TechRep
What Is Going On Here? Test
Sat Jun 08, 2002 11:29 pm
The engineer above is doing certification testing on the Dornier 728. Can you tell me what he is testing?
TechRep
TechRep
RE: What Is Going On Here? Test
Sat Jun 08, 2002 11:32 pm
Here is the Ex-Large Photo link. If your brower supports it, the photo can be blown up very large.
http://photos.imageevent.com/techrep/728recentphotos/huge/what%20is%20going%20on.jpg
TechRep
Sun Jun 09, 2002 12:14 am
Maybe a bar connecting the front part to the thing that holds onto the wheel?
TechRep
Sun Jun 09, 2002 12:30 am
This engineer is doing a required test for type certification but what is he testing or testing for? I know the answer lets see if you do.
TechRep
Theiler
Sun Jun 09, 2002 12:59 am
All I can think of would be some sort of shock/strut compression test for the gear, or maybe a test of the retraction motor/mechanism.
Just a W.A.G on my part, I really don't have a clue!
fly_yhm
Sun Jun 09, 2002 6:00 am
My guess is that he is testing something with the nose wheel to see if it give enough leway on touch down.
Where will you spend eternity? He,s more real then you think!!!!!
Jj
Sun Jun 09, 2002 6:36 am
He's testing the landing gear doors?
wietse
Sun Jun 09, 2002 6:44 am
hes probably not testing big structural design stuff, like: will the wheel fit? That would have been done during developing of the a/c. My guess is he's testing the Communication interface for the ground crew.
Wietse
Wietse de Graaf
TechRep
Sun Jun 09, 2002 6:48 am
All incorrect so far.
Hint: it happens on taxiing and at high speeds.
TechRep
OPNLguy
Sun Jun 09, 2002 7:07 am
How about a shimmy dampener?
TechRep
Sun Jun 09, 2002 7:38 am
This is in fact vibration testing. The nose strut will be tested through all degrees of extension for vibration while hydraulics are applied by use of the test stand you see in the background. The unit that is attached to the nose wheel assy hub will simulate this vibration by use of a DC motor exerting simulated loads. The wires are part of the vibration analysis equipment designed to measure the IPS or (inches per second). IPS are also also for the standard of measure on engine vibration equipment.
TechRep
