TWA902fly
What's This? DL 9666 ATL-ORD For Sale As Normal?
Thu May 16, 2002 9:10 am
This is what i found while searching for tickets. On June 9th 2002...
Delta Airlines 9666
Boeing 737-800 3:10 pm
Atlanta, GA (ATL) 4:00 pm
Chicago, IL (ORD) 1st Y Coach Y 606 miles 1:50 flight time
someone help me out?
This flight is for sale as normal by why does it have such a high flight number?
TWA902
life wasn't worth the balance, or the crumpled paper it was written on
b727
RE: What's This? DL 9666 ATL-ORD For Sale As Normal?
Thu May 16, 2002 9:41 am
Hello,
I would have to say, that this aircraft was ferried into ORD sub for a jet that was down. Delta flight numbers starting with 9 are either maintenance flights of positioning flights. Maybe someone with more Delta experience expand.
B727
Glenn
padcrasher
Thu May 16, 2002 9:49 am
The 9000 series is used for extra sections. There is a camp in Illinois that week for troubled youth...good luck.
padcrasher
Thu May 16, 2002 10:09 am
Of course I'm joking about the camp... Smile
jessman
Thu May 16, 2002 11:12 am
The high flight number indicates an extra flight that is not a part of the regular schedule. In this case they need that aircraft there in ORD for a charter for a professional sports team. Rather than ferry the aircraft there without passengers or take some other regularly scheduled flight to Chicago and have it as the charter they bring an extra flight up to Chicago so they don't mess up the rest of the schedule. For the aircraft returning to Atlanta after its charter operation see flight 9675 on 10JUN.
Other times you will see an extremely high flight number are at the last minute, for example if there is an extremely high load factor in a particular market for whatever reason you may see an extra flight with a 9000 series flight number. Also if there is an extreme delay on a through flight it may be split into two flights the latter of which will have a flight number in the 9000s. Charter flights themselves have 9000 series flight numbers, but they will not be available for sale to the general public. Hope this helps Smile
