kjet12
Which Airbus Engine Is Better For The 319/320/321?
Thu May 30, 2002 11:48 am
I'm sorry if this topic has already been discussed but, which engine is better for the A319, A320, A321 as far as reliablility, fuel efficiency, etc? Also, which engines do most customers choose for that family of airliner? How is the new PW engine for the A318?
Thanks For Flying,
Kris
Photo © Torsten Maiwald
Photo © Arthur Yu
AA - Doing what we do best.
baec777
RE: Which Airbus Engine Is Better For The 319/320/321?
Thu May 30, 2002 11:52 pm
Rolls Royce powerplants !!!
Photo © Jason Taperell
Photo © Jim Metzger
Photo © Daems Guy
Photo © Joe Pries
Photo © Charles Falk
Photo © Florian Kondziela
baec
cmb320
Fri May 31, 2002 2:37 am
Which engines does America West use on their Airbii?
baec777
Fri May 31, 2002 3:16 am
America West also has RR engines.
Photo © Mark Durbin
Photo © Timothy Keeney
baec
N79969
Fri May 31, 2002 3:19 am
Those aren't actually RR engines but look like the RB211 engines. They are made by International Aero Engine (IAE) which is a joint venture between RR, PW, and several other companies.
The PW6000 for A318 is having serious development problems and will be delayed for a couple of years.
kjet12
Fri May 31, 2002 8:01 am
Why does Lufthansa use both GE and IAE for their A320 Family? Is that economical?
Thanks For Flying,
Kris
BR715-A1-30
Fri May 31, 2002 8:11 am
The V2500 is the best engine for the A320.
Photo © French Frogs AirSlide
The CFM56-3B1 best fits on the 737-300/400/500
The CFM56-7 best fits on the 737-600/700/800/900/1000 (Hey, So I like to think ahead.)  Smile
Puhdiddle
AWspicious
Fri May 31, 2002 8:34 am
Wouldn't the lighter engine be the better choice.... thrust output being equal? Because, one options out weights the other by roughly two thousand pounds.
I'm not well versed on the specifics of fuel burn rate, but perhaps, someone with a little more technical knowledge could enlighten us... Because, I'm sure that would be another key consideration.
aw
Nevermind political correctness - Envision using your turn signals!
UAL Bagsmasher
Fri May 31, 2002 8:43 am
LOL...well....UA has the IAE engines. Yesterday on takeoff to TPA from ORD, one of our A320's had #2 engine explode. It came back on fire. Every last turbine blade in the back end of that thing was busted and/or melted. I saw it after the fire Dept. got done w/ it.
Cpt Underpants
Fri May 31, 2002 9:20 am
CFM is better for reliability and cost of repairs / parts etc. It is also lighter, allowing for more useful load. The newer -5B versions have better power than the -5A and are flat rated to a higher temperature. Nice for high and/or hot ops.
IAE is better for fuel economy, but the -A1 version with thrust bump is just stupid! The -A5 has better power and flat rating as well, but is a real heavy beast.
