b764
Why No UA CLT-DEN Flights?
Fri May 31, 2002 5:52 am
Topic speaks for itself.
b764
RE: Why No UA CLT-DEN Flights?
Fri May 31, 2002 5:53 am
Could it support a 752? Cleveland used to get DC-10, 752 aircraft to ORD.
Ryefly
Fri May 31, 2002 6:03 am
US Airways currently has three flights a day to DEN, (two A319's and one A321). I could imagine United doing well on flights to DEN from CLT. Possibly A319, A320, or 757's.
BA
Fri May 31, 2002 6:25 am
United's Eastern network from DEN is quite weak for a hub of its size.
UA doesn't even serve CVG or PIT from DEN.
Before 9/11, UA's goal was to add more Eastern routes from it's DEN hub, however these plans have now been put on hold as United's main goal is to recover financially. Then when the time is right, you'll see United continue on with its plans.
There are MANY Eastern networks that United doesn't serve from DEN.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
SegmentKing
Fri May 31, 2002 6:42 am
cause UA can't get a CRJ to fly the route yet :P
But trust me, once there is an RJ that can make it, UA will put on 8 flights a day to Denver *smirk*
-n
~ ~ ~ ~ pRoFeSsIoNaL hUrRiCaNe DoDgEr ~ ~ ~ ~
ual777contrail
Fri May 31, 2002 9:33 am
i wonder if UNITED has a big enough name in CLT to operate that kind of flight.a320,757?
737?
ual 777 contrail
BA
Fri May 31, 2002 9:35 am
Ual777contrail,
With the connections they provide at DEN, the flights should do fine.
b764
Fri May 31, 2002 9:39 am
Would love to see a 752 here in CLT. Thanks for the info!
