racko
Lufthansa To Choose Trent 900 For The A380
Tue May 07, 2002 7:11 pm
ATW reports that Lufthansa is going to choose the RR Trent 900 for it's 15 Airbus A380 aircraft.
Full article: http://www.atwonline.com/indexfull.cfm?newsid=1848
VERY surprising for me, i thought the engine alliance would get the deal
voodoo
RE: Lufthansa To Choose Trent 900 For The A380
Tue May 07, 2002 7:22 pm
If true,
I think R-R must be saying WHEW big time.
` Yeaah! Baade 152! Trabi of the Sky! '
SailorOrion
Tue May 07, 2002 7:26 pm
There have been rumors around that R-R is experimenting (or researching) magnetic bearings for aircraft engines. Does anyone have info on this?
SailorOrion
oxygen
Tue May 07, 2002 11:35 pm
What are magnetic bearings ?
eg777er
Tue May 07, 2002 11:50 pm
GDB
Wed May 08, 2002 2:30 am
Our R/R Olympus rep. at work told me about it this morning, a coup for R/R but the Trent series are already on the A340-600's.
Klaus
Oxygen
Wed May 08, 2002 8:56 pm
Magnetic bearings eliminate all mechanical parts of conventional bearings. They operate contact-free and need no lubrication since the rotor is kept floating by a magnetic field.
Contrary to the conventional ball/roller bearings there is no more mechanical friction and no wear and tear. In addition, by using electromagnets, an active magnetic bearing can actively counteract vibration of the rotor, thereby decreasing noise and increasing the lifespan of the remaining engine components. Since it´s almost friction-free, this technology would possibly help reducing the fuel burn even further (subtract from that the energy required to operate the bearings).
Without mechanical wear, magnetic bearings could also have much longer lifespans and longer maintenance intervals.
So in principle, the advantages are pretty impressive. If they can actually make it work, reliably...  Wink/being sarcastic
Problems could be in added complexity and possibly weight (although ball bearings aren´t exactly lightweight, either).
More: http://www.synchrony.com/MBforUAV.htm and http://www.synchrony.com/magbear.htm
