United Airline
Any B 777s For UA Between SFO And JFK/EWR/LGA?
Wed Mar 20, 2002 6:13 pm
Can anyone tell me whether or not, UAL provides B 777 service between SFO and JFK/LGA/EWR?
Also, NRT-JFK is still being flown by the B 777-200ER. Right?
mjzair
RE: Any B 777s For UA Between SFO And JFK/EWR/LGA?
Wed Mar 20, 2002 9:28 pm
Not sure about JFK/EWR - but definately not LGA. Actually, I do not think that there are any 777's flying the route, from what I have seen, Delta, AA, and United use a combination of 763, 762 and 757's. I am not sure if anyone else flies the route.
United Airline
Wed Mar 20, 2002 9:31 pm
Then what about JFK and EWR?
MAH4546
Wed Mar 20, 2002 10:02 pm
No. Only trans-cons with 777s are MIA-LAX, MIA-SFO, IAD-LAX, IAD-SFO.
a.
United Airline
Wed Mar 20, 2002 10:14 pm
What about the B 767?
Also, is there any UAL B 777 in EWR/JFK?
Wed Mar 20, 2002 11:19 pm
UA flies 777s from EWR to LHR and from JFK to NRT. UA will also fly a 777 from JFK to LHR this summer. The777Man
TOMASKEMPNER
Wed Mar 20, 2002 11:25 pm
LGA´s runway has several rstrictions, aircraft as large as the 777 can´t use the runway. I think that the largest airliners LGA could handle is the 763
FrequentFlyKid
Thu Mar 21, 2002 12:36 am
MAH4546 - Don't forget ORD-LAX, ORD-SFO, DEN-LAX, DEN-SFO, and ORD-DEN.
mikephotos
Thu Mar 21, 2002 12:44 am
TOMASKEMPNER,
LGA can handle B767-400, DC-10's & L1011's and even an A300-600ST Super Transporter.
Michael
McRingRing
Thu Mar 21, 2002 12:50 am
UA flies DEN-EWR with a 777 and that is the flight that continues to LHR I believe.
DEN-EWR-LHR
B==============) ~~~~
B20XX
Thu Mar 21, 2002 12:53 am
UA flies a 777 from JFK to LHR for the evening flight. They downgraded to a 763 after 9/11 but it's now back to a 777. The morning flight between JFK and LHR has always been a 763.
I was told the largest plane LGA can handle is the 767-400. Can someone confirm this?
mikephotos
Thu Mar 21, 2002 1:01 am
Well, do you consider a 767-400 larger than a DC-10 or L1011? I have photos of AA DC-10's and TW L1011's at LGA. The A300-600ST also visited but wasn't able to get any shots.
Michael
MAH4546
Thu Mar 21, 2002 5:29 am
FrequentFlyKid, I didn't forget them. Those routes are not trans-con routes.
a.
FrequentFlyKid
Thu Mar 21, 2002 5:41 am
Mah4546 - Calm down, I wasn't attacking you or anything. Merely adding to your information. Why don't you think ORD-LAX is trans-con?
Thu Mar 21, 2002 5:53 am
JFK-LHR:
UA976: 767
UA956: 777
JFK-NRT:
UA801: 777
EWR-LHR:
UA906: 777
No 777 domestic service from New York (JFK, LGA, EWR)
MAH4546
Thu Mar 21, 2002 6:19 am
FrequentFlyKid, calm down? I wasn't attacking you either. All I said was I didn't forget them, sorry if you took it the wrong way, I apologize. LAX-ORD is not a trans-con for a very simple reason. A trans con goes from one side of the coast to the other. MIA-LAX, JFK-SEA, BOS-SAN, etc. Not even ATL-LAX is a transcon, because ATL is not on the coast.
a.
ILUV767
Thu Mar 21, 2002 3:10 pm
United Airline,
All of the information that you request can be dound by going to http://www.ual.com
But to answer your question...
On the SFO/LAX-JFK flights it is a 767 only route. This is what we call a premium transcon. The 767 is a perfict plane for this route as it is cheap to operate and can allow for maximum revenue to be brought in. The 767s used on this route feature 3 cabins of service, and often sell out the premium cabins.
EWR used to have a 767 from SFO, but that is gone now.
I L U V 7 6 7
Thu Mar 21, 2002 4:39 pm
DEN-EWR will go to a 777 in Apr or Jun. The777Man
