Bruce
Why Different Airport Callsigns?
Fri Jun 14, 2002 4:58 am
Why are there 2 sets of callsigns for airports? MIA is also known as KMIA, Prestwick is known as PIK or EGPK? And Heathrow (I think) is EGLL or LHR? Are most airports in Europe known by E___? In Mexico you have MMMX or MEX.
different letters gets confusing!!!!!!!!!
bruce
Lindy
RE: Why Different Airport Callsigns?
Fri Jun 14, 2002 5:01 am
If I am correct those are ICAO and IATA codes.
BWIADCA - Nikon D100
donder10
Fri Jun 14, 2002 5:02 am
2 different systems.
4 letter US codes are just K+3letter code.Canda is C+3 letter code.
IATA is 3-letter.
ICAO is 4 letter.
I usually go by the IATA codes. However, pilots use ICAO for navigational purposes.
Bruce
Fri Jun 14, 2002 2:12 pm
Ok, but why do we even need 2 different systems anyway?
bruce
tsentsan
Fri Jun 14, 2002 2:17 pm
One's for travel agents (IATA)
One's for FMS navigation (ICAO)
NO URLS in signature
concorde1518
Fri Jun 14, 2002 2:33 pm
IACO codes are pretty much unheard of by passengers... Most people think that pilots refer to VHHH as HKG just like them...... My guess as to why there are two is that there are so many airports out there that the last three letters are bound to be repeated somewhere in the world. Therefore, if we add a letter in front depending on country and make it so the code DOESN'T necessarily reflect the name of the airport, there can be less confusion from differentiating between airports.... Airlines probably use the IATA codes for passengers, because no passenger will ever remember to use "EGLL", or "VHHH", so, they will use simple things like HKG or LHR....
Just a guess....
 Smile
foghorn
Sat Jun 15, 2002 6:21 am
ICAO codes are not just for airports - they are 'location codes'. For instance Flight Information Regions, en-route Air Traffic Control centres and a variety of other aviation-related offices also have ICAO codes e.g. EGTT for the London FIR. This allows messages usung the AFTN (Aviation Fixed Telecommunication Network) to reach their intended recipients globally in a standardised way.
The ICAO codes are used almost exclusively within aviation (except occasionally when facing passengers). and are much more comprehensive than the IATA codes.
On the other hand, the three letter IATA codes were designed for travel agents (IATA = International Association of Travel Agents).
