AirbusOnly
LH 447 diverted to KEF
Mon Apr 15, 2019 6:49 am
Just saw that LH 447 DEN-FRA was diverted to KEF, I assume it is a medical issue.
https://www.flightradar24.com/DLH447/202854c0
readytotaxi
Re: LH 447 diverted to KEF
Mon Apr 15, 2019 8:48 am
Probably was, just taken off now on route.
Growing older, but not up.
330lover
Mon Apr 15, 2019 11:55 am
Hi, just wondering if there is any specific reason to divert to KEF?
Seeing the flight path, it would look logical to continue to Ireland (SNN, DUB), which is more in the direction and does not look further away than KEF.
Or is there more 'space' to accommodate diversions at KEF than at SNN/DUB?
May seem a stupid question, but I'm just curious...
Britten Norman Islander VP-FBR on Falkland Islands. THAT'S FLYING!
Mon Apr 15, 2019 12:09 pm
SNN and DUB would be 700-800 nm further. Around 1-1.5 hrs more flight time.
hvusslax
Mon Apr 15, 2019 1:04 pm
KEF was probably significantly closer. Eyeballing the map on FR24 can be misleading as the map projection used there gets very distorted at higher latitudes.
330lover
Mon Apr 15, 2019 1:29 pm
zeke, hvusslax,
thanks, makes it clear. Knew there would be an obvious reason for choosing KEF, and now I know why :)
Comparing distances on a map is indeed very different than the reality, did not know it's that different...
