konrad
Is it possible to downgrade B737MAX to 737NG?
Fri Mar 15, 2019 6:11 pm
I hope the moderators will allow this silly question in the subject line. This is for the sake of asking more informed members of this forum about their technical expertise. What are the modification of B737MAX vs B737NG apart from the different engines and, obviously, attachment pads and interfaces with the wings? Would it be possible at all to modify parts of the wing and attach 737NG engines to a 737MAX airframe? This has nothing to do with why would one do such a thing, just speculating.
adamblang
Re: Is it possible to downgrade B737MAX to 737NG?
Fri Mar 15, 2019 6:21 pm
I Googled "what are the differences between the 737NG and 737MAX" and got this:
http://www.b737.org.uk/737maxdiffs.htm#diffs
146 319 320 321 332 333 343 717 734 735 73G 738 739 744 752 753 763 764 772 773 789 AR1 AT4 CNA CR2 CR7 DC9 ER3 ERD ER4 E70 E75 E90
BOSAero
Fri Mar 15, 2019 6:24 pm
Aside the 737 name and look, the MAX is a completely different iteration of the model. I’m sure If someone wanted to do this, the old CFM engine from the NG would not fit on the pylon. Or if you would like to change to the old pylon from the NG, it would not fit on the MAX wing..... so on and so forth....
This same scenario goes for pretty much everything else on the airplane. (Avionics, pneumatics, electrical systems, hydraulics, etc).
What you’re asking is to reengineer the MAX back to an NG. Right? Makes no sense.
Sooner787
Fri Mar 15, 2019 6:55 pm
Best way to do that is convert your new Max order to an 737NG order, assuming Boeing would be open to building a few more
anshabhi
Fri Mar 15, 2019 7:06 pm
For the coming days, Boeing will only be able to build NG
SNN99
Fri Mar 15, 2019 7:08 pm
Says who, they have said themselves they will continue to build through the grounding.
Sooner787
Fri Mar 15, 2019 7:09 pm
Actually..... they're still building Max's , they just stopped deliveries.
They'll have quite a backlog of frames to deal with once deliveries resume
Arion640
Fri Mar 15, 2019 7:25 pm
Why would airlines want to do that? The plane will be flying again in a few months.
223 319 320 321 333 346 359 388 733 73G 738 744 752 753 763 772 77E 773 77W 788 789 E145 E175 E195 RJ85 F70 DH8C DH8D AT75
Brexit - It’s time for global Britain.
Finn350
Fri Mar 15, 2019 7:26 pm
Of course it would be possible although it would be so expensive that there is no point in it.
Boof02671
Fri Mar 15, 2019 7:30 pm
Not true, they are still building thee MAX over 50 a month.
GalaxyFlyer
Sure, take it to hot rod shop that specializes in conversions, they’ll saw it up, hang the old engines on it with an adapter plate, you’re good to go. My God, where do these ideas come from?
Gf
anshabhi
Fri Mar 15, 2019 7:31 pm
Isn't is stupid to make an airframe which is globally grounded, without any modifications at all?
D L X
Fri Mar 15, 2019 7:37 pm
The time it takes to build an airframe from scratch is much longer than the grounding will be.
Especially if the fix is in software, it is likely that the fixes will be inserted into the workflow at the appropriate point when they are available, and any undelivered ships would be modified just like the ones currently in airlines' hands.
Also, shutting down an assembly line is expensive. Restarting it is even more expensive. Entire supply chains are affected. If you imagine a simpler product, say a house, halting construction on the house means stopping the shipment of parts - windows, doors, floorboards, etc. That means that the guy that makes the windows, doors, or floorboards, has to stop production too. THAT means the guy that cuts the wood or makes the glass panes has to stop production too. Halting construction has massive downstream effects that if can be avoided, should be.
Hell, in the auto industry, it's a BFD when they shut down a plant for a few hours, it does so much damage to the supply chain.
SNN99
Fri Mar 15, 2019 8:00 pm
Boeing has said the software update will be out in 10 days
Gazdon121
Fri Mar 15, 2019 9:01 pm
While they continue to build through the grounding, does Renton have the space to store these frames
jfk777
Fri Mar 15, 2019 9:27 pm
If it becomes a "Renton no space" problem Boeing can fly the MAx to other nearby airports. At some point Boeing is going to have test and re certify whatever the "Fix" is.
Campo
Fri Mar 15, 2019 10:13 pm
How can they fly them when they are grounded?
Boof02671
Fri Mar 15, 2019 10:29 pm
They are allowed test flights and maintenance ferry flights.
Airlines0613
Fri Mar 15, 2019 10:31 pm
Boeing can obtain permits from the FAA, which most likely will be granted.
precure787
Sat Mar 16, 2019 4:48 am
In terms of modifications, no. In terms of exchanging orders, yes.
The only 737NG variants that are still in production are the -800 and the -900ER series.
Edward Zen/Precure 787
Heinkel
Sun Mar 17, 2019 10:29 am
This shows the problem with the people of the IPhone- and TESLA-generation; They think, everything can be fixed with a simple software update/upgrade.
In this case, may be it can, may be it can't. Be sure, that there are many high level meetings behind closed doors at the moment, where Boeing mangagers discuss, what to do with the MAX production.
The MAXes roll out from the assembly line in much higher numbers than the 787s, when they were grounded. So Boeing can't go on with a 50 per month production for a year or so, when it is not clear, how the solution looks like. Best case: A software update fixes the problem. Worst case: 737MAX needs a complete new type approval and grandfathering is denied.
Interesting times ahead.
stratclub
Sun Mar 17, 2019 11:12 am
Safety, safety safety. Even with existing designs issues do pop up and if these issues have a negative effect on safety, you ground all aircraft with that safety issue. Stupid? No. You can not plan for a problem that you don't know about yet.
I would imagine that Boeing has not stopped production on the MAX. Whether Boeing could fly B1 (first flight) over to the delivery center at BFI would depend on the FAA granting a special permit with appropriate restrictions. Boeing may well be doing validation flights with FAA approved restrictions. They just can't get validation for the airworthiness certificate until the current problems are fixed which would mean no deliveries would be allowed.
stratclub
Sun Mar 17, 2019 11:22 am
Completely bad idea. The lack of parts in the NG supply chain would stop production dead in it's tracks.
SNN99
Sun Mar 17, 2019 12:24 pm
Wrong! NG production finishes on May 3rd
D L X
Sun Mar 17, 2019 12:56 pm
I’m not of the iPhone/Tesla generation. I’m a computer engineer and lawyer from the 90s, before Tesla and iPhone existed. When you assume...
I did not say everything can be fixed with software, but as has been reported widely, Boeing is attempting to fix this with a software update to the MCAS system. (Note the big fat “if” in there.) So, what is untrue with what I just described?
Also, who here actually thinks it will be a year before MAX flies again? If it does take a protracted amount of time, yes, you will see a halt or slowdown in production. We ain’t there yet.
Now get off my lawn. :p
Stitch
Sun Mar 17, 2019 3:44 pm
Commercial NG production may be scheduled to end then, but there will still be military 737-800A frames produced for the P-8 program.
namezero111111
Sun Mar 17, 2019 4:23 pm
Hehe.. yes, sure, you can start with just the data plate.
Whether it's economically viable is another question :}
precure787
Sun Mar 17, 2019 9:46 pm
The production usually finishes when there's no more unfilled orders. You can't necessarily or precisely predict when the production would be finished with no outstanding orders. The 747-8, for example, would've ended production no later than 2020, but thanks to UPS doubling their 747-8F orders, the very last 747 would've rolled off the production line at around 2020. Airbus' quadjets, on the other hand, had to end the production earlier than they had expected, due to lack of further orders. Therefore, once the last order is filled with no new orders, it's done.
Users browsing this forum: Kindanew, Lukas757, SFOmm, Web500sjc, Wedgepark and 18 guests
