hamad
This Door Handle?
Mon Jun 03, 2002 5:52 am
in this picture, i see the door handle sticking up from outside, so i was wondering, was this door opened from inside? or when you open the door from inside does the handle crack open from outside?
Photo © Mike Hillwig
PHX - i miss spotting
iahcsr
RE: This Door Handle?
Mon Jun 03, 2002 6:22 am
The most likely answer in this case is that the door was opened from the outside by the catering crew. However, while not designed to do so, I have, on occasion, seen the exterior handle extend when the door has been opened from the inside. A little WD40 (or the aircraft equivalent) on the mechanism would take care of that problem.
skyhawk
Mon Jun 03, 2002 6:52 am
The door handle most likely was opened slightly from inside. This would be to let the caterers know that it was safe to open the door and re-supply the aircraft.
fly_emirates
Mon Jun 03, 2002 9:28 am
we flight attendants usually dont open the door from inside. the gate agents will knock the door, so does the caterers, now if we gave them an ok sign upon arrival after disarming the door, they will crack the door open and we will push the door.
Caterers usually knock on the door upon arrival and the same thing applies. but if the plane was parked at the gate, they will knock and open it by themselves.
On airbus planes and from b747 and upward, the door will indicate that it is armed. but usually, its ok to open the door for a parked plane without passengers, the door on most planes (with the exception of the 717,727,737 and the DC9's,) will automatically disarm if opened from outside.
i think that door was cracked open from outside. since the handle is up
concorde1518
Mon Jun 03, 2002 10:07 am
how will the gate agent crack the door? I always thought that the Jetway was narrow enough that It will block the door by not being wide enough to accomodate both the opening AND the door resting againt the side of the fuselage. Could you explain the process of opening the door (L1, or whatever is being hooked up to the Jetway on that particular plane) while moving the Jetway in? Thanks
Aaron
fly_emirates
Mon Jun 03, 2002 10:26 am
concorde1518,
the jetway is usually that wide so that it will allow the gate agent to open teh door, because the doors will be disarmed while the jetway is being pushed to the door of the plane, then the gate agent will knock on the door so that it opens.
jetways are wide, and the flight attendants are not permitted to open the doors by themselves except in emergencies. it differs from airport to another, but thats at least in the airports we fly to
fly_emirates
Mon Jun 03, 2002 11:02 am
Photo © DIGITALEX Wiecka
this door was opened after the stairs was plugged into the door.
concorde1518
Mon Jun 03, 2002 12:43 pm
Thanks guys!
 Smile
lmml 14/32
Mon Jun 03, 2002 8:01 pm
On A320 the exterior handle does not move when the door is opened from the outside. When closing the door from the inside with the exterior handle extended, this is retracted automatically.
Hope this helps.
