AirIndia
Nasty Landing Approaches
Fri May 10, 2002 2:53 pm
Out of the n number of airports in the world there may be many where the landing approaches are nasty. It may be due to the geographical instances or due to demographic trends.
For eg: the landing approach at the Leh Airport (Leh is the highest airport in the world) is very risky as the ILS approach is not possible. The plane has to turn around a mountain while descending after which the runway is visible. Considering this along with the high altitude weather patterns it takes nerves to manouver a n a/c there.
Photo © Christian Hanuise
Is it true that the landing approach to the Kai Tak in HK was a nasty one and was termed as the Checkerboard approach.
lmml 14/32
RE: Nasty Landing Approaches
Fri May 10, 2002 4:49 pm
Yes re-Kai Tak. You will find numerous pictures, and even videos, of dodgy approaches on the internet. The most interesting videos I've seen are the Alitalia MD-11 and the Korean Air Freighter. I have lost the links to these two vids. Maybe someone else can help.
n949wp
Fri May 10, 2002 7:50 pm
While the approach at Kai Tak was tricky, it certainly wouldn't qualify as nasty. I'm sure there are plenty of airports around the world with equally tricky approaches, and others where the price for even the smallest screw-up is crashing. The only difference is that at most of those airports, the biggest plane you're likely to see is a 737; while at Kai Tak, you have 747's roaring by every few minutes.
Photo © Gordon Ho
Photo © Alan Tsui
Photo © Daryl Chapman
Photo © Samuel Lo
Photo © Samuel Lo
Photo © Derek Lepper
Photo © Gordon Ho
'949
wannabe
Sat May 11, 2002 1:48 am
I've gotta believe that if you could get good long distance shots from about 500 feet up, 13L at JFK would give some pretty interesting photo's. It's a Kai-Tak type approach in that you are making a right turn from base onto a short final. It's just that, since the terrain around there is all flat, it's hard to get the kind of dramatic photo's Kai-Tak produced.
TS-IOR
Sat May 11, 2002 2:26 am
Nice cote-d'azur is said to be a dangerous airport and this is not because of the relief but because of the STARs and SIDs which are for nose abatement.
GARUDAROD
Sat May 11, 2002 4:13 am
I dont know if they still are difficult, but LIH, Kauai
you used to fly in over the coast and then make a
quick descending 180 before the mountain to get down
on the runway.
SJD, Los Cabos Mexico you have to make the approach
between 2 mountain peaks, then turn and descend
over the ocean and land between the perimeter of
the ocean one side and the mountains at the other.
Wouldnt necessarily call them nasty, but if your
not expecting the sudden movements they can
certainly get your attention....
Cargo doesn't whine, moan, or complain
Leezyjet
Sat May 11, 2002 6:23 am
Courcheval is France is quite bad too, The runway goes UP the side of the mountain. (only pic on a.net tho)
Photo © Markus Herzig
The approach to LBA can be a bad one too, notorious for strong crosswinds, and also a blind spot on the ILS due to the slope on the runway.
Leezyjet.
"She Rolls, 45 knots, 90, 135, nose comes up to 20 degrees, she's airborne - She flies, Concorde Flies"
BA777
Sat May 11, 2002 6:28 am
Whats LEH's ICAO??
BA777
jasewgtn
Sat May 11, 2002 6:34 am
The ICAO for LEH, Le Harve is LFOH
RayChuang
Sat May 11, 2002 8:34 am
One particularly nasty landing approach is landing at SAN. That six-story parking structure right at the end of the runway is a collision waiting to happen, in my opinion.
trickijedi
Sat May 11, 2002 11:53 am
TGU in Tegucigalpa in Honduras is pretty challenging partly because of the mountains and the short runway.
Photo © Scott Stache
Photo © William L.B.J. Dekker
There is also an interesting article about it here on A.net. Here it is:
http://www.airliners.net/articles/read.main?id=8
Good read!
Its better to be on the ground wishing you were in the air than be in the air wishing you were on the ground. Fly safe!
AirIndia
Sat May 11, 2002 5:30 pm
There is one airport in The Netherlands Antilles i guess where the a/c land a few feet from the beach. That must be really risky. Is it true that the Schipol approach is also a bit chalenging as i guess there are simulators for the pilots to train .
Sat May 11, 2002 5:55 pm
Well, there is St. Barths in the Caribbean...
Photo © Elvio Adrian Salomon
-Clovis Big grin
AirIndia
Sun May 12, 2002 1:01 am
Was the crosswinds at Kai Tak made it challenging or was it the low City scape approach. Tried the approach on the MS Flight Sim on a 737.....crashed on the turn  Big grin ...
GD727
Sun May 12, 2002 1:41 am
Airindia might be referring to the world famous St. Maarten. The approach to SXM must be an interesting one!
Photo © Hiromichi Miyagaki
Photo © Justin Cederholm - Orlando/Tampa Aviation Photography
-GD727
Mmmm forbidden donut.
NZ767
Sun May 12, 2002 4:22 pm
Airindia,
Crosswinds at Kai Tak used to add to the fun but the real deal was that they had to track the IGS (Inertial Guidance System as opposed to ILS) towards the checkerboard located on a hill and then the right turn at around 400 feet to line up with the runway.
Not much room for error.  Smile
NZ767
Sun May 12, 2002 8:00 pm
Oops!!
Correction:
IGS=Instrument Guidance System. Big grin
A320-addict
Sun May 12, 2002 8:30 pm
Some very nasty approaches, and runways can be found on many of the Greek Islands.
Islands like Mitilini and Chios have only a runway under 1500m..... There is not much room if you need a minimum of 1200m or 1300m to land  Wow! , on most of the charterplanes (depending on the weight). Even if you float a little you might be ending up with wet feet, or of the runway. I consider those as most challenging...  Big thumbs up  Big thumbs up
Others like Iraklion have a bit of a longer runway but have very limited approach facilities. In Iraklion you make a non precision of-set approach coming over the water, which on short final takes you dangerously close to a mountain ridge. At night the approach is even more challening because of the limited lightening system of the airport.
I do agree most of these destinations have beautiful weather during summer, and often you can make a visual approach, but even in these months they can be very nasty.
A third difficulty is the terrain. Some airports have long runways, equiped with an ILS and full light facilities, but the approach takes you over (very) high terrain.
Some airports in Turkey are very known for this...
Antalya, Dalaman, Izmir... sometimes the approach controller provides you with radar vectors there, but letting you descent way too early, a real hazard for CFIT (Controlled flight into terrain) One mistake could be fatal.  Wow!  Wow!
blink182
Sun May 12, 2002 11:08 pm
There is also Vail/Eagle County Colorado(EGE). Right after take off, you have to make a sharp right turn in order to avoid a mountain.
blink
Give me a break, I created this username when I was a kid...
