TS-IOR
An Excerpt From Tunis ATC
Mon Mar 25, 2002 9:27 pm
This is what i listened to today Monday 25 from Tunis ATC between 0832 and 0913 UTC :
TAR 8000 contact Roma 128.8 bye !
AFR 1285 switch over Roma 135.7
HB-LSP good morning
HSP continue as cleared
TAR 752 contact Roma 135.7 "beslema" !
TAR 466 approaching SARDI contact Roma 135.7
TAR 700 approaching OSMAR switch over Roma 135.7
TAR 4825 proceed MON to JBA for Rwy 09
BELAIR 114 bonjour monsieur radar contact,final level ?
BELAIR 114 climb FL400,4-0-0 !!!
HLF 025 radar contact,MON-JBA final Rwy 09
BELAIR 114 change 132.55
TAR 788 bonjour,i call you back for higher !
BELAIR 114 radar contact,continue as cleared !
HLF 192 confirm leaving 106 ?
HLF 192 radar contact,continue climb FL360
TAR 788 climb FL300
Hercule 38 changez 129.3
Hercule 38 pour essai radio claire et net !
Hercule 38 rappelez pour la descente !!!
HLF 192 change 132.55 , 132.55 !
............you try again infew minutes !
............ ok no problem,when possible,132.55 !
TAR 4825 descent FL110
HLF 025 after MON proceed direct to ZEKRI for Rwy 09
TAR 650 sbah'el'khir finallevel requested ?
TAR 650 climb FL320
HLF 192 confirmchanging 132.55
HLF 192 loud and clear,continue as cleared
BELAIR 114 climb FL420
BELAIR 114 stop climbing FL410 for the moment
BELAIR 114 FL420 is not your correct level,up 430 !!!
AFR 2584 bonjour !
AFR 2584 proceed NOLSI-TUC for Rwy29
BELAIR 114 maintain410 final for the moment
TAR 670 contact Roma 135.7
Hercule 38 descendez 110
TAR 650 change 132.55
TAR 788 Roma 135.7
HLF 025 descent FL120
TAR 4825 change 129.3
TAR 650 on 132.55 how do you read ?
TAR 4825 loud and clear,continue as cleared
HLF 025 change 129.3
TAR 4825 radar service terminated,Djerba 118.15 !
Hercule 38 fin service radar,Tozeur 118.2 au revoir !
.. 4166 bonjour radar contact,final level requested ?
.. 4166 climb FL360
AFR 2584 proceed direct to MARSA for Rwy 29
BELAIR 114 contact Roma 128.8
AFR 2584 contact Carthage radar 121.2
HSP approaching OSMAR?SWITCH OVER Roma 135.7
HLF 025 maintain 120 when reaching
........... radar service terminated,Djerba 118.15
...AND THE CIRCUS GOES ON 24/7 ...
Of course,it wasn't a rush hour !!!
It would be kind if you give excerpts from your local ATCs !!!
Thank you !!!
