft altitude I couldn't say.
That just leaves whether it was better to dump the fuel, and have it evaporate into the atmosphere
or
Whether it was better to burn it and generate additional CO²
In reality neither is a good option for the environment.
I did have one rather absurd thought regarding keeping the pax airborne until BA had prepared things on the ground for them; what if BA were busy organising a replacement A380 & crew (assuming they could find a spare one at short notice). How many pax would enjoy the thought of a 4 hour flight to nowhere, followed immediately by another 11-12 hrs actually flying to HKG? I concluded it was probably a bad idea even if it was feasible.
DocLightning
Sat Feb 09, 2019 9:26 pm
This is the first time in my memory that I've heard of a primary flaps malfunction (without something else obviously causing it). What could cause it?
What kinds of logic are built in to ensure that the aircraft remains controllable with jammed flaps? Is there logic to prevent the LE slats from retracting, for example?
-Doc Lightning-
-Carl Sagan
c933103
Sun Feb 10, 2019 4:37 am
or
Given that they have to fly this number of hours to dumb the fuel anyway and the aircraft wasn't really dangerous, could it be a viable choice to use the fuel to fly them to say Dubai and then let EK carry them for the rest of the journey? That would minimize the travelling time of affected passengers although the image wouldn't be that good for BA and one would never know when might some other things in the aircraft went wrong that requires a more emergent handling
wildwobby
Sun Feb 10, 2019 4:59 am
or
You should really read the thread since this point has been adressed a few times already.
In addition, “let EK carry them the rest of the journey”? Do you think EK is some sort of charity?
A319 A320 A321 A380 B712 B733 B735 B736 B737 B738 B739 B752 B753 B763 B772 B77W B788 CONC CRJ2 CRJ7 CRJ9 DC10 E120 E145 F100 MD80 MD83 MD88 MD90
harleydriver
Mon Feb 11, 2019 12:37 am
Not really a viable option. The amount of coordination required would be horrendous. Does EK have a spare jet and crew available? Does EK have space in a hanger to work on this jet in addition to their own maintenance requirements? Someone late at night has to coordinate contract prices for EK to do this for BA if they continued on and only if EK had an available aircraft and crew at Dubai. They did the right thing and I'm sure it wasn't a difficult decision to make. Dump fuel to land at a safe landing weight and speed and apologize severely to the inconvenienced passengers. If BA had another aircraft and crew available, order many extra first class meals for everyone and stock up on liquor for free drinks for the next 12 hours and get them on their way. It could be an easy fix to the aircraft or it could be an extensive repair and its much better to have your own crew working on it.
hz747300
Mon Feb 11, 2019 12:46 am
This makes sense. I saw a BA A380 taking off from HKG around 5pm-ish yesterday so I opened Flight Radar and saw it was BA28D. That would put them in London around 11pm I guess.
Keep on truckin'...
Rivet42
Mon Feb 11, 2019 11:19 am
Yup, G-XLED departed LHR as the delayed BA27D at 20:15 on 9th, arriving HKG 15:24 +1, quick turnaround (for the previous nights' passengers), departed 18:06, and landed back at LHR last night at 22:27.
So it wasn't just the pax ex London that needed hotels, it was also the planeload at HKG, although they would at least have had 16+ hours warning. No doubt VS and CX picked up what they could.
Ironic, I always prefer a daytime flight back to London from HKG, so almost always take CX. Wish BA did this quick turnround as a routine, but it obviously doesn't work for them to have a 380 landing back at base too late to go anywhere else.
Riv'
I travel, therefore I am.
