jhooper
Rolls Royce RB-211 Engines On The L-1011
Thu May 02, 2002 10:55 am
The RB-211 engine is the best-sounding engine ever made, in my opinion. Just listen to it spool up in the video clip below!
http://airside.paradise.net.nz/video/deltal1011honoluluto.wmv
I know this engine caused some economic problems for the Tristar, butw was this engine considered reliable? Also, were any other engines used on the L-1011?
Last year 1,944 New Yorkers saw something and said something.
IMissPiedmont
RE: Rolls Royce RB-211 Engines On The L-1011
Thu May 02, 2002 11:00 am
No other engine was ever used on the L-1011. It was, barring the human FUBARs, a very reliable engine.
The day you stop learning is the day you should die.
MDCJets
Thu May 02, 2002 11:01 am
Economic problems came from the financial situation at the RR company not the RB-211 itself. I beleive they were very reliable. Many aircraft today are powered by them today (757,767,747) but somehow dont have that unique sound that the L-1011 had. I sure wish I could still see DL L-1011s at LAX, but that era is over  Sad
RayChuang
Thu May 02, 2002 9:58 pm
The reason why the RB.211 sounded so unique on the L1011 was because #2 engine was mounted with a unique S-duct inlet. As a result, you had that very distinct moo when the plane powers up to full power for takeoff, something you don't hear on the DC-10.
CF-CPI
Thu May 02, 2002 10:39 pm
Over time, the RB211 became a respected powerplant but in the early 70s it was a major headache, with frequent shutdowns and a couple of catastrophic failures with Eastern (one was while spooling up at the gate). Often the engines could not be started. Over time this was rectified. By the time Delta got them in late '73, Eastern had ironed out all the bugs for them  Smile/happy/getting dizzy.
The L10 was offered with only the RB211. Lockheed considered offering the CF-6 as well but it would have required too much modification to the tail, so the idea was dropped. Daniel Haughton, then pres of Lockheed, stated that not offering an alternative engine on the L10 was his biggest mistake. (Second biggest mistake was bribing All Nippon).
gr8slvrflt
Thu May 02, 2002 10:59 pm
The RB211 was a good deal shorter than the CF6 so a major redesign of the S-duct would have been required; along with a loss of seating capacity. As mentioned above, Lockheed's reliance on the RB211 as sole engine for the TriStar was disastrous for the company. For a most excellent book on the design of the L-1011 and the battle between it and the DC-10, check out The Sporty Game, by John Newhouse. A great read.
I work for Southwest, but the views expressed are my own and do not necessarily represent those of Southwest.
Ilyushin96M
Fri May 03, 2002 12:38 am
Various sources I have heard or read have stated that the RB-211 powering the L1011 was a great engine, very tough, and could take quite a bit of foreign object damage and keep on flying, compared to the CF-6, which was easily damaged. I believe the RB-211s required quite alot of maintenance, however, to keep them running smoothly. Somewhat of a contradiction for these rather complex powerplants.
GREAT video and sound, btw...it reminded me how long it's been since I flew in an L1011. Guess my chances to do so now are virtually gone.  Sad
ATA L1011
Fri May 03, 2002 5:43 am
Great Video, and that was a long takeoff. If you would have been in row 18 or lower you would have got the full sound of those 22'bs.
Treat others as you expect to be treated!
Fri May 03, 2002 6:10 am
Long download and very disappointing not to hear the start-up of the engines ... also did anyone else notice that the volume was extremely low, even with all my volume settings here at the max?
Very long take-off run ... must have been a -100 with -22B power!
jhooper
Fri May 03, 2002 7:50 am
Sorry SAS23; I didn't record the start-up of the engines (and that would have increased the length of the download), and I havn't quite figured out the volume issue with my digitizing software.
EA CO AS
Fri May 03, 2002 8:01 am
Finally, someone else who knows the famous L-1011 "moo" sound at startup!
The A-300B4 had a less-throaty, "stuck moo" sound within the cabin when full thrust was applied at takeoff.
And no, I'm not kidding!
jhooper
Fri May 03, 2002 8:37 am
I always loved listening to those L-1011 engines crank up right outside councourse A in Atlanta. I felt like the building was about to start shaking.
jkelley480
Fri May 03, 2002 9:08 am
Boeing should talk to Daniel Haughton regarding the 777LR.
TS-IOR
Fri May 03, 2002 11:35 pm
I prefer the sound of the GE90 of the 777 !!!
airman99o
Sat May 04, 2002 12:12 am
Hey there,
Here in Toronto when Air Transat starts up their L 10's what a sound. In the Crew Room over looking the B and C Gates the entire place starts to vibrate and all you can hear is this funny humming sound. Looking up to see this beast starting and spewing out smoke like there is no tommorow. Kinda took me for supurise when I first saw this happen. I love watching them take off. They all have a long take off roll just like the video here for the topic.
Airman99o
Safety is Everyones Responsibility.
