gf-a330
Can This Runway Really Handle A 747?
Tue Mar 19, 2002 8:16 pm
The runway at BHX looks pretty short, to handle this 747 of PIA. The take off run has taken majority of the runway.
Click for large version
Photo © Andrew Brooks
What do you think ?
AMSMAN
RE: Can This Runway Really Handle A 747?
Tue Mar 19, 2002 8:27 pm
Onbviously seeing as they let a 747 take off on it!
AMSMAN
Aer Lingus, Proud to be Irish.
SQ325
Tue Mar 19, 2002 8:34 pm
Photo © Kelvin Poon
KaiTak handled more B747s than any other Airport in the world!
regards Bjoern
lmml 14/32
Tue Mar 19, 2002 8:44 pm
Sometimes these jumbos are weight restricted to be able to take off. They either take fewer pax or less fuel then make a tech stop somewhere else. It interesting to note that having sufficient runway to abort safely is also a consideration when calculating field requirements. When runway is wet or in icing conditions the length required to stop increases significantly.
TS-IOR
Tue Mar 19, 2002 8:52 pm
What about St Maarten rwy so ? It is more common to see 747s landing on it !!!
Next flight TUN-YUL Tunisair A330-243.
ammunition
Tue Mar 19, 2002 9:12 pm
The PIA 747 has a scheduled stop at copenhagen en route to pakistan, so they were able to take off as they had very little fuel required for the 1 hour or so flight, and also the number of passangers may not have been the maximum possible for the plane. I think they are restarting BHX later this week or the beginning of april, with an A310- which should not require a stop, but whether they are adding one for the sake of it remains to be seen, maybe someone can confirm this, it has been discussed before recently  Big thumbs up
regards
Ammunition
Saint Augustine- 'The world is a book and those who do not travel, read only 1 page'
cedarjet
Tue Mar 19, 2002 9:47 pm
Remember that aviation is a business and it is in the interest of airlines to consume as little fuel as possible (they waste enough in holding patterns after all). So the take-off thrust will be calculated to ensure fuel economy. So a flight might use most of the runway even if it could lift off halfway along, but due to a reduced power take-off VR comes somewhere near the end. Doesn't mean the flight is near max weight.
LY744
Tue Mar 19, 2002 9:57 pm
Rwy 15-33 in BHX is 8537 feet long, while the runway at SXM is 7000 feet long, and handles 747's regularly (although they T/O with a light fuel load and fly to a larger airport in the region). BHX's elevation is about 300 feet higher.
LY744.
Tue Mar 19, 2002 10:03 pm
A little correction, Kai Tak did not handle more 747s than any other airport, that coveted title goes to none other than Narita New Tokyo Int'l Airport!
The reason? Simple, JAL is the world's largest operator of the 747. They have operated the 747 in every marque except the SP. From the -100s to the current Sky Cruiser -400s.
Photo © Mel Lawrence
Photo © B. van Langenberg
Photo © STUART PRINCE
Photo © Neville Murphy
Photo © Sam Chui
Photo © Philippe noret
Couple that with United and Northwest making NRT their hub and they visit daily with their numerous 747 trans-Pacific fleet. Is that a lot of 747s or what? Since NRT is a major destination, 747s from other carriers are also very evident everyday!
Ryan
KAL_LM
Wed Mar 20, 2002 2:53 am
You'd be surprised at how short of a runway the 747 really needs, especially with weight restrictions and light fuel loads. Even so I've seen some pretty heavy 747s go off of 8,000ft...
Tom
is that a light at the end of the tunnel or just a train?
Lekky-Man
Wed Mar 20, 2002 4:31 am
Apart from anything else, that piccy of the PIA 742 makes the runway look really short, but i can tell ya, you wouldn't wanna run from one end to the other!!!
Anyway's, it all makes it really exiting watching these things come and go.
A couple of weeks back when we had all those extreme winds, i was at BHX when they were using runway 15, and I watched the Emirates A.330 arrive, after several had done go arounds due to wind sheer. It managed to get down eventually just before the intersection!! I don't think I'll ever get the chance to see an A.330 on full reverse ever again!!! (almost like chucking out an anchor!!)
LM
757man
Thu Mar 21, 2002 4:33 am
That photograph is taken at such an angle whereby it deletes the remaining 3000ft or so runway remaining. The PIA 747's used to rotate off BHX's main runway at around the halfway point on average, usually with over 300 passengers on board. The tech stop in CPH enabled them to do this. The runway at BHX is a similar length to DUB and GLA - two airports which handle widebodied aircraft on a regular basis. BHX is more than big enough to handle the 747 - It just can't handle fully loaded examples. Not even a 3000m strip can do that though...
EGGD
Thu Mar 21, 2002 5:49 am
How about Cardiff? Runway is only 2300m long but they handle 747's and 777's regularly (yeah they are empty, so what).
Dan  Smile
ATA L1011
Fri Mar 22, 2002 3:10 am
Heck I have seen heavy 727's at LAX run longer than heavy 747's, their are alot of factors in determining who can do what.
Treat others as you expect to be treated!
gf-a330
Fri Mar 22, 2002 7:10 am
Sorry to go off topic, but I presume PIA are resuming Birmingham services, next week right ?
hawkeye2
Fri Mar 22, 2002 9:46 am
I've seen NCA 747Fs take off from SFO's 1L, 7000' in length. They were bound for LAX -- rather lighter than if they were doing the transpacific runs!
