hkg82
Great Pictures Of Innsbruck-Kranebitten (INN)
Thu May 09, 2002 6:56 pm
Hkgspotter1's earlier post brought to my attention some of the fantastic pictures taken by photographers at INN. Here are some nice shots:
Photo © Andrew Hunt
Photo © Andrew Hunt
Photo © Andrew Hunt
Photo © Andrew Hunt
Photo © Andrew Hunt
Photo © Andrew Hunt
Has anyone here been to INN? What's the approach & takeoff like?
Hkg82.
BestWestern
RE: Great Pictures Of Innsbruck-Kranebitten (INN)
Thu May 09, 2002 7:29 pm
Having stayed at the Holiday Inn at INN and seen the aircraft on approach... These are very representative.
I would not like an engine failure on go-around though!
Greetings from Hong Kong.... a subsidiary of China Inc.
Established02
Thu May 09, 2002 8:11 pm
Obviously, INN has very impressive surroundings because of the closeness of the mountains on both sides of the valley. However, the approach into INN is perhaps not so complicated. I don't think that there are any sharp turns to be done. The valley is quite wide, long and straight, so I would think that this aiport may not be extremely difficult to handle for the pilots, as long as the visibility is good.
PS: I for sure appreciate that photographer Andrew Hunt recently moved from Asia to Europe.  Smile/happy/getting dizzy
SailorOrion
Thu May 09, 2002 8:49 pm
Having to fly a go around in INN is horrible, you have to do a 185° turn in the valley which is about 1.8nm wide. Have fun.
SailorOrion
ptica2000
Thu May 09, 2002 9:29 pm
And you have to fight with very strong turbolences because there is a wind called phoen.
Difficult
andyhunt
Crew
Fri May 10, 2002 4:04 am
INN is really a great airport to photograph. I had one of my best days ever when snapping the above shots.
A go around in INN would more than likely not be restricted to the valley. I think that it would be a bit wider than that.
Andrew
Full frame always beats post processing
EGGD
Fri May 10, 2002 4:14 am
Photo © Thomas Posch
Photo © Andrew Hunt
Dan Big grin
SailorOrion
Fri May 10, 2002 6:04 am
I'll check my INN approach maps next Monday and tell you about the missed approach path
SailorOrion
andyhunt
Crew
Fri May 10, 2002 2:33 pm
Ok, but perhaps only for light aircraft?? Assuming that they are different of course.
Andrew
Ansett767
Fri May 10, 2002 10:15 pm
Flying into INN is the most amazing experience of my life while flying. Flew on a Dash 8 Tyrollean
It was such a turbulent day and the approach through the mountains was absolutely magnificent!
Do it some day if you can!
 Smile  Smile  Smile
